![]() Peter Duniho wrote: "Ron Rosenfeld" wrote in message ... Pilot/Controller Glossary under the C's for Course I'm not aware of any reason that glossary is legally applied to words found in FAR 97.3. The glossary exists to describe communications between pilots and controllers, nothing more. Pete Then again, an IAP is issued under a subset of 97.20 on a form 8260-3 or -5, and on that form (which is regulatory as to courses, altitudes, and distances, as it says at the top of the form) specifies the outbound course for the procedure turn. Line 1 of the form. If, instead, the course reversal is a holding pattern, then Line 2 specifies the inbound course of the holding pattern. Would you deem the inbound course for the holding pattern to be regulatory? I would. So, following that reasoning, where the outbound course for a standard procedure turn is set forth on Line 1 of the 8260-3 or -5, it seems that it would be regulatory. Because the procedure turn is treated with sufficient detail under 97.2X (the 8260 form) there is no need for a definition under 97.3 |
[...] So, following that reasoning, where the outbound course for a standard procedure turn is set forth on Line 1 of the 8260-3 or -5, it seems that it would be regulatory. I'm not really sure what you're getting at here. You seem to be reinforcing my point. |
![]() Peter Duniho wrote: wrote in message ... [...] So, following that reasoning, where the outbound course for a standard procedure turn is set forth on Line 1 of the 8260-3 or -5, it seems that it would be regulatory. I'm not really sure what you're getting at here. You seem to be reinforcing my point. My point was that there is a specific regulatory description of the outbound track of a standard procedure turn. I took it that you felt there was none, since it was not set forth in 97.3. |
Procedure turn required? | Yossarian | Piloting | 85 | July 6th 05 08:12 PM |
Sports class tasking | [email protected] | Soaring | 12 | April 25th 05 01:32 PM |
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! | copertopkiller | Military Aviation | 11 | April 20th 04 02:17 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
