I love Pacers and TriPacers. I owned one, I've spent hundreds of hours
flying them and instructing in them, and hundreds more working on them. I think they're the best entry-level airplanes Piper ever built. But I am biased. There are some major advantages to a TriPacer. It was designed so any swinging dick with a toolbox could fix it out in the field. It's VERY easy to work on, and if you plan to do much of your own work, it's a great first airplane. On the other hand, there as some major disadvantages. It needs a lot of work. If you're going to pay someone to do it all, it's not such a great deal. Also, it is cramped. Check the age AND condition of the fabric. A punch test is a must. Don't believe anyone who says he can determine the condition of the fabric without it. Can't be done. Make sure to punch the tops of the fuselage, tailfeathers, and wings. Beware the strut AD. Punch those in a few places too. (BTW - punching does not mean making a hole - it means using a Maule tester to a predefined pressure - if a hole (or, in the case of struts, a dent) is made, that means the fabric/strut is not airworthy. If you're going to upgrade to IFR, make sure it has a static system. Many of them vent to the cabin and thus can't get a pitot-static check - which means they're not legal for IFR. If it does have a static system, hook a piece of plastic hose to it, and suck gently until the altimeter reads 4000 ft or so. Then plug the hose (or bend it over) and see if the system holds pressure. If not, you're looking at expensive troubleshooting/repairs to make it IFR legal (not safe - in a TriPacer, a static leak really is a non-issue). Make sure the gyros work. On average, I find such planes generally have one of the three gyros not working. If you want an IFR installation, you need the high panel. Most of the PA-22-150's had them, but some planes people call -150's are actually earlier versions coverted to 150 hp. They have the low panel, which just doesn't have enough room unless you buy modern (expensive) slimline avionics. The O-320 is a bulletproof engine, and many run well past the 2000 hour TBO if flown regularly. Every mechanic is familiar with them, so no special issues there. Beware the muffler AD - those mufflers with more than 1000 hours on them require compliance every 50 hours. The electrical systems on these planes are 1930's tech. You will never get enough juice out of the generator to power both the IFR panel and the landing lights. The alternator mod is a good one. Any more questions - just ask. Michael |
Michael wrote:
Beware the strut AD. Punch those in a few places too. A few other ADs: Check the attach point of the fabric at the top of the windshield. The SB referenced by the AD has pictures - make sure it's done right. There are corrosion problems with the lower longerons and the bottom of the window channels - someone who knows what they are doing can tap along the lower longerons and tell what sort of shape they're in. Oh, yes: Join the Short Wing Piper Club. www.shortwing.org Other then that, I second Michael: I love my Tripacer, and I fly a reasonable amount of IFR in it. It's a great, stable IFR platform, although a bit lacking in range for alternates. Tina Marie -- http://www.tripacerdriver.com "...One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." (Robert Firth) |
Piper Pacer for sale | GASSITT | Aviation Marketplace | 0 | January 14th 04 03:20 AM |
Piper Pacer for sale | GASSITT | Aviation Marketplace | 0 | January 9th 04 01:53 PM |
Piper Pacer for sale | GASSITT | Aviation Marketplace | 4 | December 27th 03 12:42 AM |
Piper Pacer , trade $$ plus plane for R 22 | GASSITT | Rotorcraft | 0 | December 22nd 03 02:35 AM |
FS : 1953 PA22/20 Pacer conversion | John Galban | Aviation Marketplace | 0 | December 15th 03 09:04 AM |
