![]() wrote in message oups.com... An engine loss in a Garrett powered aircraft such as the Swearingen or MU-2 would be quite noticeable at any power setting. The Negative Torque Sensor (NTS) on the Garrett TPE331's will dump oil pressure from the prop dome when the engine flames out. The spring load on the prop will drive the prop to a high pitch, lower drag configuration, but does not feather the prop. The pilot must manually perform this task. I have been told that in a MU-2 with a four bladed prop, should an engine quit and the NTS fail, a minimun turn of 90 degress will occur before the pilot gets the prop feathered. The NTS should be checked every engine start and is a no go item should it not test properly. The Searingen Metro, like th MU-2, is a handful of airplane with 2 pilots and 2 engines. One pilot and one engine? ew....... G. Lee It is not quite as bad as all that. NTS failures on takeoff are saveable at least in the simulator but immediate feathering is required. The airplane will not yaw or roll 90 deg. Mike MU-2 |
On Wed, 01 Jun 2005 15:03:52 GMT, "Mike Rapoport"
wrote: It is not quite as bad as all that. NTS failures on takeoff are saveable at least in the simulator but immediate feathering is required. The airplane will not yaw or roll 90 deg. Mike MU-2 Speaking of difficult to handle twins. In 1939, the Martin Co. responded to a request for a high speed medium twin engined bomber with a submission that was named the "Marauder" and designated the 26th such commissioned design, or B-26. Martin assigned a young aerodynamics engineer to the task of designing the airplane. The specifications called for a top speed of 300 mph or better, but DID NOT specify a landing speed. The designer responded by installing the two biggest engines in production at the time, the Pratt and Whitney R-2800, coupled with an enormous four bladed Curtiss electric prop, and giving the B-26 very short wings which gave it the top speed he wanted, at the expense of a landing speed that topped 130 mph. There was never a prototype, the Army needed the bomber and flight testing was conducted with the first production models. A series of circumstances and misfortunes dogged the Marauder crews during it's workup and training, causing so many accidents (almost exclusively on takeoff and landing) that it was investigated 4 times by Congress. The initial problems were the result of assigning pilots to train in the B-26, most of whom had not flown twins. Those who had trained for twins, flew the "Bamboo Bomber" a small Cessna twin with a cruise speed slower than the B-26 stalled. To say that they were intimidated is an understatement. The inexperienced pilots had many difficulties landing the Marauder. Then there were the operational problems: The training command switched fuels and the new 100 octane aeromatic fuel disintegrated the diaphrams in the carburators. The ground crews were unfamiliar with the engine and the prop and maintenance was minimal or improperly conducted. The result was a near total disaster as the training crews suffered numerous engine failures during takeoff, or the prop went into flat pitch, also during takeoff. Many of the training flights involved takeoff at max gross. At that weight during takeoff, the loss of an engine or having the prop slip to flat pitch was disasterous. The bomber rolled into the dead engine virtually instantaneously and pitched into Tampa Bay, or impacted the ground upside down. "One a day in Tampa Bay" became the bitter refrain. Experienced combat crews did not have the problem the green training crews had though, they liked the airplane. The Army decided it needed the airplane for the war effort and sent it to Europe (as well as to the South Pacific Theater). By the time it was headed for England, the training accidents had been reduced greatly due to better understanding of the airplane and better training. I have a video at home about the B-26. In it a veteran instructor was interviewed and he spoke of being sent to Tampa to investigate the very high accident rate. He arrived, spoke with the commanding officer and requested their very best B-26 pilot trainee. They took off and climbed to 8,000 feet (I think, could have been 12,000) where the instructor told the pilot to configure the bomber as if he were taking off. So the pilot slowed down, dropped flaps and gear, pitched up and advanced power to takeoff settings. At that point the instructor told the pilot he was going to chop power to one of the engines, and told him which engine it would be. Then he cut the power. The bomber flipped over inverted and immediately went into a spin. The instructor waited a bit while the pilot struggled to get out of the spin, then announced that they were in a standard inverted spin and proceeded to recover. By the time they pulled out they had lost many thousands of feet of altitude. Martin eventually relented it's stance in regards the wing and made the follow up models with much larger wings and tail surfaces. In the event, the Marauder had an almost charmed combat career, suffering one of, if not the, lowest rates of combat lost of any bomber. The reason for this was due less to the robust construction of the bomber or it's flight characteristics than to the Luftwaffe's orders to concentrate on the heavy bombers at the expense of all other operations. When the heavies were up, it was usually because the weather favored visual bombing. That being the case, all other bombers were usually also flying missions. The Luftwaffe did not have the numbers to respond to each and every type of enemy incursion, so they concentrated on the heavies. So the Marauders kind of drew a bye when they flew on bombing missions. They even got lucky with the AA artillery because most of it was removed from the fronts to surround the cities in defense against the heavy bomber attacks. But the missions were not a piece of cake as any B-26 combat veteran can tell you, there was plenty enough AAA still around to make missions harrowing. Corky Scott |
