Auto. engine >> vertical shaft power output
Old May 31st 05, 11:00 PM
Default Auto. engine >> vertical shaft power output
Anybody know of a bolt on device to get a vertical shaft output from a
100+ HP auto. engine? No transmission.
Current options:
1. A RWD car with IRS. Turn IRS 90 degrees and block one IRS output
shaft from turning.
Problem: Transmission weight and "crude" design.
2. Shaft drive motorcycle - turn the rear wheel axel shaft 90 degrees
to give a vertical shaft power output.
Old June 1st 05, 01:08 PM
Vaughn Simon
Current options:
shaft from turning.
3) Modify an auto engine to use a dry oil sump, run with crank
vertical.
4) Use an engine from a large outboard motor.
Old June 1st 05, 08:41 PM
Sla#s
"The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in
message ...
On 31 May 2005 15:00:27 -0700, "
SNIP
I'd opt for option 2. There are many shaft driven bikes that have
100+ HP engines. My concern would be the torque more than anything.
I certainly woulnd' tuse the shaft drive unit off a cycle for anything
that flew - especially with me in it..
Use the Hughes option. Use a separate tube and bearing assy to do the
lifting and the drive shaft is only for power delivery.
Slatts
Old June 2nd 05, 01:13 PM
Steve R.
"Vaughn Simon" wrote in message
Didn't B.J. Schramm try that in his early Rotorway designs? Wasn't too
successful from what I remember reading about. Of course, they do have the
modern 4-stroke outboards around these days. Might do better?
Fly Safe,
Steve R.
Old June 2nd 05, 07:16 PM
Steve R.
message ...
On Thu, 02 Jun 2005 12:13:19 GMT, "Steve R."
Speaking of B.J.....
What's going on with Helicycle since his death??
The web site is still active, www.helicycle.com.
I looked at it the other day. They seem to be doing Ok if you can believe
all the photo's of flying Helicycle's they've got posted.
I was privileged to meet B.J. on several occasions, not the least of which
was at the PRA Fun-Fly after he'd flown though the power lines during a demo
flight. I found him to be a very personable individual and a pleasure to
talk to. He will be missed.
Fly Safe,
Steve R.
Are you gliding when you touch down? John Doe Piloting 29 January 23rd 05 12:52 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
