![]() "Stefan" wrote: Pneumatic altimeters are reliable, Most of the time. In very cold weather, you can run into something by relying on a pneumatic altimeter. -- Dan C172RG at BFM |
Dan Luke wrote:
In very cold weather, you can run into something by relying on a pneumatic altimeter. Pssst, I'll tell you a secret: All that stuff you had to learn to pass the written was somehow linked to real life. Stefan |
![]() "Stefan" wrote: Pssst, I'll tell you a secret: All that stuff you had to learn to pass the written was somehow linked to real life. Really? Gosh! -- Dan "How can an idiot be a policeman? Answer me that!" - Chief Inspector Dreyfus |
Does anybody know a quick rule of thumb about how much the altitude changes
with non-standard temperature? I guess is also has to have in consideration that the airport altimeter setting is also kinda "corrected". I.E., you are flying at 4000 ft, then if you set up the altimeter setting for an airport at 3800', you'll be far more accurate than if you set it up for an airport at 1000' (assuming that the atmosphere is exactly the same). or, in other words, the closer you are to the airport altitude, the more accurate your altitude will be. "Dan Luke" wrote in message ... "Stefan" wrote: Pneumatic altimeters are reliable, Most of the time. In very cold weather, you can run into something by relying on a pneumatic altimeter. -- Dan C172RG at BFM |
GREAT AVIATION READS | Cribsheet | Piloting | 1 | September 12th 04 02:51 AM |
GREAT AVIATION READS | Cribsheet | Rotorcraft | 0 | September 10th 04 06:06 PM |
GREAT AVIATION READS | Cribsheet | Military Aviation | 0 | September 7th 04 06:37 PM |
When the ASI Reads Below Zero | BTIZ | Piloting | 11 | August 23rd 04 04:57 PM |
Newsweek Reads RAM! | Bob McKellar | Military Aviation | 0 | February 17th 04 02:10 AM |
