WAAS for GNS 430/530?
Old June 8th 05, 10:27 PM
Andrew Gideon
Victor J. Osborne, Jr. wrote:
But does this feature work as enhancements to existing SDF/LOC approaches?
My reading of the advertising-speak is that it can build a descent profile
for any approach. I've some question about that (ie. what if the straight
line from FAF to VDP passes under a stepdown), but I don't know that I've
interpreted the advertising-speak accurately.
- Andrew
Old June 9th 05, 04:35 AM
John R. Copeland
"Andrew Gideon" wrote in message =
online.com...
=20
But does this feature work as enhancements to existing SDF/LOC =
approaches?
=20
My reading of the advertising-speak is that it can build a descent =
profile
for any approach. I've some question about that (ie. what if the =
straight
line from FAF to VDP passes under a stepdown), but I don't know that =
I've
=20
- Andrew
I agree the "advertising-speak" seems to say what you interpreted.
But I've yet to encounter a computed glide slope for any SDF/LOC
or VOR approaches in my CNX80.
(If some are there, though, someone will surely tell us so.)
However, it seems like all RNAV (GPS) approaches, as well as a majority
of the plain-vanilla GPS approaches do give me vertical guidance,
to which I can couple my 3-axis autopilot if I so choose.
During practice, I make sure I'm comfortable either coupled or =
uncoupled.
Regarding the "straight line from FAF to VDP passing under a stepdown",
that's handled by a charting a delay before descending until reaching a =
point
from which the stabilized descent *will* meet obstruction-clearance =
criteria.
The CNX80/GNS480 follows that charting.
It does not start the descent from the FAF when it's incorrect to do so.
Old June 9th 05, 02:48 PM
Andrew Gideon
point from which the stabilized descent will meet obstruction-clearance
criteria. The CNX80/GNS480 follows that charting.
That's a nice solution; I wish I could see it for myself grin.
- Andrew
Old June 9th 05, 11:48 PM
Jon Carlson
Does the computed glideslope indication meet obstacle clearance (i.e.
stepdown altitudes and whatnot) even if the approach is flown a couple
of dots low on the glideslope indication? Or does the pilot/autopilot
need to be absolutely sure that the approach is flown smack in the
middle or a couple dots high?
-Jon C.
"John R. Copeland" wrote in message
stepdown",
a point
criteria.
so.
Old June 10th 05, 12:58 AM
Roy Smith
I think that's kind of like asking, "Does the MDA meet obstacle clearance
even if you go below it?".
I think the answer to both questions is the same, "There's some
TERPs-defined buffer built in, but from the pilot's point of view, all you
gotta know is don't go below what the procedure says until you can see the
runway".
Old June 10th 05, 05:24 AM
Jon Carlson
clearance
Sort of, but one of the advantages of WAAS generated glideslopes is
that it enables autopilot coupled approaches with vertical guidance.
So... if a dot or two off runs you through a hill, that might be a
nice thing to know and correlate with your autopilot's level of
precision...
all you
see the
runway".
Yes, we are still responsible for not descending below the MDA. But we
need to understand the limitations of the box if we're going to let
the box help us so that we can know what we have to do to live up to
those responsibilities.
-Jon C.
Any inside story re 430/530 WAAS cert.? [email protected] Instrument Flight Rules 0 May 20th 05 06:13 PM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
WAAS Big John Piloting 8 July 22nd 03 01:06 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
