Who does flight plans?
Old June 3rd 05, 01:09 PM
Doug Vetter
Michael 182 wrote:
I'm kind of curious - does anyone with more than 100 hours do a flight plan,
with winds and all, before they fly cross country? Most of my planning is of
the fuel stop, or occasionally detour for weather variety - but it is rare
for me to include more than one or two waypoints in my "plan", and I almost
never file an airway, even when I file ifr. Maybe it's because I live in the
west. A typical flight plan will be Longmont - Amarillo - Austin, or if the
winds are good, Longmont - Austin. What do others do?
Michael
I used to calculate everything manually, and took pride in interpolating
wind / temperature data, and tweaking my climb and descent profiles to
get the total time enroute accurate to a minute or two. That became
boring, so I then concentrated on improving the speed with which I did
all the calculations.
Then my time became money, and I realized that doing it manually no
longer served any purpose (there's only so much you can learn from a
whiz-wheel, or calculating these things manually...particularly after a
few zillion times). Now I let the computers do it and I find that given
the right data, they're accurate to within 1 minute. I don't dig holes
with shovels anymore.
FYI, if you want to plan / file direct VFR, fine. But don't try that
IFR -- particularly in the northeast. It irritates the controllers, and
no surprise. The AIM specifies that you should file airways (sorry I
don't have the exact reference handy...but just read Don Brown's columns
on Avweb for more info). The entire ATC system (airspace boundaries,
etc.) are based on the airway system, and when you file direct, you
increase controller workload. Given the shortage of controllers, that's
just about the last thing you should do.
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
Old June 3rd 05, 03:15 PM
Maule Driver
I would say that is increasingly a NE issue. In the SE boonies (south
of the Wash ADIZ), once they see /G, they tend to clear you direct
*independent* of your plan. In FL my experience is that you will be
initially cleared on airways then either thru request or offer, you can
get direct for many portions. Leave the busier FL airspace and it's
"cleared direct destination". I guess it's fewer words to say or
something. Amazing!
-Doug
Old June 4th 05, 04:10 AM
Doug Vetter
something. Amazing!
It probably has more to do with traffic count per square mile (and
therefore workload), which is almost always lower in places other than
the northeast. Getting direct may also have something to do with getting
lucky, no matter where you fly.
Don Brown indicates that one of the chief reasons they hate pilots who
file direct (even out in the boonies where radio calls are made every
100 miles) is that if a direct courseline quickly crosses or nears
several sector boundaries (which can happen in both the horizontal or
vertical planes), they have to do tons of point outs and (lacking
successful communication with the neighboring controllers) radar
vectors, reroutes, and other hand-holding that would not have been
necessary had the pilot filed airways and avoided those trouble-spots in
the first place.
That said, on my way down the coast from New Jersey to Florida a couple
weeks ago, I was about 10 miles south of my second departure point
(Newport News, VA) when I was cleared to my destination (N. Myrtle
Beach, Grand Strand) 225NM out -- a personal direct-to distance record
under IFR. Of course, V1 is almost a straight line between the two
airports and more or less equivalent to a direct-to route (thus I was
getting lucky) but in general I agree with you that you are certainly
more likely to get direct in places OTHER than the northeast.
-Doug
Old June 5th 05, 01:41 AM
Maule Driver
Maybe ATC in the SE Atlantic seaboard have somehow 'broken the code' on
handling direct. I swear that your experience with direct to N Myrtle
is becoming the norm rather than the exception. Between the Wash ADIZ
and Jacksonville I've been filing airways and getting cleared direct
without requesting it. And I'm filing the airways to avoid SUAs that
clog the airspace. The interesting part is that for someone like me
flying at 9 or below, flights typically involve center and multiple
approaches with constant switching. And yet I'm getting cleared direct
3 or 4 handoffs out from my destination. Who knows, it may be
particular to the routes.
I don't know who Doug Brown is but I'm going to continue to be pretty
aggressive in filing and/or requesting direct where I consider it a
reasonable request. And I expect to get it more often than not outside
of those areas where it just isn't doable (ADIZ, Phille/NY corridor, FL
ooastal routes). It's working better than one might expect in my
experience. I'll have to get out more....
can get direct for many portions. Leave the busier FL airspace and
it's "cleared direct destination". I guess it's fewer words to say or
something. Amazing!
the first place.
-Doug
Old June 5th 05, 04:38 PM
Newps
the first place.
This is a typical FAA attitude that is very difficult to overcome.
Don't do something that is convenient to you because I then have to work
too hard. Or change what I have been doing for the last 50 years. Busy
airspace is one thing but to say they hate pilots filing direct because
that line nicks other sectors and airspaces is assinine.
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
WINGS: When do the clocks start ticking? Andrew Gideon Piloting 6 February 3rd 04 03:01 PM
Flight instructors as Charter Pilots C J Campbell Piloting 6 January 24th 04 07:51 AM
