ADIZ pilot's ticket revoked
Old May 25th 05, 04:48 PM
Matt Barrow
In rec.aviation.owning Matt Barrow wrote:
In rec.aviation.owning Roger
On Tue, 24 May 2005 06:40:25 -0700, "Matt Barrow"
There is an audit trail both on the PC (unless it's erased) and on
Duats (Session and Transaction number).
Only problem is they never claimed to have checked Duats and that's
only one that officially counts.
Quite! He said he checked weather and NOTAMS on some "unofficial" web
site.
IIRC, he never mentioned if the "other" web site showed the RA.
If the feds wanted to verify his story, they'd have to do a complete
disk
recovery and it's not likely they would do so in a relatively trivial
case
such as this. I suspect his lawyer knows this and used that excuse as a
dodge against a negligence action.
I don't use DUATS either, but I print everything I do get, weather,
TAFs,
maps, _everything_, and keep it in a flight folio.
That won't do you much good in a legal battle; only DUATS or a call to
FS is an official CYA.
It depends if the battle was a criminal action or a negligence action.
I'd rather have the actual DOCUMENTS than just a log that said I did in fact
call for a briefing. And yes, I can print from DUATS, but until recently
(IIRC) all you could do was screen dumps. I don't know when they changed,
but I remember when all you could do was accesss them from a dumb terminal
and printing was impossible.
I check weather etc. elsewhere than finish with DUATS for a scan of
NOTAMS and PIREPS and to get my official square checked.
It may be up to the second and the most thorough but it's isn't "Official"
as far as I know (hanger lawyers, what say??).
Could you prove that you did anything more than just scan the data on the
screen?
Old May 25th 05, 05:04 PM
Dave Butler
If you access the raw text service with telnet, and use any of the modern
terminal emulators, you can easily get a text file that you can browse with your
favorite text editor, print, run post-processing filters, etc...
Old May 26th 05, 04:17 AM
Matt Barrow
"Dave Butler" wrote in message
news:1117036890.671631@sj-nntpcache-5...
fact
changed,
terminal
with your
Whoopie do!!
If I had a Model-T Ford, I could hand crank the engine! :~)
Old May 26th 05, 01:49 PM
Dave Butler
Matt Barrow wrote:
Whoopie do!!
Do as you wish.
Old May 25th 05, 07:09 PM
snip
DUATS has been an official briefing for a few years now.
screen?
No more than you can prove you were listening when you called FS.
Jim Pennino
Remove .spam.sux to reply.
Old May 26th 05, 04:13 AM
Matt Barrow
snip
"Official"
Site?
screen?
Which is why I print everything.
Old May 26th 05, 05:17 AM
snip
"Official"
Site?
http://www.duats.com/faq.html
"When getting a briefing on DUATS, is this considered to be a legal
pre-flight briefing, with the same standing as a briefing I'd get by
calling Flight Service?
Yes. A DUATS route briefing contains the same elements as a route
briefing which is provided by an FAA Briefer. The briefing is recorded
by DUATS, and your receipt of the data can be proven, should the need
arise. (Of course, this requires you to sign on to DUATS using your own
DUATS Access Code or Personal Access code!) The DUAT service is paid for
by the FAA, and is certified by the FAA as being equivalent to a live
Flight Service Specialist for pre-flight briefings."
Good enough for you?
screen?
Which is totally, absolutely useless for legal purposes.
Only a FAA or a DUATS briefing counts.
Jim Pennino
Old May 26th 05, 05:22 AM
Dave Stadt
snip
of
"Official"
Site?
on
screen?
Where is that documented?
Jim Pennino
Old May 26th 05, 05:59 AM
In rec.aviation.owning Dave Stadt wrote:
snip
Which part? That you need a briefing, that it has to be "official" or
that FS and DUATS are the only briefings that count?
91.103 says you need a briefing and contains the catch all of "all
available information concerning that flight" which to the FAA enforcers
means weather, NOTAMs, TFRs, etc.
AIM 5-1-1 says FS or DUATS.
There was a proposed AC to add other services; I don't know if it was
approved.
There have been articles on AOPA about the consequences of not using
the "official" sources; a search should find them.
Jim Pennino
Old May 26th 05, 01:42 PM
Dave Stadt
snip
That's not what 91.103 says.
It suggests FSS or DUATS.
approved.
I have seen FAA statements to that effect but only for part 91 flights.
Light Sport Aircraft for Private Pilots (Long) Jimbob Owning 17 March 1st 05 03:01 AM
Bush Pilots Fly-In. South Africa. Bush Air Home Built 0 May 25th 04 06:18 AM
Older Pilots and Safety Bob Johnson Soaring 5 May 21st 04 01:08 AM
UK pilots - please help by completeing a questionnaire Chris Nicholas Soaring 0 September 15th 03 01:44 PM
