![]() wrote in message ... Matt Barrow wrote: wrote in message ... Doug wrote: A pilot can use either technique. Depending on the pilot, the aircraft, and the approach, there are positives and negatives to using dive and drive vs. stabilized constant descent technique. The accidents stats don't support any positives for dive-and-drive. Cite? How can I cite the negative? The same way you assert it. There are many, many NPA crashes over the years. And how many were attributable to D&D, rather than stabilized descent? |
![]() Matt Barrow wrote: wrote in message ... Matt Barrow wrote: wrote in message ... Doug wrote: A pilot can use either technique. Depending on the pilot, the aircraft, and the approach, there are positives and negatives to using dive and drive vs. stabilized constant descent technique. The accidents stats don't support any positives for dive-and-drive. Cite? How can I cite the negative? The same way you assert it. There are many, many NPA crashes over the years. And how many were attributable to D&D, rather than stabilized descent? The accidents that were reviewed by the group working constant descent/constant rate and Baro VNAV issues were all dive-and-drive. So far as I know, there wasn't much, if any, constant rate/descent angle NPA operational policies until perhaps the mid-1990s. Your hostility indicates a closed mind, but that is your problem, not mine. There was a crash of a commuter Metroliner in Austrailia about a month ago that was almost certainly a misunderstood stepdown fix, which is a different (but related) hazard to dive and drive. A Baro VNAV path would have almost certainly have prevented that tragedy. I don't know the stats, but misuse of stepdown fixes in the NPA final is a part of the "dive and drive" problem. AOPA, and others, made sure you would retain your "God-given right" to dive and drive. So, keep on 'truckin pal. |
Any inside story re 430/530 WAAS cert.? | [email protected] | Instrument Flight Rules | 0 | May 20th 05 06:13 PM |
WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 04:06 AM |
Terminology of New WAAS, VNAV, LPV approach types | Tarver Engineering | Instrument Flight Rules | 2 | August 5th 03 03:50 AM |
WAAS | Big John | Piloting | 8 | July 22nd 03 01:06 PM |
Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 01:43 PM |
