As I recall, the ASW-24 had a climb problem until it
was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ At 02:00 26 May 2005, Udo Rumpf wrote: In fact it is the other way around. Is the winglets that is the key. The 'blunting', changing the first 10% of the airfoil in the outboard section of the wing was thought to improve the climb but it turns out to be a well designed winglet that made the difference. The factory winglet did not perform as well. Those in the know are changing back to the original airfoil as the cruise is improved but climb does not deteriorate. It was not the airfoil but rather the small Reynolds numbers in the wing tip region that caused the problem, which the winglet corrected. The 24 is still very competitive indeed. I do agree with the rest of your comments. Regards Udo wrote in message roups.com... Lee, The ASW-24 is a great aircraft, but I'm sure you have discovered in your research that the 24's original airfoil was discovered to not perform as well as expected in rough air. There was a relatively simple remedy which was to 'blunt' the leading edge. Before worrying about the winglets I'd check to ensure that this modification has been done. And to answer your question, if the avionics are top notch and the winglets PROPERLY installed and the finish in very good condition, then $45k sounds like a fair price in my opinion. It's a beautiful aircraft. Respectfully, Lee Rusconi wrote: I have an opportunity to buy a 1988 ASW-24 which is in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
J.J.
Since I am a relative late comer to the ASW 24 and have flown it only with the B mod. and Nixon winglet My target speed "at a 45deg". bank and empty at 7.3lb/sqft is about 50kt. Regards Udo "John Sinclair" wrote in message ... As I recall, the ASW-24 had a climb problem until it was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ At 02:00 26 May 2005, Udo Rumpf wrote: In fact it is the other way around. Is the winglets that is the key. The 'blunting', changing the first 10% of the airfoil in the outboard section of the wing was thought to improve the climb but it turns out to be a well designed winglet that made the difference. The factory winglet did not perform as well. Those in the know are changing back to the original airfoil as the cruise is improved but climb does not deteriorate. It was not the airfoil but rather the small Reynolds numbers in the wing tip region that caused the problem, which the winglet corrected. The 24 is still very competitive indeed. I do agree with the rest of your comments. Regards Udo wrote in message groups.com... Lee, The ASW-24 is a great aircraft, but I'm sure you have discovered in your research that the 24's original airfoil was discovered to not perform as well as expected in rough air. There was a relatively simple remedy which was to 'blunt' the leading edge. Before worrying about the winglets I'd check to ensure that this modification has been done. And to answer your question, if the avionics are top notch and the winglets PROPERLY installed and the finish in very good condition, then $45k sounds like a fair price in my opinion. It's a beautiful aircraft. Respectfully, Lee Rusconi wrote: I have an opportunity to buy a 1988 ASW-24 which is in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
JJ,
Good winglets fix the climb "problem" (which wasn't much of a problem--I flew mine sans winglets the first year and loved it). Hank Nixon and I have a friendly ongoing debate over whether the modified leading edge (the famous "B" mod) does anything beneficial. He did the mod; I didn't. I think he's just keen to see me take a file to my leading edge. With Hank's latest winglets, my ship climbs with anything. I'd thought until last year that I had to fly it a little faster; e.g., low 50s (kts.) in moderate banks. But I discovered at New Castle that in survival conditions, I could fly it just like a 1-26 and it climbs great: i.e., slow it down until it's on the edge of buffet. There may or may not be some benefit to the blunter "B" leading edge in gusty thermals but I haven't noticed. I do agree with those who believe that the debate over the airfoil, micro-turbulence, etc., was primarly a very effective (obviously!) marketing campaign on the factory's part. After all, how do you sell a brand new glider that doesn't seem to go any better than the old model unless you can point to something that's been "fixed"? ![]() Chip Bearden "JB" ASW-24 owner since 1992 John Sinclair wrote: As I recall, the ASW-24 had a climb problem until it was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ |
It's true what you say. The first flights I tried to thermal at 80-85kph,
just as I had done on ASK-21, Astir, and Discus I previusly flew. Found it harder to climb. I thermal now around 90-95kph and I find no problem. Just had to be slightly more careful about speed. It climbs very well if you respect the speed range. "John Sinclair" escribió en el mensaje ... As I recall, the ASW-24 had a climb problem until it was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ |
Of course it would be true, at 80km/k you would be flying to slow
if you tried to thermal. This is minimum sink speed in level flight at 6.5 lb/sqft. at 7.5 lb/sqft you would be approaching stall speed. To recap the ASW24 does not have to be flown any faster then other glider of its type. Two gliders you have mentioned have a much lighter wingloading and the Discus and the ASW24 with 7.5 lb/sqft will fly at about the same speed. Now I know how misinformation gets started. Regards Udo "J.A.M." wrote in message ... It's true what you say. The first flights I tried to thermal at 80-85kph, just as I had done on ASK-21, Astir, and Discus I previusly flew. Found it harder to climb. I thermal now around 90-95kph and I find no problem. Just had to be slightly more careful about speed. It climbs very well if you respect the speed range. "John Sinclair" escribis en el mensaje ... As I recall, the ASW-24 had a climb problem until it was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ |
