OSH for the uninitiated...
Old June 6th 05, 03:12 AM
Morgans
"Jack Allison" wrote
No looking back now, especially since we're operating
for *less* than another FBO in the area charges for their wet rate on a
C-152.
Are you also including a fund for: engine overhaul reserve, annual
inspection expenses reserve, and hangar or tiedown, in your per hour
calculation? If so, that is truly great news!
Jim in NC
Old June 6th 05, 03:27 AM
RST Engineering
Jim ....
Please..."annual inspection expenses reserve" should be out of your
vocabulary. The annual inspection should be something on the order of
$200-400. What the inspection REVEALS if not taken care of during the year
might be a hell of a lot more. But don't lay the cost of preventive
maintenance on the annual.
My annual this year (if I couldn't do it myself) would be $150. The
cylinder inspection and replacement of parts is another $600. The muffler
with deteriorated flame tubes is another $600. The muffler shroud is $200.
Is this $1400 part of the annual? I think not. Please separate "average
preventive maintenance" from the "annual".
Thanks,
"Morgans" wrote in message
Jim in NC
Old June 6th 05, 05:19 AM
Morgans
"RST Engineering" wrote Jim ....
year
True. Well said.
If the plane is new to you, and a very complete prebuy inspection was not
done; then you could get bitten on the behind.
Jim in NC
Old June 6th 05, 11:23 PM
Matt Whiting
RST Engineering wrote:
Jim ....
It is only maintenance if you replace the parts before they break. :-)
Matt
Old June 6th 05, 11:32 PM
RST Engineering
No, it is always maintenance. It is PREVENTIVE maintenance if you replace
the parts before they break. {;^P
Matt
Old June 6th 05, 11:39 PM
Matt Whiting
No, it is a repair when done after the break. :-)
Preventive maintenance is redundant.
Matt
Old June 6th 05, 11:49 PM
RST Engineering
I refuse to have a battle of wits with an unarmed man.
"Matt Whiting" wrote in message
replace the parts before they break. {;^P
Matt
Old June 7th 05, 01:32 AM
Matt Whiting
Ah, preventive maintenance. :-)
Saves a later repair after the battle. ;-)
Matt
Old June 6th 05, 04:19 AM
Jack Allison
Yep, this is including all fixed and variable expenses. Variable
expenses including engine/maintenance reserves and fuel run right at
$50/hr., depending on fuel cost. Tack on another $200/month for each
one of us (three partners) and that has put it right at $70/hr. for my
hours each of the last two months.
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
