For [email protected]
Old June 10th 05, 03:37 AM
Bob Gardner
I rely on the Summit Aviation CD-ROM...guess they don't provide
everything...
Thanks.
Bob
"JPH" wrote in message
news:xC5qe.9693$mC.6960@okepread07...
Bob,
The TERPS manual that contains the PT instructions can be found at this
website;
http://av-info.faa.gov/terps/Directi...260.3_1-18.pdf
If you go to page 34 (of 268) you can find the graphic and on page 35 you
can find the table that gives the instructions on how to build the PT
manually.
JPH
Bob Gardner wrote:
It is apparently not possible to communicate with you directly, so let me
explain how I got the 1.4 miles of protected airspace on the
non-maneuvering side of procedure turn airspace, and apologize for being
wrong...the protected airspace is 4.0 miles wide, giving the pilot even
less reason to work at tracking the outbound.
Back when TERPS was an actual publication with pages rather than an
online source, Para 234 included instructions for constructing procedure
turn airspace based on max allowed distance. In the instructions for a
ten-mile PT, the procedures designer was told to select a point one mile
inside of the airspace on the manuevering side, perpendular to the
outbound course at the fix. The next step was to select another point,
ten miles from the original point but two miles inside of the maneuvering
airspace. The designer was then told to swing an arc with a 5 nm radius
from the first point and a 6 nm radius from the second point. A line
drawn tangent to these two arcs, parallel to the outbound course, defines
the edge of the primary protected area on the non-maneuvering side. The
primary area gives 1000 ft of vertical clearance...beyond that, the
protected airspace vertical protection tapers down to zero over an
additional two miles.
Can't find the detailed instruction in the online TERPS, but the
illustration remains.
Bob Gardner
Old June 10th 05, 01:38 PM
everything...
How current is your Summit CD? Mine shows Paragraph 234, the graphic, and the
three tables for construction area, depending on altitude.
The three different sizes, depending on altitude, were added in the past five,
or so, years.
Another thing to keep in mind, just like with holding pattern crtieria (a
different handbook, also in Summit) is that where the procedure turn is a VHF
fix, the fix error could already chip away at the margins, so you might not
quite be where you think you should be when starting a procedure turn under
those circumstances.
Then, there is the ever-present issue of FAA policy directives that are not
reflected in handbooks that are not "spot current." For instance, in the
holding pattern crtieria there is a selection table for GPS (RNAV) holding, but
that was challenged at the Aeronatucal Charting Forum about three years ago as
being an untested selection process that presumed positive course guidance
throughout an RNAV holding pattern. Only some high-end LNAV platforms can do
that; others must fly outbound in the traditional manner using dead reckoning.
As a result of that ACF issue paper the FAA made simulator tests, which
confirmed the industry objection. Thus, by policy letter, that GPS selection
table can no longer be used for RNAV holding patterns.
Thanks.
Bob
Bob,
website;
manually.
JPH
Bob Gardner
Old June 10th 05, 09:20 PM
Bob Gardner
Poor research on my part. At a glance, the presentation didn't look like
what I had seen in the past, and I dismissed it. But my original point is
valid...there is a ton of protected airspace on the non-maneuvering side.
Bob Gardner
wrote in message ...
everything...
five,
or so, years.
VHF
not
under
not
holding, but
ago as
do
reckoning.
selection
Thanks.
Bob
Bob,
website;
you
manually.
JPH
me
being
even
procedure
mile
maneuvering
radius
defines
The
Bob Gardner
Old June 11th 05, 12:08 AM
No doubt that is the case for light aircraft. But, not necessarily so for
jets. For many years the AIM said procedure turn entry and maneuvers could be
done as high as 250 knots, IAS. When it was demonstrated to them that loss of
containment could occur in the entry area at certain angles and adverse tail
wind components, they dropped the max speed to 200.