"Corky Scott" wrote in message
... On Wed, 01 Jun 2005 15:03:52 GMT, "Mike Rapoport" wrote: Snip Great History Lesson I have a video at home about the B-26. In it a veteran instructor was interviewed and he spoke of being sent to Tampa to investigate the very high accident rate. He arrived, spoke with the commanding officer and requested their very best B-26 pilot trainee. They took off and climbed to 8,000 feet (I think, could have been 12,000) where the instructor told the pilot to configure the bomber as if he were taking off. So the pilot slowed down, dropped flaps and gear, pitched up and advanced power to takeoff settings. At that point the instructor told the pilot he was going to chop power to one of the engines, and told him which engine it would be. Then he cut the power. Snip More Great History Lesson Corky, IIRC, the "instructor" they sent down was Jimmie Doolittle, was it not? Jay B |
On Wed, 1 Jun 2005 11:59:45 -0700, "Jay Beckman"
wrote: IIRC, the "instructor" they sent down was Jimmie Doolittle, was it not? Doolittle was put in charge of demonstrating the airplane to prove that it could be flown safely, but he wasn't the guy who did most of the flying. According to my information:" General Doolittle sent his technical adviser, Captain Vincent W. "Squeak" Burnett" to do the demo flying. I watched in the video as he (I assume it was he) brought in a B-26 on one engine. The final approach was incredibly steep, and the pilot pulled the nose up at the last second and greased it on. From what I could see, this was a do or die type of landing (given the approach speed): pull up too late and the landing gear is history (given the rate of descent I saw), pull up too early and the airplane would instantly stall to the runway wiping out the gear again. Corky Scott |
There is no doubt that many military aircraft have narrow envelopes and
require extreme precision to fly. The same is not true of certified civilian airplanes and thankfully so. Mike MU-2 "Corky Scott" wrote in message ... On Wed, 01 Jun 2005 15:03:52 GMT, "Mike Rapoport" wrote: It is not quite as bad as all that. NTS failures on takeoff are saveable at least in the simulator but immediate feathering is required. The airplane will not yaw or roll 90 deg. Mike MU-2 Speaking of difficult to handle twins. In 1939, the Martin Co. responded to a request for a high speed medium twin engined bomber with a submission that was named the "Marauder" and designated the 26th such commissioned design, or B-26. Martin assigned a young aerodynamics engineer to the task of designing the airplane. The specifications called for a top speed of 300 mph or better, but DID NOT specify a landing speed. The designer responded by installing the two biggest engines in production at the time, the Pratt and Whitney R-2800, coupled with an enormous four bladed Curtiss electric prop, and giving the B-26 very short wings which gave it the top speed he wanted, at the expense of a landing speed that topped 130 mph. There was never a prototype, the Army needed the bomber and flight testing was conducted with the first production models. A series of circumstances and misfortunes dogged the Marauder crews during it's workup and training, causing so many accidents (almost exclusively on takeoff and landing) that it was investigated 4 times by Congress. The initial problems were the result of assigning pilots to train in the B-26, most of whom had not flown twins. Those who had trained for twins, flew the "Bamboo Bomber" a small Cessna twin with a cruise speed slower than the B-26 stalled. To say that they were intimidated is an understatement. The inexperienced pilots had many difficulties landing the Marauder. Then there were the operational problems: The training command switched fuels and the new 100 octane aeromatic fuel disintegrated the diaphrams in the carburators. The ground crews were unfamiliar with the engine and the prop and maintenance was minimal or improperly conducted. The result was a near total disaster as the training crews suffered numerous engine failures during takeoff, or the prop went into flat pitch, also during takeoff. Many of the training flights involved takeoff at max gross. At that weight during takeoff, the loss of an engine or having the prop slip to flat pitch was disasterous. The bomber rolled into the dead engine virtually instantaneously and pitched into Tampa Bay, or impacted the ground upside down. "One a day in Tampa Bay" became the bitter refrain. Experienced combat crews did not have the problem the green training crews had though, they liked the airplane. The Army decided it needed the airplane for the war effort and sent it to Europe (as well as to the South Pacific Theater). By the time it was headed for England, the training accidents had been reduced greatly due to better understanding of the airplane and better training. I have a video at home about the B-26. In it a veteran instructor was interviewed and he spoke of being sent to Tampa to investigate the very high accident rate. He arrived, spoke with the commanding officer and requested their very best B-26 pilot trainee. They took off and climbed to 8,000 feet (I think, could have been 12,000) where the instructor told the pilot to configure the bomber as if he were taking off. So the pilot slowed down, dropped flaps and gear, pitched up and advanced power to takeoff settings. At that point the instructor told the pilot he was going to chop power to one of the engines, and told him which engine it would be. Then he cut the power. The bomber flipped over inverted and immediately went into a spin. The instructor waited a bit while the pilot struggled to get out of the spin, then announced that they were in a standard inverted spin and proceeded to recover. By the time they pulled out they had lost many thousands of feet of altitude. Martin eventually relented it's stance in regards the wing and made the follow up models with much larger wings and tail surfaces. In