Re-Reading the original post on this subject made me realize
something... The plane was on approach not on a departure... If that makes a difference on the effect of loosing an engine, I do not know. I would certainly suspect it would make a difference since I would think on approach engines would be on a low power setting... On 31 May 2005 22:17:51 GMT, wrote: My understanding is that the aircraft will tend to roll due to the side with the failed engine having less lift. My CFI was explaining this to me some time ago. Engine failure would require immediate and extreme rudder input and feathering the props on the failed engine to reduce the drag. He said something about "Lawn Dart" and that it can happen in a blink of the eye. I'm a ASEL primary student. What's the skinny on multi-engine control issues when one engine fails on approach? Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com |
On 5/31/2005 6:57 PM, Mike 'Flyin'8' wrote:
Re-Reading the original post on this subject made me realize something... The plane was on approach not on a departure... If that makes a difference on the effect of loosing an engine, I do not know. I would certainly suspect it would make a difference since I would think on approach engines would be on a low power setting... I was assuming he didn't like the approach, and decided to go around ... then added full power on the remaining engine. This is assumption on my part, as I have no additional information. On 31 May 2005 22:17:51 GMT, wrote: My understanding is that the aircraft will tend to roll due to the side with the failed engine having less lift. My CFI was explaining this to me some time ago. Engine failure would require immediate and extreme rudder input and feathering the props on the failed engine to reduce the drag. He said something about "Lawn Dart" and that it can happen in a blink of the eye. I'm a ASEL primary student. What's the skinny on multi-engine control issues when one engine fails on approach? Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 02:20 AM |
How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 12:07 PM |
Flight Simulator 2004 Control Issues | SouthBayGuy | Simulators | 22 | November 26th 03 04:31 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
