Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Outside loops in a Decathlon
Old January 26th 05, 11:51 PM
Default Outside loops in a Decathlon
I am relatively new to aerobatics, and I have been flying only positive
manuevers so far. I am flying a 1978 Decathlon with wooden wings. Can
some one give me some tips on flying an outside loop? Things to be
mindful of, and so on? I have the entry speeds from the POH.
Old January 27th 05, 06:44 PM
ShawnD2112
Start with a half loop up, it's less frightening. Start out at your entry
speed, straight and level. Roll inverted and push until you're upright at
the top. The key for me is to keep pushing!! It's a sick feeling to be
bleeding energy inverted half way up and think you're not going to make it
upright. It'll feel like the radius is really tightening up at the top, and
it is, but if you start to relax the forward pressure too soon, you'll fall
out of it.
Shawn
Old January 28th 05, 04:00 AM
Doug
Good advice; however I'd start with a few days of push to a 45 or so
degree upline, roll upright, dive to get the speed back, level off and
repeat.
If this starts feeling good to you then do the half loop up as Shawn
suggests.
The idea is to gradually condition your body to the negative G-load.
Doug
Pitts S2-C
Old January 28th 05, 05:53 AM
ShawnD2112
You could do that, bu I don't find a -3 G load to be that much of a problem.
For me it's the visuals and other cues that were a bit more disturbing when
I was starting. That's why I started with a half loop up. And, by the way,
I haven't had the guts to try a full outside loop yet!
Shawn
"Doug" wrote in message
. com...
entry speed, straight and level.
repeat.
suggests.
Doug
Pitts S2-C
Old March 2nd 05, 02:47 PM
yupyupxav
DOug,
I just arrived on this forum, but something really important is not to
pull too much positive G immediately after gone negative. -3 to +5 is
physiologically more difficult than 1 to 9. (loss of conciousness)
Xav
repeat.
suggests.
Doug
Pitts S2-C
Old March 2nd 05, 05:59 PM
Doug Carter
yupyupxav wrote:
DOug,
Xav
Great point! I suppose that the negative G load causes the blood
vessels to swell and if you go hard positive you are going to gray out
at a lower G load. I can really feel this difference.
Old March 8th 05, 05:50 PM
Andrew Boyd
Suggested training program:
Exercise #1: from level upright, 1/2 roll inverted, pause,
then push to 45 up inverted. Pause. 1/2 roll to upright
45 up. Gently lower nose to level upright again. Descend
to regain airspeed. Repeat.
Exercise #2: from level upright, 1/2 roll inverted. Push
past 45 up to vertical upline. Hammerhead to vertical
downline, pull level. Repeat.
Exercise #3: from level upright, 1/2 roll inverted. Push
past 45 up, past vertical to level upright, completing
1/2 outside loop up. Pause without sagging. Descend to
Exercise #4: from level upright, 1/2 roll inverted. Push
past 45 up, past vertical, past level upright to 45 downline,
upright. Pause. Pull level. Not much different than #3, really.
Exercise #5: from level upright, 1/2 roll inverted. Push
upright. 1/2 roll inverted on 45 downline. Push to level
inverted. Repeat - you can skip 1/2 roll on entry. You
are now doing a full outside 1/2 cuban-8.
Exercise #6: from level upright, 1/2 roll inverted. Push
past 45 up, past vertical, past level upright, past 45 downline,
past vertical downline - don't hesitate - to level inverted.
You've just completed your first solo outside loop!
As others have mentioned, a pull right after a push is a
sure-fire G-loc trap.
ATP www.pittspecials.com/images/takeoff.jpg
"Contests? We don't need no stinkin' contests!"
Old January 27th 05, 09:36 PM
What type of suggestions have you gotten from your instructor?
Dave
Old January 27th 05, 10:50 PM
Thanks Shawn. Does it feel like you have to apply a lot more stick
force than the inside loop? I would assume so since it takes some
input to fly level inverted without retrimming.
Dave, I am not suprised by your post, but do you really think I need my
question answered with a question? My instructor does not teach any
outside manuevers, as he normally flies a Citabria. Other options for
instructors are a very long way away and expensive. What does your
instructor suggest Dave?
Old January 28th 05, 04:13 PM
Why are you not suprised by my post? The reason I asked the question
was because as a relatively new acro pilot myself who isn't anywhere
near inverted loops I was curious about what advice your primary
instructor had given you, perhaps based on what he was seeing during
your lesson. I've posted numerous times asking for advice, but
sometimes find that the best responses come when I give others an idea
of how my current instructor is having me do something. Therefore I
was in no way implying that you should only listen to your instructor
and avoid asking on this group.
Dave
Info regarding Super Decathlon Markus Feyerabend Aerobatics 10 September 4th 04 07:03 AM
inverted spin recovery explanation Alan Wood Aerobatics 18 August 19th 04 03:32 PM
Snaps in the Decathlon Dave Russell Aerobatics 12 April 14th 04 06:14 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 07:27 AM
