![]() "Scott Migaldi" wrote in message ... Plain language: Because they do not have the trafic load required to be Class C but much more traffic than what is being loaded into the class D airports. Has nothing to do with traffic levels. We were a TRSA here at BIL and went right into class C when that all happened across the country. A very few just stayed TRSA's. Class D is never an option for a facility with a radar approach control. |
Newps wrote:
"Scott Migaldi" wrote in message ... Plain language: Because they do not have the trafic load required to be Class C but much more traffic than what is being loaded into the class D airports. Has nothing to do with traffic levels. We were a TRSA here at BIL and went right into class C when that all happened across the country. A very few just stayed TRSA's. Class D is never an option for a facility with a radar approach control. Really? How do you explain KRDG, an airport in Class D airspace, which has radar approach control? There is NO TRSA. (The apprch frequency is also not on anywhere on or next to the chart, so one needs to use a A/FD to find the frequency. I think the ATIS includes the frequency, and the tower will direct you to switch to approach frequency if you contact them first, although there is no obligation to use approach if you decline it.) |
![]() Newps wrote: Has nothing to do with traffic levels. We were a TRSA here at BIL and went right into class C when that all happened across the country. A very few just stayed TRSA's. Class D is never an option for a facility with a radar approach control. It may have been an option at one time. Not all TRSAs are leftover from the old days. I recall that Fairbanks, AK had an approach control and class D back in '99 (no TRSA). Looks like they've added a TRSA since then. John Galban=====N4BQ (PA28-180) |
In article .com,
"John Galban" wrote: Newps wrote: Has nothing to do with traffic levels. We were a TRSA here at BIL and went right into class C when that all happened across the country. A very few just stayed TRSA's. Class D is never an option for a facility with a radar approach control. It may have been an option at one time. Not all TRSAs are leftover from the old days. I recall that Fairbanks, AK had an approach control and class D back in '99 (no TRSA). Looks like they've added a TRSA since then. Stockton (KSCK) in California was a Class D with its own approach control until it was swallowed up by NorCal Approach a couple of years ago. Hamish |
Reason was funding. Extra staff for TRSA. Doesn't qualify for Class C.
![]() "Doug" wrote in message oups.com... Reason was funding. Extra staff for TRSA. Doesn't qualify for Class C. Why would a TRSA require more staff than a TRACON with just Class D airspace? |
![]() "Steven P. McNicoll" wrote: "Doug" wrote in message oups.com... Reason was funding. Extra staff for TRSA. Doesn't qualify for Class C. Why would a TRSA require more staff than a TRACON with just Class D airspace? Answering the latter question alone, some TRSAless Class D radar facilities have the radar position(s) in the tower cab, which probably reduces the personnel required compared to a separate room or facility which might require separate supervisors, etc. For example at KRDG, the same controller may operate both local and approach (departure) during off-peak times. Not sure if radar control in the tower cab qualifies as a "TRACON" though or if there is another acronym for the setup. |
![]() "Jessica Taylor" wrote in message ... Answering the latter question alone, some TRSAless Class D radar facilities have the radar position(s) in the tower cab, which probably reduces the personnel required compared to a separate room or facility which might require separate supervisors, etc. Why would the physical location of the radar scope(s) affect the number of personnel required to staff them? For example at KRDG, the same controller may operate both local and approach (departure) during off-peak times. Not sure if radar control in the tower cab qualifies as a "TRACON" though or if there is another acronym for the setup. That setup is known as a TRACAB. I've never been in one, but I assume such facilities have only one radar position. But many TRACONs with multiple radar positions combine them at times to one radar position in the radar room or in the tower cab or even one controller working all TRACON and tower positions. It was stated here that a TRSA requires additional staff. I don't see why that would be, everything else being equal. RFD and RDG have about the same level of traffic, RFD has a TRSA but RDG does not. I see no reason why RDG would require greater staffing to work the same traffic. |
"Newps" wrote in message
... [...] Class D is never an option for a facility with a radar approach control. Never say "never": KEUG There are probably others. |
![]() "Newps" wrote in message ... Class D is never an option for a facility with a radar approach control. Duluth International Airport on the beautiful shores of Lake Superior has a radar approach control and just Class D airspace. So do Rochester International, Waterloo Municipal, Reading Regional, Grand Forks AFB, Minot AFB, etc., etc., etc. Those are just what I can remember, I'm sure a little research would turn up many more. |
R in a Circle (Airport Surveillance Radar) on VFR charts | Jeff Saylor | Piloting | 66 | May 12th 04 04:05 PM |
UTICA TRSA shape | Jeff Saylor | Piloting | 4 | May 10th 04 05:54 AM |
