On Thu, 09 Jun 2005 09:55:37 -0400, xyzzy wrote:
Ron Rosenfeld wrote: On Wed, 08 Jun 2005 14:55:45 -0400, xyzzy wrote: Doug wrote: There is, in fact, a requirement to be able to fly the approach at your alternate without the use of GPS. So having DME will assist you in finding legal alternates that have VOR/DME approaches. This will allow you to carry less fuel and more payload. Without DME or ADF, all you can fly is a VOR approach, and if you have radar, an ILS or LOC (maybe a few obscure others). Even then some ILS's require DME or ADF. My home airport has an ILS approach with ADF required, but I just figured I could use the GPS to substitute for the ADF. From what I understand of the above, that's true but that also means my airport's ILS approach is not a legal alternate for someone planning a GPS somewhere else, do I understand that right? (I'm an instrument student, still learning this stuff and have found this thread fascinating). What is your home airport? TTA, ILS RWY 3. Some GPS units (GNS480) do NOT require that the the alternate have something other than a GPS approach. But I'd like to look at your specific approach to see if it would be legal to fly the ILS ADF approach there. The other aproaches at TTA are GPS on both 3 and 21 and NDB on 3. So basically an ADF is kinda important there. If you don't have an approach certified GPS, you need one. Well, according to my Jepp chart, TTA is NA for filing as an alternate, so the ILS (or any other approach) would not be a legal alternate anyway. For actually flying the ILS, an approach-approved GPS can substitute for the NDB on that ILS approach. Since the NDB Rwy 3 approach is not an overlay, an approach-approved GPS could not fly it legally. This is not a loss as there is an RNAV(GPS) Rwy 3 approach which has lower minimums! Best, Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Thu, 09 Jun 2005 09:55:37 -0400, xyzzy wrote: Ron Rosenfeld wrote: On Wed, 08 Jun 2005 14:55:45 -0400, xyzzy wrote: Doug wrote: There is, in fact, a requirement to be able to fly the approach at your alternate without the use of GPS. So having DME will assist you in finding legal alternates that have VOR/DME approaches. This will allow you to carry less fuel and more payload. Without DME or ADF, all you can fly is a VOR approach, and if you have radar, an ILS or LOC (maybe a few obscure others). Even then some ILS's require DME or ADF. My home airport has an ILS approach with ADF required, but I just figured I could use the GPS to substitute for the ADF. From what I understand of the above, that's true but that also means my airport's ILS approach is not a legal alternate for someone planning a GPS somewhere else, do I understand that right? (I'm an instrument student, still learning this stuff and have found this thread fascinating). What is your home airport? TTA, ILS RWY 3. Some GPS units (GNS480) do NOT require that the the alternate have something other than a GPS approach. But I'd like to look at your specific approach to see if it would be legal to fly the ILS ADF approach there. The other aproaches at TTA are GPS on both 3 and 21 and NDB on 3. So basically an ADF is kinda important there. If you don't have an approach certified GPS, you need one. Well, according to my Jepp chart, TTA is NA for filing as an alternate, so the ILS (or any other approach) would not be a legal alternate anyway. Why do they designate airports NA for alternates? Is it perhaps because a major class-C airport (RDU) is nearby and should be used as the alternate instead? |
a major class-C airport (RDU) is nearby and should be used as the alternate instead? They don't designate airports NA for alternates. They only designate approaches NA for alternates. Pilots then sometimes refer to an airport as being NA for alternates when they discover that all the approaches are NA for alternates. Often times, though, some approaches will be NA and others will not be... -- Cheers, John Clonts Temple, Texas N7NZ |
John Clonts wrote:
Why do they designate airports NA for alternates? Is it perhaps because a major class-C airport (RDU) is nearby and should be used as the alternate instead? They don't designate airports NA for alternates. They only designate approaches NA for alternates. Pilots then sometimes refer to an airport as being NA for alternates when they discover that all the approaches are NA for alternates. Often times, though, some approaches will be NA and others will not be... Ok, why do they designate approaches NA for alternates (every approach at this airport is so designated)? |
