Hi,
How is standard temperature and pressure defined below sea level? How does DA increase/decrease below sea level? I know that the gravitation force starts decreasing in a *linear* fashion below sea level, but how that affect the temp, pressure, and DA is beyond me. Any books, or URLs that could help me out here? Thanks! Hilton |
"Hilton" wrote in message
ink.net... How is standard temperature and pressure defined below sea level? Same as above sea level. Take the standards at sea level, apply a standard adjustment, viola. How does DA increase/decrease below sea level? Same as above sea level, except in the opposite direction. Below sea level, pressure altitude decreases, which decreases density altitude. Of course, temperature has the same effect regardless of altitude; high temperature increases density altitude, low temperature decreases density altitude. I know that the gravitation force starts decreasing in a *linear* fashion below sea level As far as I know, the difference in gravity has to do with the amount of mass under you, and is negligible with respect to temperature or pressure. Same thing would be true of high-elevation terrain. but how that affect the temp, pressure, and DA is beyond me. I do not believe that the change in gravitation force is significant for the purposes of piloting an aircraft. Basically, nothing unusual happens just because you went below sea level. "Mean sea level" is simply a convenient reference point. Just as you could set your reference point to what we now call 4000' MSL, and then find that density altitude simply decreases below that according to pressure altitude, and temperature increases or decreases density altitude in the same way it does at any altitude...the exact same thing happens below sea level. I haven't seen any calls to adjust density altitude to account for higher gravitational forces at higher altitudes, nor would I expect to see any call to do so at extremely low altitudes. Note that we also don't compensate in our calculations for changes in gravity due to changes in our flight altitude above ground level. As far as us pilots are concerned, gravity is exactly the same everywhere. Pete |
![]() Seems to me that the places where you could fly below MSL are very hot. Wouldn't that affect the aircraft more than the altitude, which in any event would not be very many feet below 0 MSL? -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
On 2005-06-13, Peter Duniho wrote:
"Hilton" wrote in message ink.net... How is standard temperature and pressure defined below sea level? Same as above sea level. Take the standards at sea level, apply a standard adjustment, viola. On a point of pedantry, what does a stringed musical instrument, a little larger than a violin, have to do with the subject at hand? :-) I know that the gravitation force starts decreasing in a *linear* fashion below sea level As far as I know, the difference in gravity has to do with the amount of mass under you, and is negligible with respect to temperature or pressure. Same thing would be true of high-elevation terrain. Especially since airports below MSL aren't that far below MSL anyway (IIRC, the 'deepest' airport in the continental US is only about -200 MSL, but the highest, Leadville, has an additional 9000 ft of rock below it). I've been to a below MSL airport - Thermal (Palm Springs), California. I didn't notice any difference. But it was kind of neat watching a correctly set altimeter go below 0 feet :-) -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Actualy, the places I know of are not very hot but rather cool and
humid. I'm serious here, it is a small country called The Netherlands which is for about one third below actual seal level. -Kees |
![]() "Hilton" wrote in message ink.net... Hi, How is standard temperature and pressure defined below sea level? How does DA increase/decrease below sea level? I know that the gravitation force starts decreasing in a *linear* fashion below sea level, but how that affect the temp, pressure, and DA is beyond me. Any books, or URLs that could help me out here? http://www.faa.gov/atpubs/SWO/chapter_14Sect2.htm but it only has the standard pressures down to about -2700 feet, no temperatures. Increments of .01 inches of mercury. The following is much more coarse.... every 500 feet: http://www.sablesys.com/baro-altitude.html but it shows pressures AND Temperatures down to -5000 feet |
On Mon, 13 Jun 2005 05:34:13 -0400, Cub Driver
wrote in :: in any event would not be very many feet below 0 MSL? Bad Water, the lowest point in the western hemisphere, located in the Death Valley is 282' below sea level. http://www.virtualtourist.com/travel...ater-BR-1.html The lowest place in the world is the Dead Sea at 1,395' below sea level: http://www.extremescience.com/DeadSea.htm |
Furnace Creek, minus 210.
Jim (IIRC, the 'deepest' airport in the continental US is only about -200 MSL, but the highest, Leadville, has an additional 9000 ft of rock below it). |
![]() Dylan Smith wrote: On 2005-06-13, Peter Duniho wrote: Same as above sea level. Take the standards at sea level, apply a standard adjustment, viola. On a point of pedantry, what does a stringed musical instrument, a little larger than a violin, have to do with the subject at hand? :-) Darn! You beat me to it :-) Actually, it's an American custom that you might not have picked up in your time here. We usually have our Koch chart taped to the back of our violas (the instrument, not the flower). John Galban=====N4BQ (PA28-180) |
hot. I made it a point to fly over Death Valley on the way back from SFO, just so that I could fly below sea level. I wanted to see the expression on my altimeter's face. It looked bewildered. It was August; temp was well over 100 F. I decided not to land. vince norris |
Displaced AFSS "controllers" heading for BIL and GRB | Chip Jones | Instrument Flight Rules | 12 | April 10th 05 09:22 PM |
Outside loops in a Decathlon | [email protected] | Aerobatics | 12 | March 8th 05 07:14 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
PIREP--CO Experts low level carbon monoxide detector | Jay Honeck | Piloting | 10 | December 3rd 04 11:21 AM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
