Yet another media outlet gets it WRONG
Old May 26th 05, 07:14 PM
gatt
"Larry Dighera" wrote in message
If our government is going to put pilots in their deadly cross hairs,
their policies must be infallible. This intercept policy is flawed,
as demonstrated by this incident.
How is it flawed? It worked. The plane was diverted, nobody was killed,
the media made a bunch of money and an idiot lost his certificate.
-c
Old May 26th 05, 07:27 PM
Larry Dighera
On Thu, 26 May 2005 11:14:56 -0700, "gatt"
wrote in ::
How is it flawed?
It relies upon radio communications that are inherently unreliable.
That is true this time.
What if the C-150 had gotten close enough to the White House to
trigger ground fire as a result of its inability to communicate via
radio? Would you still characterize the policy as having worked?
Old May 27th 05, 09:17 AM
Stefan
It does not. There are visual signs.
Stefan
Old May 27th 05, 01:46 PM
Larry Dighera
On Fri, 27 May 2005 10:17:47 +0200, Stefan
wrote in ::
It does not.
It seems to have to some extent in this case. And that failure in
establishing communications apparently resulted in delaying the Cessna
from diverting course away from ground based weapons and certain
death.
That is true also. However, I have not read/heard reports of the
standard/documented* visual signs being successfully given in this
case.
In this case, apparently initially attempting to use radio
communications to communicate with the pilot of the Cessna 150 failed
resulting in the aircraft continuing deeper into the White House FRZ.
The F-15 intercept aircraft had to resort to the deployment of flairs
(an undocumented procedure outside what pilots are taught to expect in
intercept situations) to cause the Cessna to change course. Should
the flight have continued 15 to 20 seconds longer without changing
course, government spokesmen have said the order to shoot it down
would have been given. Such a close encounter with our government's
lethal force makes me uncomfortable, and calls into question the
adequacy of the intercept procedures as they are currently written.
From the information (of admittedly questionable credibility) I've
seen, it appears the PIC's judgment in intentionally launching without
being current to carry passengers, with a pre-9/11 chart, was notably
poor. It appears to me, that he hadn't been aloft for a good length
of time, and his lack of currency resulted in his flight becoming a
hazard to aerial navigation and causing a disruption of governmental
decorum. But I don't consider those offences to warrant a death
sentence.
So while this case reflects badly on GA pilots, it also points out the
indiscretion of the security policy currently in place in the vicinity
of our nation's capital and those who drafted it.
* http://www.aopa.org/whatsnew/newsite...intercept.html
Old May 27th 05, 11:50 PM
gatt
Nope. But it didn't work out that way.
If you're arguing that the margin of error was a little slim and shows flaws
with relying on radio communications, I might agree. Except, there's no way
to hook a landline to an airplane, or board it, so using radio to
communicate with it is more or less necessity, isn't it?
'Course, publishing the ADIZ, TFRs, FARs, requiring weather briefing and
expecting a certificated pilot to be able to navigate in VFR don't seem to
have worked either.
Personally, I don't have much sympathy for the guy.
-c
Old May 28th 05, 04:18 AM
Larry Dighera
On Fri, 27 May 2005 15:50:00 -0700, "gatt"
wrote in ::
It hasn't worked out that way yet. But the lethal force dictum has
only been in place for a few years so far. Given the narrow margin
the Cessna flight escaped tragedy, I would expect that someone will
get shot down for no good reason within the coming decades.
Thank you.
It's only a necessity if you consider the security measures effective
in stopping terrorist activity. I find it difficult to see how the
current security policy accomplishes what it purports to address.
More intelligent people need to reassess what measures might be more
effective, IMO.
have worked either.
Humans make mistakes; it's human nature. If those mistakes intrude on
the rights or safety of others, they should be made to compensate
those affected by their mistakes/inelegance. In this case, the
disruptive evacuation in DC was a result of misguided security
officials/policy, and the only threat to the safety of others occurred
as a result of those misguided security officials/policy not the
Cessna PIC.
I have no sympathy for the Cessna PIC at all, but I don't consider
that to be the issue here.
Old May 28th 05, 04:36 AM
Orval Fairbairn
Cessna PIC.
I agree with Larry here. It seems that the entire security apparatus of
this country is run by a combination of Chicken Little and Fearless
Fosdick.
For those who don't remember, Fearless Fosdick was the Al Capp takeoff
on Dick Tracy, who shot "criminal jaywalkers" while ignoring real
criminals. Everyone knows the story of Chicken Little.
Remove _'s from email address to talk to me.
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Naval Aviation 5 August 21st 04 12:50 AM
Conspiracy Theory’s real Script: Slave CIA, FBI change the story jews wanted to tell the media Jean-Paul Roy Restoration 0 July 12th 03 12:55 PM
MEDIA ADVISORY ON 767A REPORT TO CONGRESS Otis Willie Military Aviation 0 July 11th 03 09:30 PM
