Best PDA or tablet soln for GPS & XM WX and gyro AI
Old June 12th 05, 01:20 AM
Luke Scharf
Michael 182 wrote:
Why would altitude affect a hard drive?
Because the hard drive head "flies" over the platter. The tolerances
are tight enough and things move quickly enough inside the drive that
the air has a big affect on how close the read/write head gets to the
disc platter, and the drive is designed with this in mind.
Take the air away, and the head that was supposed to be hovering a few
mils over the disc is now scratching up the surface on which the data is
stored. Not a recipe for reliable long-term data storage.
See the following page for more detail:
http://www.storagereview.com/guide20.../opHeight.html
FWIW, I run my iPod at high altitudes all the time with no failures.
Then somebody did a good job designing the hard drive in it, assuming
that it has a hard drive. The iPod Shuffle uses flash ram instead of a
hard drive and should work in a vacuum -- even if listening to music in
a vacuum appears to be impractical. :-)
-Luke
Old June 12th 05, 05:05 AM
Michael 182
"Luke Scharf" wrote in message
Because the hard drive head "flies" over the platter. The tolerances are
tight enough and things move quickly enough inside the drive that the air
has a big affect on how close the read/write head gets to the disc
Thanks. Good explanation.
Then somebody did a good job designing the hard drive in it, assuming that
it has a hard drive. The iPod Shuffle uses flash ram instead of a hard
drive and should work in a vacuum -- even if listening to music in a
No, I have the 20 gig drive.
Michael
Old June 12th 05, 04:13 PM
Matt Barrow
Motion Computing LE1600.
Great display, 1GB Celeron, 30GB HD.
http://www.motioncomputing.com/produ...blet_pc_le.asp
Old June 12th 05, 04:21 PM
Mitty
Interesting thread he
http://www.tabletpcbuzz.com/forum/to...TOPIC_ID=22517
includes several photos of the Motion machine in a cockpit.
If the link doesn't work, search on "cockpit" will get you the thread.
On 6/12/2005 10:13 AM, Matt Barrow wrote the following:
Old June 13th 05, 10:42 PM
Blueskies
"Mitty" wrote in message ...
That is a lot of screen to be looking at - I hope those folks are looking outside more than they are looking inside.
Gyrocopter Speed Mark Rotorcraft 36 August 16th 05 11:28 PM
Best PDA or tablet soln for GPS & XM WX and gyro AI Paul Folbrecht Instrument Flight Rules 31 June 18th 05 01:42 PM
Horizon Gyro internal lighting? Chad Lemmen Owning 2 September 6th 04 03:38 AM
My newly overhauled Gyro! Robert M. Gary Piloting 10 March 4th 04 06:10 PM
Gyro Copter for Sale on EBAY EC155 Pilot Home Built 0 November 1st 03 11:34 PM
