Matt Barrow wrote:
I had no idea that any GPS approaches existed that required DME - guess that would make them "GPS-DME" approaches. Can you name some? One I do fairly often is SDA GPS 12, which is a VOR/DME overlay. To fly this approach you need either (VOR and DME) or GPS. If you're flying it with a GPS, you don't need a DME. It's really just for convenience that they put them both on the same chart. |
In article , Roy Smith wrote:
Matt Barrow wrote: I had no idea that any GPS approaches existed that required DME - guess that would make them "GPS-DME" approaches. Can you name some? One I do fairly often is SDA GPS 12, which is a VOR/DME overlay. To fly this approach you need either (VOR and DME) or GPS. If you're flying it with a GPS, you don't need a DME. It's really just for convenience that they put them both on the same chart. Looking closer at this approach, I'm a little confused why the OVR 13 DME (CFDKH) fix exists. There's no course change. The MDA is the same before and after. There's no timer to start. Why is the segment after Omaha VOR not simply "2800 NoPT to PICAM"? |
Roy Smith wrote:
Looking closer at this approach, I'm a little confused why the OVR 13 DME (CFDKH) fix exists. There's no course change. The MDA is the same before and after. There's no timer to start. Why is the segment after Omaha VOR not simply "2800 NoPT to PICAM"? It's to let you know you're inside the circle :-) |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
