Procedure turn required?
Old June 4th 05, 07:13 PM
Peter Duniho
wrote in message ...
The reason the course reversal is required in the cited case at KFUL is
because
going straight in from V-64 requires a course change entering the final
approach
segment that well exceeds the maximum course change at the FAF of 30
degrees
permitted for VOR IAPs.
A procedure turn requires a course change of over 130 degrees (including
getting back onto the outbound course). And then of 180 degrees. You can
fly the transition at the same altitude allowed for the procedure turn.
How is the procedure turn better?
Like it or not that is the criteria. Keep in mind that TERPs is
simplistic
criteria in the sense that it tries to make one size fit all in most
aspects of
IAP construction.
Well, I can agree with that.
From a practical point of view, however...
It seems likely that when radar coverage is available, vectors will be
given. This allows no procedure turn to be flown. If radar coverage is not
available, how is anyone going to know if you've flown the procedure turn?
I would think that from an enforcement point of view, the cases where a
procedure turn is theoretically required, but where the pilot could ever be
cited for not flying one, are pretty far and few between. From a safety
point of view, not flying the procedure turn appears to be the superior
approach, at least in this case.
Pete
Old June 4th 05, 11:13 PM
Peter Clark
On Sat, 4 Jun 2005 11:13:47 -0700, "Peter Duniho"
Anyone who listens to the tapes, assuming radio coverage? At least
around here whenever I'm flying a full procedure ATC always requests
"report procedure turn inbound".
Old June 8th 05, 11:52 PM
Jose
All the maneuvering is done prior to the FAF, and prior to descent.
Jose
The price of freedom is... well... freedom.
Old June 9th 05, 12:47 AM
Peter Duniho
"Jose" wrote in message
. com...
Offset by the significant increase in the amount and difficulty of
maneuvering required. I agree you've shown it to be different. I don't see
how it's better.
Pete
Old June 9th 05, 01:11 AM
Jose
how it's better.
It's better because it's safer. There is no real increased difficulty -
one standard rate turn is like another, and making a longer turn is no
harder (unless you fall asleep during the turn, then the landing is much
harder!).
When you make the turns used for the full procedure, you end up right
where you are supposed to be. But if you make a turn to final that
takes fifty degrees, you will =not= be on the FAC. You'll have lagged,
and have to squirrel yourself back to be on course. You're also
approaching the MAP and descending.
This is harder.
Or you can anticipate the turn. How much? Well, (fudge fudge fudge)...
This is harder.
Maybe not harder enough to be =unsafe=, but harder enough that, combined
with proximity (to the ground and the airport) it is less safe.
Jose
Old June 9th 05, 01:26 AM
Peter Duniho
om...
You have not demonstrated that. To demonstrate an improvement in safety,
you need to compare a statistically significant number of samples using both
methods, and then look at the resulting accident rates for each method.
You certainly can't claim that it's "obviously safer". That is, it's not
true that "one standard rate turn is like another". Any maneuvering runs
the risk of causing an accident, and the more time spent maneuvering, the
greater the exposure to that risk (this is no different from saying "any
flight runs the risk of causing an accident, and the more time spent flying,
the greater the exposure to that risk").
As far as the difference in difficulty, one can debate that as well.
Inasmuch as a pilot ought to be maintaining a mental picture of his position
while flying by instruments, an extended turn away from one's destination
certainly could be more difficult than a prompt turn toward one's
destination. Furthermore, the right-310 turn is just one option of many,
and several of the other options involve multiple turns in multiple
directions. Increased complexity implies increased difficulty IMHO.
Whether this increase in complexity offsets the potential increase in
complexity of turning directly 50 degrees onto the final approach course,
has not been established. I suggest it does, you suggest it doesn't, and
neither of us has any justification for making such statements, other than
our own intuition.
You might be, if you do it right. There's no guarantee though. Even if
done properly, you are still "allowed" a significant margin of error.
But if you make a turn to final that takes fifty degrees, you will =not=
be on the FAC.
If you simply intercept the approach course, how would you not wind up on
the approach course?
You'll have lagged, and have to squirrel yourself back to be on course.
You're also approaching the MAP and descending.
This is harder.
It is different. I see it as being FAR from a foregone conclusion that it
is harder.
This is harder.
Well, we're back to that. You haven't demonstrated "less safe". You simply
asserted it. There's a difference.
Pete
Old June 9th 05, 01:58 AM
Jose
You have not demonstrated that [it's safer]. To demonstrate an improvement in safety,
I'm not going to do that. Neither are you going to do the same for your
contention that it's best to simply turn final, irrespective of what the
regulations (including the opinion of FAA legal council) state.
So we are back to using reasoning to infer safety from (personal and
shared) experience.
True. However, turns happen all the time. I'm not convinced that a
standard rate turn is so risky that an extra hundred degrees or two
makes a significant difference, all other things being equal.
That said, all other things are =not= equal. "My" turns are done at
altitude, flying towards protected airspace, in an area that has been
certified for such turns. "Your" turns are done flying towards the
final approach fix, at the commencement of a descent, off from the final
approach course, and in an area that has been proscribed by the FAA for
such turns (which means in this case that the terrain and airspace has
not been checked and approved for these turns).
It is those conditions that I contend make "your" turns less safe.
destination.
I'm not sure I follow this reasoning, and I don't agree with what I
think you mean. A pilot who's on top of things should have no problem
with either turn (in terms of situational awareness) and one that's a
little behind could use the extra time flying away and then back,
establishing themselves on the FAC long before the FAF.
our own intuition.
Well, we have our own flight experience, and I assume that much of it is
similar.
This paraphrases as "if you succeed, how could you have failed"? A
course interception involves some S-turning or anticipation, iow some
slop. The shallower the intercept, the less slop. Intercepting the FAC
at low altitude is a critical enough maneuver that slop should be
minimized. You need to be dead on. (fsvo "dead" However, turning
away from the FAC and =not= descending would allow slop to be safer.
The FAA has chosen 30 degrees as the amount of turn which balances slop
one way with slop the other way. I don't know whether the number
"should" be 30 degrees, 50 degrees, or 10 degrees, but I suspect the
TERPS designers have some data to back themselves up, and I'll trust
their design.
I have asserted it and given my reasoning. Reasoning isn't proof, and
isn't intended to be.
Jose
Procedure turn required? Yossarian Piloting 85 July 6th 05 08:12 PM
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 11 April 20th 04 02:17 AM
