"Bill" wrote in message
m... I was told by a co-worker that a new Part 91-mandatory compliance reg has come out, requiring all airplanes to meet a min. climb gradient of 2.5% for second stage climb gradient, unless published otherwise. Sure doesn't sound like anything that would show up in Part 91. There's basically nothing in Part 91 that requires an airplane to be able to climb at all. I assume that you don't really mean this applies for all flights, and that this is some sort of commercial/IFR departure procedure thing? Pete |
"Peter Duniho" wrote in message ...
"Bill" wrote in message m... I was told by a co-worker that a new Part 91-mandatory compliance reg has come out, requiring all airplanes to meet a min. climb gradient of 2.5% for second stage climb gradient, unless published otherwise. Sure doesn't sound like anything that would show up in Part 91. There's basically nothing in Part 91 that requires an airplane to be able to climb at all. I assume that you don't really mean this applies for all flights, and that this is some sort of commercial/IFR departure procedure thing? Today its 200 feet per nm for GA. |
om... Today its 200 feet per nm for GA. There is no requirement for all airplanes to meet a 200 feet per NM gradient, or any other climb capability. Perhaps you, like the original poster, intended to restrict your statement to IFR departures where no other climb requirement has been published? |
![]() Peter Duniho wrote: I assume that you don't really mean this applies for all flights, and that this is some sort of commercial/IFR departure procedure thing? Pete It has been true for years that anyone who accepts (commercial or just Part 91) SID with a climb gradient (now called ATC DP) accepts as part of the clearance the assurance that the climb gradient will be met. What Part 91-only has not been legally responsible for is any climb gradient on an obstacle DP that is not assigned by ATC (formerly IFR departure procedure). Having said that, there was a najor NPRM circulated early this year that updated RNAV stuff, etc, and also proposed to make the use of obstacle DPs mandatory for IFR departures unless ATC assigns an ATC DP. If adopted as proposed, this would apply to all IFR operations. |
[...] If adopted as proposed, this would apply to all IFR operations. In other words, NOT all flights. Just the IFR ones. Which is what I suggested was the case. |
![]() In other words, NOT all flights. Just the IFR ones. Which is what I suggested was the case. In view of the title of this news group I assumed that was the context of the original posting since VFR aircraft and IFR DPs have nothing to do with each other, just as Part 25 takeoff flight paths have nothing to do with Part 23 aircraft. |
Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 03:48 PM |
Rate of climb | Dillon Pyron | Home Built | 3 | May 8th 04 01:08 PM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
