How come GPS reads different
Old June 12th 05, 04:11 PM
Aluckyguess
Its a 296. It seems the like the higher I go the farther off it is.
I am one to think the GPS would be more accurate than the altimeter.
I was thinking that we get incorrect altimeter settings
"Casey Wilson" N2310D @ gmail.com wrote in message
news:x1Pqe.2896$9a1.185@trnddc01...
"Aluckyguess" wrote in message
I am getting over 500ft. difference and more.
"Matt Whiting" wrote in message
Aluckyguess wrote:
How come the GPS reads a different altitude than the Altimeter?
For many reasons. The main reason is that they derive altitude by two
completely different methods and this inevitably introduces errors. Then
each method has its own inherent errors.
Even two altimeters side by side won't read the same altitude other than
by accident.
Matt
The number of sattelites being received is one of the variables -- how
many are you registering on the GPS? What brand/model is the GPS. Is the
GPS certified for navigation? Does the GPS have a Kohlsman equivalent
input? What are the altitude specifications of the GPS? Are you comparing
it to an altimeter in an airplane? Is the calibration data on the
altimeter valid? Have you compared the altimeter to the GPS while parked
at a known reference (i.e., the benchmark of your local airport)? My
Magellan handheld takes about five mintues of averaging to get a
reasonably close altitude correlation -- how much time are you giving
yours?
Bottom line, forget the GPS altitude reading, dial in the local pressure
data into the airplane's altimeter and trust it.
Old June 12th 05, 05:13 PM
Fred G. Black
The altimeter is only "accurate" when the temperature profile of the
airmass is equal to the ISA standard atmosphere. The rest of the time,
there will be some error which increases with altitude (wrt wherever the
source for the altimeter setting is located). This isn't a concern for
en-route operations since everybody's altimeter has the same "error".
It can be a concern for terrain clearance in the mountains or in some
cases instrument approaches in cold weather since the altimeter reads
higher than the plane actually is.
Old June 12th 05, 05:28 PM
Stefan
en-route operations since everybody's altimeter has the same "error". It
can be a concern for terrain clearance in the mountains or in some cases
instrument approaches in cold weather since the altimeter reads higher
No concern, either. When IMC, there is a safety margin built into the
approaches, and when VMC, there are windows in the copckpit.
Pneumatic altimeters are reliable, independant of any infrastructure and
work without electricity.
Stefan
Old June 12th 05, 06:23 PM
Fred G. Black
This isn't a concern for en-route operations since everybody's
altimeter has the same "error". It can be a concern for terrain
clearance in the mountains or in some cases instrument approaches in
cold weather since the altimeter reads higher than the plane actually is.
Stefan
There is a buffer in the procedure design however given that cold
temperature corrections are published (at least in Canada, ref CAP GEN
p19), it's not unreasonable to assume that there are situations where
they should be used.
Fred.
Old June 12th 05, 07:01 PM
Stefan
Of course. That's one more reason why you must pass a test to get the
license.
Stefan
Old June 12th 05, 07:16 PM
Dan Luke
Most of the time.
In very cold weather, you can run into something by relying on a
pneumatic altimeter.
Dan
C172RG at BFM
Old June 12th 05, 07:23 PM
Stefan
Pssst, I'll tell you a secret: All that stuff you had to learn to pass
the written was somehow linked to real life.
Stefan
Old June 12th 05, 07:43 PM
Dan Luke
Really?
Gosh!
Dan
"How can an idiot be a policeman? Answer me that!"
- Chief Inspector Dreyfus
Old June 13th 05, 02:42 PM
Guillermo
Does anybody know a quick rule of thumb about how much the altitude changes
with non-standard temperature?
I guess is also has to have in consideration that the airport altimeter
setting is also kinda "corrected".
I.E., you are flying at 4000 ft, then if you set up the altimeter setting
for an airport at 3800', you'll be far more accurate than if you set it up
for an airport at 1000' (assuming that the atmosphere is exactly the same).
or, in other words, the closer you are to the airport altitude, the more
accurate your altitude will be.
"Dan Luke" wrote in message
Most of the time.
Dan
C172RG at BFM
GREAT AVIATION READS Cribsheet Piloting 1 September 12th 04 02:51 AM
GREAT AVIATION READS Cribsheet Rotorcraft 0 September 10th 04 06:06 PM
GREAT AVIATION READS Cribsheet Military Aviation 0 September 7th 04 06:37 PM
When the ASI Reads Below Zero BTIZ Piloting 11 August 23rd 04 04:57 PM
Newsweek Reads RAM! Bob McKellar Military Aviation 0 February 17th 04 02:10 AM
