ADIZ pilot's ticket revoked
Old May 27th 05, 11:59 AM
Neil Gould
Recently, Dave A. posted:
Well, quite possibly because the FAA inspector was technically wrong.
Whether you're legal VFR or not depends on the conditions at your
point in space and time, not what some weather station several miles
away might be reporting.
The question was, what is a legal briefing and where is it stated in
the regulations. If you take off in the conditions stated by George
Patternson you are technically flying illegal.
Then, why do Pireps trump briefings? Whether one is "flying illegal" is
determined by the conditions where one is flying, not the conditions
elsewhere.
The philosophizing on the subject aside, all indications given by
the FAA is that the FSS and DUATS weather and NOTAMS are your only
proof should legal proceedings take place that you followed 91.103.
This is a somewhat different matter. Should one need such proof, FSS and
DUATS may be the only sources that are not to be challenged in court.
However, if you crash at a fogged-in airport because FSS and/or DUATS
report CAVU elsewhere, good luck trying to use those reports to defend
yourself.
Neil
  #132
Old May 27th 05, 12:20 PM
Neil Gould
We are taught for the Oral exam that the only way you can prove you
took off into legal minimums for VFR flight is to obtain a weather
briefing from the FSS or DUATS.
It is only the FSS or DUATS weather report for that time that
determines if you are legally allowed to be flying based on your
restrictions, whatever they may be.
So... you depart from a non-weather reporting airport that is below
minimum, while the reporting airport is CAVU, and you think you have
"proof" that you took off into legal minimums? Think again.
Around here, there are lots of airports, most non-reporting. It is not at
all unusual for one of the reporting airports to be below minimums while
others are above, or even CAVU. When you call for a briefing under such
conditions, the briefer offers pireps if they have them, and if they
don't, they leave it up to the pilot to determine the actual conditions.
It's not unusual to arrive at the non-reporting airport to find other
planes in the pattern, and any one of those pilots and/or tower can be
valid proof in court that conditions were above minimums. Essentially,
pireps trump briefings.
Regards,
Neil
  #133
Old May 27th 05, 12:36 PM
Gary Drescher
"Dave A." wrote in message
news:hzCle.4554$Fb.1419@trndny07...
The philosophizing on the subject aside, all indications given by the FAA
is that the FSS and DUATS weather and NOTAMS are your only proof should
FSS and DUATS are the only services whose use is supposed to generate
*automatic* proof of the briefing, with no further effort on your part. But
if you get the same information elsewhere, you *may* still be able to prove
that you did so (witnesses, notes, saved or deleted data on your computer,
etc.).
--Gary
  #134
Old May 27th 05, 10:50 PM
Dave A.
Suit yourself.
Dave A
Aging Student Pilot
-I can gather all the news I need
on the weather report-
"Neil Gould" wrote in message
m...
Regards,
Neil
  #135
Old May 28th 05, 05:57 PM
Darrel Toepfer
Ron Garret wrote:
NOT an instructor. A private pilot. Now a former pilot. The student
will get to fly again simply because even if he was manipulating the
controls, the private pilot was the pilot in command.
But does he get to log the time as PIC?
And did he mail that letter to NASA within 24 hours?
  #136
Old May 28th 05, 06:41 PM
Dave S
Neil Gould wrote:
Sorry, but not much would make me happy about "only being spread-eagled at
gunpoint". There are other ways to determine that someone is unarmed, not
the least of which is that they didn't exit their Vehicle of Terror with
guns blazing.
Neil
Surely that is not the first time you've seen a "felony traffic stop" on
TV.. even if it WAS the first time you may have seen it applied to a
pilot in a plane.
The ground guys did their job, just like they were trained to. Everyone
got to go home alive that night.
Dave
  #137
Old May 28th 05, 09:22 PM
Neil Gould
Recently, Dave S posted:
spread-eagled at gunpoint". There are other ways to determine that
someone is unarmed, not the least of which is that they didn't exit
their Vehicle of Terror with guns blazing.
Neil
on TV.. even if it WAS the first time you may have seen it applied
to a pilot in a plane.
Everyone got to go home alive that night.
Suffice it to say that you are easier to please than I. I expect to go
home alive every night with one exception, and I don't expect that
exception to be at the hands of some paranoid idiot with a badge
over-reacting to what should have been a non-event. Their lack of common
sense is more worrisome than the hazard they misperceived.
Neil
  #138
Old May 29th 05, 01:33 AM
Roy Page
Neil
Neil
Neil,
You are right on the money, perfectly said and totally accurate.
Roy
N5804F - PA28-181 Piper Archer II
  #139
Old May 30th 05, 02:52 AM
George Patterson
Peter Duniho wrote:
I certainly agree that life and property was in danger. But as Larry points
out, those hazards were not of the pilot's creation.
If you fly into a war zone, the hazards are also not of your creation;
nevertheless, *you* will have placed all occupants of the plane in a hazardous
situation, and *you* are responsible.
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
Light Sport Aircraft for Private Pilots (Long) Jimbob Owning 17 March 1st 05 03:01 AM
Bush Pilots Fly-In. South Africa. Bush Air Home Built 0 May 25th 04 06:18 AM
Older Pilots and Safety Bob Johnson Soaring 5 May 21st 04 01:08 AM
UK pilots - please help by completeing a questionnaire Chris Nicholas Soaring 0 September 15th 03 01:44 PM
