Yes, does anyone have pictures of these animals and the mod to the
flaps? Thanks, Larry "zero one" "Chris" wrote in message : Hi Dick et all Is there a similar mod available for the Nimbus 2, I am rebuilding a Nimbus at the moment and always thought that area could benefit from fairings, pictures or drawings would do I can work from there. Chris Runeckles Western Australia wrote in message oups.com... You described the fairing installation procedure well JJ, and that is just how I did mine. But do not forget to describe sawing off the 4 inches of each flap root. Otherwise it is real difficult to move the flaps. Dick Johnson |
Look in the June issue of Soaring for 2 photos of the Ventus A wing
root fairings. Fairings should about equally benefit the Nimbus 2, but that wing is thicker, and I do not know if anyone has developed fairings for it. Dick Johnson |
I found an image on Jim Phoenix's site of the fairing.
http://www.jimphoenix.com/jimphoenix...Nfuselage.html Also the last issue of Soaring Magazine has a good picture from the rear of Dick's Ventus with the wings on so you can see the flaps. |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
Wing root fairings | D.A.L | Soaring | 10 | October 29th 03 11:36 AM |
wing root strakes (not canard A/C) | Wallace Berry | Home Built | 0 | October 2nd 03 08:47 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
