Larry Dighera wrote:
It relies upon radio communications that are inherently unreliable. It does not. There are visual signs. Stefan |
On Fri, 27 May 2005 10:17:47 +0200, Stefan
wrote in :: Larry Dighera wrote: It relies upon radio communications that are inherently unreliable. It does not. It seems to have to some extent in this case. And that failure in establishing communications apparently resulted in delaying the Cessna from diverting course away from ground based weapons and certain death. There are visual signs. That is true also. However, I have not read/heard reports of the standard/documented* visual signs being successfully given in this case. In this case, apparently initially attempting to use radio communications to communicate with the pilot of the Cessna 150 failed resulting in the aircraft continuing deeper into the White House FRZ. The F-15 intercept aircraft had to resort to the deployment of flairs (an undocumented procedure outside what pilots are taught to expect in intercept situations) to cause the Cessna to change course. Should the flight have continued 15 to 20 seconds longer without changing course, government spokesmen have said the order to shoot it down would have been given. Such a close encounter with our government's lethal force makes me uncomfortable, and calls into question the adequacy of the intercept procedures as they are currently written. From the information (of admittedly questionable credibility) I've seen, it appears the PIC's judgment in intentionally launching without being current to carry passengers, with a pre-9/11 chart, was notably poor. It appears to me, that he hadn't been aloft for a good length of time, and his lack of currency resulted in his flight becoming a hazard to aerial navigation and causing a disruption of governmental decorum. But I don't consider those offences to warrant a death sentence. So while this case reflects badly on GA pilots, it also points out the indiscretion of the security policy currently in place in the vicinity of our nation's capital and those who drafted it. * http://www.aopa.org/whatsnew/newsite...intercept.html |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 12:50 AM |
Conspiracy Theory’s real Script: Slave CIA, FBI change the story jews wanted to tell the media | Jean-Paul Roy | Restoration | 0 | July 12th 03 12:55 PM |
MEDIA ADVISORY ON 767A REPORT TO CONGRESS | Otis Willie | Military Aviation | 0 | July 11th 03 09:30 PM |
