Anyone know a good way to make a belly baggage pod?
Old June 5th 05, 04:11 AM
Charlie
Pete Schaefer wrote:
http://www.eaa1000.av.org/pix/rvpods.jpg
What Pete didn't mention is the minimal (possibly even positive) effect
on the gross weight capability of the wing due to using 2 wing mounted
pods instead of a single belly mounted pod.
Old June 5th 05, 07:00 AM
Pete Schaefer
There's a lot I didn't mention. Like...getting the pods out of prop wash is
a good idea. Like, putting a pod on centerline increases back-end flow
separation (especially if it's designed to produce lift) and hence total
drag. Also, a shape other than the old bomb could be destabilizing in roll
(a positive increment to Cpbeta....could cause you problems in cross-wind
landings...). I could go on and on. But, in the end, the two wing-mounted
pods just look a lot cooler, so why bother with a centerline pod.
Pete
"Charlie" wrote in message
Would the AH-6J (Little Bird make a good, low cost, helicopter for force protection? John Hairell Military Aviation 1 May 17th 04 04:21 PM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 08:52 PM
