On Sun, 5 Jun 2005 16:47:49 -0700, "Peter Duniho"
wrote: As far as I know, that's to distinguish from those procedure turns that require a particular kind of turn, versus those that simply require the pilot to remain on the "protected" side of the turn. It has nothing at all to do with whether one is supposed to fly the depicted outbound course. I don't know where you find a requirement that one must fly for any distance at all outbound along the "depicted outbound course" in executing a procedure turn that does not have a required track. You cite 97.3 but that paragraph also states that "the point at which the turn may be commenced, and the type and rate of turn, is left to the discretion of the pilot". Some of the types of turns that would not require flying along the charted outbound track include teardrop, racetrack and 80-260. Even the 45° turn would not require flying along the "depicted outbound course" if the pilot elected to start that turn immediately. At the approach under discussion (KFUL VOR-A via the WILMA transition), I would probably elect to fly a racetrack turn after Seal Beach and, depending on the winds, I might never even be parallel to the charted inbound course of 020 until I turned inbound. All perfectly legal according to both 97.3 and the AIM. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
"Ron Rosenfeld" wrote in message
... I don't know where you find a requirement that one must fly for any distance at all outbound along the "depicted outbound course" in executing a procedure turn that does not have a required track. Asked and answered. You cite 97.3 but that paragraph also states that "the point at which the turn may be commenced, and the type and rate of turn, is left to the discretion of the pilot". Unless by "turn" they are referring to the final course reversal, that sentence IMHO basically makes this entire thread moot. That is, it answers the question, and leaves the entire procedure up to the discretion of the pilot. Now, that's a fine interpretation by me. ![]() those arguing that the entire procedure is required to be flown (absent the explicitly stated exceptions, of course) feel that the sentence you quote is referring only to the final course reversal, not the entire procedure turn. Some of the types of turns that would not require flying along the charted outbound track include teardrop, racetrack and 80-260. Even the 45° turn would not require flying along the "depicted outbound course" if the pilot elected to start that turn immediately. All of your examples are ways to complete the course reversal *after flying the outbound leg*. That is, if those are all valid methods for executing the entire procedure turn itself, then surely so too is simply turning onto the final approach course. So, either you are simply supporting my point, or your examples are in no way a counter-example to what I've written. At the approach under discussion (KFUL VOR-A via the WILMA transition), I would probably elect to fly a racetrack turn after Seal Beach and, depending on the winds, I might never even be parallel to the charted inbound course of 020 until I turned inbound. All perfectly legal according to both 97.3 and the AIM. If you have the discretion to choose your outbound track, why bother flying outbound at all? Pete |
On Sun, 5 Jun 2005 21:54:12 -0700, "Peter Duniho"
wrote: If you have the discretion to choose your outbound track, why bother flying outbound at all? You are skipping over the part of the regulation which states that the "point at which the turn may be commenced" is up to the pilot. There is no MINIMUM length of an outbound leg. There is only a maximum length. You can begin your turn (or course reversal if you will), immediately. But if you do not see that, then further discussion here is pointless. There is certainly nothing wrong with returning to the outbound course after Seal Beach, flying outbound for some length that you determine you want to; and then executing a 45° turn on the charted side, so long as you remain within the mileage limit. But it is not the only valid, legal method of executing the procedure. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
... You are skipping over the part of the regulation which states that the "point at which the turn may be commenced" is up to the pilot. No, I'm not skipping that at all. I'm simply pointing out that if the pilot is permitted to degenerate the entire thing down to just the reversal itself, how is it that logic doesn't also show that the pilot can degenerate the entire thing down to the final turn to the final approach course? After all, ALL of the elements of the "reversal" are at the pilot's discretion. A 90 degree left turn is "the same" as a 270 degree right turn. If a 270 degree right turn is allowed, then a 90 degree left turn is too. There is no MINIMUM length of an outbound leg. And no specific direction of the turn. There is only a maximum length. Depending on where you start the turn, correct. You can begin your turn (or course reversal if you will), immediately. And the type of turn is entirely at the pilot's discretion. So rather than flying a 270 degree right turn, the pilot can choose a 90 degree left turn. But if you do not see that, then further discussion here is pointless. Ahh, yes...the old "terminate the thread with an ad hominem" tactic. There is certainly nothing wrong with returning to the outbound course after Seal Beach, flying outbound for some length that you determine you want to; and then executing a 45° turn on the charted side, so long as you remain within the mileage limit. But it is not the only valid, legal method of executing the procedure. I never said it was. Pete |
