Does an "IFR approved" GPS placard require database updates?
Old June 10th 05, 11:47 AM
Peter Clark
On Fri, 10 Jun 2005 04:33:58 GMT, Chuck wrote:
On Tue, 31 May 2005 12:24:32 +0000 (UTC),
In rec.aviation.misc Charlie Derk wrote:
: During my instrument training I was told that if you have an IFR
: certified GPS, it had to be updated if you were using it for IFR Flight.
: You can use it VFR even if it hasn't been updated
: Charlie
As I've heard it, you can technically fly IFR with an expired database, so
long as you have verified that the data for every piece of information in the database
that you will use is correct.
-Cory
I've heard that recently myself. You can use an expired database GPS
for all the VFR you want. But to use it for IFR, you first have to
confirm the database information for any approach you'll use hasn't
changed. Or you have to manually chage it in the database if it has
changed.
Unless precluded by the flight manual supplement or, if incorporated
by reference like "Must be operated in accordance with the owners
manual" in the supplement, the users guide.
The KLN89B and KLN94 are apparently two such units - their supplement
introduction states "NOTE: A current database is required by
regulation in order to use the (blah) GPS system for non-precision
approaches". The KLN94 limitations page states "Instrument approaches
must be accomplished in accordance with approved instrument approach
procedures that are retrieved from the KLN 94 database. The KLN 94
aeronautical database must incorporate the current update cycle." The
89B's limitations page is similar, except they also have a minimum
software revision limitation.
Doesn't look to have any discretion to verify and go with expired
databases with these boxes at least.
Old June 10th 05, 12:31 PM
Peter R.
approaches".
Minus the words "by regulation," my Garmin GNS430 GPS also has such as
restriction in the POH supplement.
I recall reading here that at least one other GNS430 owner did not have
such a restriction in his supplement. One possible explanation may be that
my unit, as purchased by the previous owner of the aircraft, was one of the
first GNS430s available. Perhaps Garmin and/or the FAA loosened that
restriction as time went on.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Approved Drug List Carl J. Hixon Piloting 13 December 2nd 04 01:00 PM
Is AWC an approved weather source? Andrew Sarangan Piloting 1 June 26th 04 01:01 PM
clever amateur built placard mods Joa Home Built 5 January 8th 04 08:10 AM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
