In fact it is the other way around.
Is the winglets that is the key. The "blunting", changing the first 10% of the airfoil in the outboard section of the wing was thought to improve the climb but it turns out to be a well designed winglet that made the difference. The factory winglet did not perform as well. Those in the know are changing back to the original airfoil as the cruise is improved but climb does not deteriorate. It was not the airfoil but rather the small Reynolds numbers in the wing tip region that caused the problem, which the winglet corrected. The 24 is still very competitive indeed. I do agree with the rest of your comments. Regards Udo wrote in message oups.com... Lee, The ASW-24 is a great aircraft, but I'm sure you have discovered in your research that the 24's original airfoil was discovered to not perform as well as expected in rough air. There was a relatively simple remedy which was to "blunt" the leading edge. Before worrying about the winglets I'd check to ensure that this modification has been done. And to answer your question, if the avionics are top notch and the winglets PROPERLY installed and the finish in very good condition, then $45k sounds like a fair price in my opinion. It's a beautiful aircraft. Respectfully, Lee Rusconi wrote: I have an opportunity to buy a 1988 ASW-24 which is in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
I slightly disagree with Udo. The best result, in my opinion, having
flown '24's in all the combinations, is the leading edge mod and improved winglets together give the best total result. I never saw any deterioration of glide with leading edge mod and did see improvement in gust sensitivity. He is very much correct that winglet is most important as it keps the tip working and aileron effective down to a speed where overall drag on the airfoil begins to rise due to separation. '24 is a great glider, I'd still have it today if Gerhard had not made a little bit better glider in the "28. Good Luck UH |