![]() Udo Rumpf wrote: Of course it would be true, at 80km/k you would be flying to slow if you tried to thermal. This is minimum sink speed in level flight at 6.5 lb/sqft. at 7.5 lb/sqft you would be approaching stall speed. To recap the ASW24 does not have to be flown any faster then other glider of its type. Two gliders you have mentioned have a much lighter wingloading and the Discus and the ASW24 with 7.5 lb/sqft will fly at about the same speed. Now I know how misinformation gets started. Regards Udo Udo, A related question in terms of data points. How significant is the in-flight CG on climb performance? It's purely subjective, but my LS8 seems to climb markedly better now that I've moved the CG back to about 80% of aft limit (from a previous 45%). Locically, aft CG would reduce the amount of lift (nose up pitch) required of the elevator/stabilizer, reducing induced drag from these surfaces. As a percentage of total induced drag I'm sure this relatively small, but is it significant? Erik Mann (P3) |
Eric
From my initial set-up I flew with a C of G in the 50% to 55% range. This worked out nicely. The up elevator in climb was identical to the down in cruise. I was happy with this compromise. Then I loaded water 55 litres in each tank about 240 lb total. To thermal, I needed much more control input and up elevator, due to the water being ahead of the C of G. Also I had the sense, aside from being heavier, it was not climbing as well. This could have been subjective. I added 5 lb to the tail and the handling improved and felt just as before when dry. I was surprised when I dumped the water how much more nimble and responsive but still very comfortable it felt. I am flying dry now at 85% C of G. The elevator with the new C of G, once the bank and turn is established, has a minimal up deflection but in cruise the elevator is even more in a down deflection. This causes more drag. This can be corrected by placing a washer under the bolt attachment of the stab to reduce the angle of incidence to reduce the down deflection in cruise. Ideally the ASW 24 should have a tail tank. Anyone know of someone that made this mod on the 24? Regards Udo "Papa3" wrote in message ups.com... Udo Rumpf wrote: Of course it would be true, at 80km/k you would be flying to slow if you tried to thermal. This is minimum sink speed in level flight at 6.5 lb/sqft. at 7.5 lb/sqft you would be approaching stall speed. To recap the ASW24 does not have to be flown any faster then other glider of its type. Two gliders you have mentioned have a much lighter wingloading and the Discus and the ASW24 with 7.5 lb/sqft will fly at about the same speed. Now I know how misinformation gets started. Regards Udo Udo, A related question in terms of data points. How significant is the in-flight CG on climb performance? It's purely subjective, but my LS8 seems to climb markedly better now that I've moved the CG back to about 80% of aft limit (from a previous 45%). Locically, aft CG would reduce the amount of lift (nose up pitch) required of the elevator/stabilizer, reducing induced drag from these surfaces. As a percentage of total induced drag I'm sure this relatively small, but is it significant? Erik Mann (P3) |
![]() Udo Rumpf wrote: Eric The elevator with the new C of G, once the bank and turn is established, has a minimal up deflection but in cruise the elevator is even more in a down deflection. This causes more drag. This can be corrected by placing a washer under the bolt attachment of the stab to reduce the angle of incidence to reduce the down deflection in cruise. Ideally the ASW 24 should have a tail tank. Anyone know of someone that made this mod on the 24? Regards Udo What you really need is a lead weight on a track mounted in the fuselage driven by a small motor. Move the weight back for climb. Move it forward for cruise :-)) Actually, the flight research department at my University had this installed in Navions. I guess I'm only half-joking... P3 |
Papa3 wrote:
Udo Rumpf wrote: Eric The elevator with the new C of G, once the bank and turn is established, has a minimal up deflection but in cruise the elevator is even more in a down deflection. This causes more drag. This can be corrected by placing a washer under the bolt attachment of the stab to reduce the angle of incidence to reduce the down deflection in cruise. Ideally the ASW 24 should have a tail tank. Anyone know of someone that made this mod on the 24? Regards Udo What you really need is a lead weight on a track mounted in the fuselage driven by a small motor. Move the weight back for climb. Move it forward for cruise :-)) Actually, the flight research department at my University had this installed in Navions. I guess I'm only half-joking... P3 Reminds me of the "mercury pump" gadget Moffat supposedly revealed to his fellow contestants on the start grid one long-ago day. Didn't matter whether it worked or not, the other guys were so psyced out they were beaten before they hooked up. Bob Johnson |
At 19:30 27 May 2005, Bob Johnson wrote:
Papa3 wrote: Udo Rumpf wrote: Eric The elevator with the new C of G, once the bank and turn is established, has a minimal up deflection but in cruise the elevator is even more in a down deflection. This causes more drag. This can be corrected by placing a washer under the bolt attachment of the stab to reduce the angle of incidence to reduce the down deflection in cruise. Ideally the ASW 24 should have a tail tank. Anyone know of someone that made this mod on the 24? Regards Udo What you really need is a lead weight on a track mounted in the fuselage driven by a small motor. Move the weight back for climb. Move it forward for cruise :-)) Actually, the flight research department at my University had this installed in Navions. I guess I'm only half-joking... P3 Reminds me of the 'mercury pump' gadget Moffat supposedly revealed to his fellow contestants on the start grid one long-ago day. Didn't matter whether it worked or not, the other guys were so psyced out they were beaten before they hooked up. Bob Johnson Moffat comes from a racing sailboat tradition, where trickery is admired if not the norm and where clever rule beating devices are constantly developed. I heard of one sailor who, not allowed ballast at his weighing, put several boxes of tomato soup (highest specific gravity) in the bilges as crew provisions. I never met George and I'm not accusing him of cheating, but the out-psych'em strategy is certainly a NE tradition. |