at this airport is so designated)? The NACO approach books' legend explains thus: [Black Triangle "A" NA] - Alternate minimums are Not Authorized due to unmonitored facility or absence of weather reporting service I understand that the "unmonitored facility" basically means that ATC has no means of confirming that the facility (VOR, ILS, NDB, etc) is working at a given time. More info in this thread: http://groups-beta.google.com/group/...a9031acc10224/ -- Cheers, John Clonts Temple, Texas N7NZ |
On 6/15/2005 09:51, John Clonts wrote:
Ok, why do they designate approaches NA for alternates (every approach at this airport is so designated)? The NACO approach books' legend explains thus: [Black Triangle "A" NA] - Alternate minimums are Not Authorized due to unmonitored facility or absence of weather reporting service I understand that the "unmonitored facility" basically means that ATC has no means of confirming that the facility (VOR, ILS, NDB, etc) is working at a given time. This still doesn't mean that the NA applies to the entire airport. For example, at one of the local airports here, one of the approachs is not authorized for use as an alternate when the tower is closed, because it is not monitored. However, a different approach (at the same airport) uses a VOR facility that is off-field, and it is authorized as an alternate. Of course, I'm an instrument student, so I may still be missing something... More info in this thread: http://groups-beta.google.com/group/...a9031acc10224/ -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA |
On Wed, 15 Jun 2005 10:05:07 -0700, Mark Hansen
wrote: This still doesn't mean that the NA applies to the entire airport. For example, at one of the local airports here, one of the approachs is not authorized for use as an alternate when the tower is closed, because it is not monitored. However, a different approach (at the same airport) uses a VOR facility that is off-field, and it is authorized as an alternate. If there's no weather reporting, you're out of luck for the airport. |
On Tue, 14 Jun 2005 11:10:33 -0400, xyzzy wrote:
Why do they designate airports NA for alternates? Is it perhaps because a major class-C airport (RDU) is nearby and should be used as the alternate instead? Usually it is either because of unmonitored facilities or an absence of weather reporting. In point of fact, it is the approaches that are designated NA and not the airport as a whole. The fact that all of the approaches at TTA leads to an interesting conundrum which get debated here from time to time. Part 91 prescribes certain minima for an airport to be used as an alternate. The way it reads (91.169c), if an instrument approach has been published, then certain minima are required (depending on precision vs non-precision, etc). However, if no instrument approach has been published, then "the ceiling and visibility minima are those allowing descent from the MEA, approach, and landing under basic VFR". There's no exception for an airport which has published approaches, but they're all marked NA for an alternate, as at TTA. So, you're filed to RDU, and the weather requires an alternate. You obtain "appropriate weather reports or weather forecasts, or a combination ..." that indicate the weather at TTA will be severe clear at your time of arrival. According to a strict reading of those regulations, you still could not use it as an alternate; although it would be perfectly OK to use some grass strip as an alternate. Makes no sense to me. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
So, you're filed to RDU, and the weather requires an alternate. You obtain "appropriate weather reports or weather forecasts, or a combination ..." that indicate the weather at TTA will be severe clear at your time of arrival. According to a strict reading of those regulations, you still could not use it as an alternate; although it would be perfectly OK to use some grass strip as an alternate. Makes no sense to me. You can't use it to satisfy the requirements for *filing* an alternate. You can *use* whatever you want. Right? Dave |
Dave Butler wrote:
Ron Rosenfeld wrote: So, you're filed to RDU, and the weather requires an alternate. You obtain "appropriate weather reports or weather forecasts, or a combination ..." that indicate the weather at TTA will be severe clear at your time of arrival. According to a strict reading of those regulations, you still could not use it as an alternate; although it would be perfectly OK to use some grass strip as an alternate. Makes no sense to me. You can't use it to satisfy the requirements for *filing* an alternate. You can *use* whatever you want. Right? Right, couldn't you file, say FAY, as an alternate then on your way there when you break out cancel IFR and land at TTA? |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
