Procedure turn required?
Old June 6th 05, 07:53 PM
Kris Kortokrax
I agree with your instructor. AFAIK, there is NEVER a requirement to make
a procedure turn.
Legal Counsel has issued an opinion, see below.
Kris
Nov. 28, 1994
Mr. Tom Young, Chairman
Charting and Instrument Procedures Committee
Air Line Pilots Association
535 Herndon Parkway
Herndon, VA 22070
Dear Mr. Young
This is a clarification of our response to your letter of August 23,
1993. In that letter you requested an interpretation of Section 91.175 of
the Federal Aviation Regulation (FAR) (14 CFR Section 91.175). You address
the necessity of executing a complete Standard Instrument Approach Procedure
(SIAP) in a non-radar environment while operating under Instrument Flight
Rules (IFR). Our response assumes that each of the specific scenarios you
pose speaks to a flight conducted under IFR in a non-radar environment.
Section 91.175(a) provides that unless otherwise authorized by the
Administrator, when an instrument letdown to a civil airport is necessary,
each person operating an aircraft, except a military aircraft of the United
States, shall use a standard instrument approach procedure prescribed for
the airport in Part 97.
First you ask whether an arriving aircraft must begin the SIAP at a
published Initial Approach Fix (IAF). A pilot must begin a SIAP at the IAF
as defined in Part 97. Descent gradients, communication, and obstruction
clearance, as set forth in the U.S. Standard for Terminal Instrument
Approach Procedures (TERPs), cannot be assured if the entire procedure is
not flown.
You also ask whether a Distance Measuring Equipment (DME) arc initial
approach segment can be substituted for a published IAF along any portion of
the published arc. A DME arc cannot be substituted for a published IAF along
a portion of the published arc. If a feeder route to an IAF is part of the
published approach procedure, it is considered a mandatory part of the
approach.
Finally, you ask whether a course reversal segment is optional "when one
of the conditions of FAR section 91.175(j) is not present." Section
91.175(j) states that in the case of a radar vector to a final approach
course or fix, a timed approach from a holding fix, or an approach for which
the procedures specifies "no procedure turn," no pilot may make a procedure
turn unless cleared to do so by ATC.
Section 97.3(p) defines a procedure turn, in part, as a maneuver
prescribed when it is necessary to reverse direction to establish the
aircraft on a intermediate or final approach course. A SIAP may or may not
prescribe a procedure turn based on the application of certain criteria
contained in the TERPs. However, if a SIAP does contain a procedure turn and
ATC has cleared a pilot to execute the SIAP, the pilot must make the
procedure turn when one of the conditions of Section 91.175(j) is not
present.
If you have any questions regarding this matter, please contact Patricia
R. Lane, Manager, Airspace and Air Traffic Law Branch, at (202) 267-3491.
Sincerely,
/s/
Patricia R. Lane
for Donald P. Byrne
Assistant Chief Counsel
Regulations Division
Procedure turn required? Yossarian Piloting 85 July 6th 05 08:12 PM
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 11 April 20th 04 02:17 AM