the event, the Marauder had an almost charmed combat career, suffering one of, if not the, lowest rates of combat lost of any bomber. The reason for this was due less to the robust construction of the bomber or it's flight characteristics than to the Luftwaffe's orders to concentrate on the heavy bombers at the expense of all other operations. When the heavies were up, it was usually because the weather favored visual bombing. That being the case, all other bombers were usually also flying missions. The Luftwaffe did not have the numbers to respond to each and every type of enemy incursion, so they concentrated on the heavies. So the Marauders kind of drew a bye when they flew on bombing missions. They even got lucky with the AA artillery because most of it was removed from the fronts to surround the cities in defense against the heavy bomber attacks. But the missions were not a piece of cake as any B-26 combat veteran can tell you, there was plenty enough AAA still around to make missions harrowing. Corky Scott |
![]() "Corky Scott" wrote in message ... Speaking of difficult to handle twins. In 1939, the Martin Co. responded to a request for a high speed medium twin engined bomber with a submission that was named the "Marauder" and designated the 26th such commissioned design, or B-26. Martin assigned a young aerodynamics engineer to the task of designing the airplane. The same guy (Ted Smith ?) who designed the Rockwell/AeroCommander series, now called the Twin Commander. |
On Wed, 1 Jun 2005 18:26:50 -0700, "Matt Barrow"
wrote: The same guy (Ted Smith ?) who designed the Rockwell/AeroCommander series, now called the Twin Commander. Don't know about Ted Smith, the information I have, which was compiled by Joseph Baugher and posted to the internet years ago is as follows: Requests for proposals were widely circulated throughout the industry. Proposals were received from Martin, Douglas, Stearman, and North American. The proposal of the Glenn L. Martin company of Middle River, Maryland (near Baltimore) was assigned the company designation of Model 179. Martin assigned 26-year old aeronautical engineer Peyton M. Magruder as Project Engineer for the Model 179. Magruder and his team chose a low-drag profile fuselage with a circular cross section. Since the Army wanted a high maximum speed but hadn't specified any limitation on landing speed, the team selected a high-mounted wing with a wingspan of only 65 feet. Its small area gave a wing loading of more than 50 pounds per square foot. The wing was shoulder-mounted to leave the central fuselage free for bomb stowage. The wings were unusual in possessing no fillets. The engines were to be a pair of 1850 hp Pratt & Whitney R-2800-5 Double Wasp air-cooled radials, which were the most powerful engines available at the time. Two-speed mechanical superchargers were installed in order to maintain engine power up to medium altitudes, and ejector exhausts vented on each side of the closely-cowled nacelles. The engines drove four-bladed 13 foot 6 inch Curtiss Electric propellers. Large spinners were fitted to the propellers, and root cuffs were added to aid in engine cooling. I archived a number of his aircraft development histories, they are comprehensive and dry, tending to the technical side with long lists of serial numbers for respective models and where each was deployed. Corky Scott |
![]() "Corky Scott" wrote in message ... On Wed, 1 Jun 2005 18:26:50 -0700, "Matt Barrow" wrote: The same guy (Ted Smith ?) who designed the Rockwell/AeroCommander series, now called the Twin Commander. Don't know about Ted Smith, the information I have, which was compiled by Joseph Baugher and posted to the internet years ago is as follows: http://www.twincommander.com/aero_design.htm The story of the man begins with Ted Smith, and the dream starts when, as project engineer at the Douglas Aircraft Company during the Second World War, Smith envisioned the day when peace would come and the airplane would fill its promise of usefulness to man as a transportation vehicle. The airlines had already developed a growing network of schedules and yet the air transport system, as it was and as it showed signs of developing, did not provide for the many needs of business and individual travelers whose requirements placed a premium on going between origin and destination (frequently not on the airline map) and doing so with all the convenience, flexibility and time saving that only a privately owned aircraft could accomplish. At the same time, comfort, dependability, and safety must be the ultimate that the aviation industry could achieve. |
("Matt Barrow" wrote)
http://www.twincommander.com/aero_design.htm The story of the man begins with Ted Smith, and the dream starts when, as project engineer at the Douglas Aircraft Company during the Second World War, Smith envisioned the day when peace would come and the airplane would fill its promise of usefulness to man as a transportation vehicle. (Posted this last week in another thread) OT - Speaking of Aero Commanders, I saw the Pella Windows corporate jet a few weeks ago at the Pella, Iowa airport open house. Talked with the crew. It's an Aero Commander jet. Israeli company converts them - see link. http://tinyurl.com/a7duk Israel IAI-1124A Westwind Montblack |
![]() "Montblack" wrote OT - Speaking of Aero Commanders, I saw the Pella Windows corporate jet a few weeks ago at the Pella, Iowa airport open house. Talked with the crew. It's an Aero Commander jet. Israeli company converts them - see link. That may be the strangest conversion I have ever seen! But I like it! I sure do wonder how they got the CG in the right place. Do you think they moved the wing back? -- Jim in NC |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 02:20 AM |
How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 12:07 PM |
Flight Simulator 2004 Control Issues | SouthBayGuy | Simulators | 22 | November 26th 03 04:31 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