"point at which the turn may be commenced" is up to the pilot. No, I'm not skipping that at all. I'm simply pointing out that if the pilot is permitted to degenerate the entire thing down to just the reversal itself, how is it that logic doesn't also show that the pilot can degenerate the entire thing down to the final turn to the final approach course? After all, ALL of the elements of the "reversal" are at the pilot's discretion. A 90 degree left turn is "the same" as a 270 degree right turn. If a 270 degree right turn is allowed, then a 90 degree left turn is too. The difference between the 90 degree left turn and all of the variations of the procedure turn (even with a zero-length outbound leg) is that all those variations have you *established* on the final approach course *prior* to reaching the FAF. In this sense the 90 degree left turn is not equal to the 270 right turn. To me this seems the conceptual basis for the fact that the regs require the procedure turn when it often doesn't "seem" that it should be necessary. Now if you happen to be coming from a direction where you *are* already aligned on the final approach course and at the proper altitude prior to reaching the FAF, I would agree that it doesn't make sense to do the PT (though it may still be technically required by the regs). The basis *I* use for skipping the turn in this case is: 1) I am flying a hold-in-lieu-of-procedure turn, plus 2) I am established in the hold by virtue of being established (+/- 10 degrees) on the inbound course prior to reaching the holding point (the FAF). Ok, its a stretch, but that's how I look at it! Cheers, John Clonts Temple, Texas |
On Mon, 6 Jun 2005 10:40:11 -0700, "Peter Duniho"
wrote: "Ron Rosenfeld" wrote in message .. . You are skipping over the part of the regulation which states that the "point at which the turn may be commenced" is up to the pilot. No, I'm not skipping that at all. I'm simply pointing out that if the pilot is permitted to degenerate the entire thing down to just the reversal itself, how is it that logic doesn't also show that the pilot can degenerate the entire thing down to the final turn to the final approach course? I don't understand what you are trying to say. I don't see it as degeneration to be following the clearly stated rule that it is pilots choice for the type of turn and where to start it. After all, ALL of the elements of the "reversal" are at the pilot's discretion. A 90 degree left turn is "the same" as a 270 degree right turn. If a 270 degree right turn is allowed, then a 90 degree left turn is too. Again, I don't see any similarity (assuming we are talking about the same approach as started this thread) between a 90° left turn at Seal Beach and a 270° right turn. So I would disagree with your conclusion that they are the same. There is no MINIMUM length of an outbound leg. And no specific direction of the turn. That's right; after turning outbound, you can go clockwise or counter clockwise. There is only a maximum length. Depending on where you start the turn, correct. You can begin your turn (or course reversal if you will), immediately. And the type of turn is entirely at the pilot's discretion. So rather than flying a 270 degree right turn, the pilot can choose a 90 degree left turn. But if you do not see that, then further discussion here is pointless. Ahh, yes...the old "terminate the thread with an ad hominem" tactic. Sorry, I did not mean a personal attack. My statement stems from a realization that nothing I write here is going to convince you that there is no requirement to return to and fly over the depicted outbound track of a procedure turn (unless it's one of those fly as charted types); and nothing you write will convince me that there is such a requirement. There is certainly nothing wrong with returning to the outbound course after Seal Beach, flying outbound for some length that you determine you want to; and then executing a 45° turn on the charted side, so long as you remain within the mileage limit. But it is not the only valid, legal method of executing the procedure. I never said it was. Well, you seem to be insisting that it is required to fly along the charted outbound course for some length of time. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Procedure turn required? | Yossarian | Piloting | 85 | July 6th 05 08:12 PM |
Sports class tasking | [email protected] | Soaring | 12 | April 25th 05 01:32 PM |
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! | copertopkiller | Military Aviation | 11 | April 20th 04 02:17 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
