Do I need DME or ADF in an IFR-certified GPS panel?
Old June 8th 05, 03:26 PM
Thomas Borchert
Matt,
My guess is that you'll
find more GPS approaches that require DME than require ADF.
but how many would there be where the GPS could not legally replace the
DME? Those are only the very few where the DME is not in the database.
Thomas Borchert (EDDH)
Old June 8th 05, 05:51 PM
George Patterson
It's my understanding that the DME box in the plane measures distance from a
VOR. All VORs should be in the database.
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
Old June 8th 05, 06:01 PM
Mark Hansen
Actually, it measures distance from a DME or TACAN facility, not from
a VOR. It can use a VOR/DME or VORTAC, but not a VOR.
George Patterson
Mark Hansen, PP-ASEL, Instrument Student
Sacramento, CA
Old June 8th 05, 06:09 PM
Ron Natalie
the DME? Those are only the very few where the DME is not in the
database.
from a VOR. All VORs should be in the database.
There are ILS based DME's. The issue isn't GPS appraoches, it's
using a GPS to substitute for DME on another non-GPS approach.
Old June 8th 05, 07:24 PM
Roy Smith
Not all DME ground stations are co-located with VORs. Many are on
airports as part of an ILS-DME (and the exact location of the ground
station is not charted in that case).
If you look hard enough, you can find the occasional NDB-DME station.
I'm not aware of any stand-alone DME ground stations, but I can't
think of any reason why such a thing couldn't exist.
Old June 8th 05, 07:34 PM
Ron Natalie
There are probably some TACAN only stations around somewhere, but I'm
not sure any civil procedures would use them.
Old June 10th 05, 04:13 AM
Dave S
KEFD (ellington field) has some DME arcs on its TERPS that are based on
an on-field TACAN. Once upon a time this was a VORTAC, but its been a
TACAN only for at least the past 5 years, prolly closer to 10.
the ILS 17R is one of em. The Govt charts list the TACAN/DME chan as
31.. by having the jepp charts, you can know the freq as 109.4 mhz.
I use the DME routinely just to know distance to the field in non-gps
planes.
Dave
Old June 8th 05, 06:08 PM
Ron Natalie
Matt,
There are no GPS appraoches that require DME period. It's not a
matter of "replacing" it.
The only issue is using GPS to substitute for DME on NON-GPS
approaches. You can do that if you have the fix AND this isn't
the non-GPS required alternate.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
