Aluckyguess wrote:
I am getting over 500ft. difference and more. "Matt Whiting" wrote in message ... Aluckyguess wrote: How come the GPS reads a different altitude than the Altimeter? For many reasons. The main reason is that they derive altitude by two completely different methods and this inevitably introduces errors. Then each method has its own inherent errors. Even two altimeters side by side won't read the same altitude other than by accident. Matt GPS altitude is not accurate. That is why you need to have a baro sensor included as input to a IFR approved GPS. -- Regards, Ross C-172F 180HP KSWI |
![]() Ross Richardson wrote: GPS altitude is not accurate. .... except when it is, which is most of the time. That is why you need to have a baro sensor included as input to a IFR approved GPS. That baro input is used as a cross-check for gross errors, to assist RAIM. It does not "correct" inaccuracy, and thus is irrelevant to the normal GPS altitude readout. - FChE |
GREAT AVIATION READS | Cribsheet | Piloting | 1 | September 12th 04 02:51 AM |
GREAT AVIATION READS | Cribsheet | Rotorcraft | 0 | September 10th 04 06:06 PM |
GREAT AVIATION READS | Cribsheet | Military Aviation | 0 | September 7th 04 06:37 PM |
When the ASI Reads Below Zero | BTIZ | Piloting | 11 | August 23rd 04 04:57 PM |
Newsweek Reads RAM! | Bob McKellar | Military Aviation | 0 | February 17th 04 02:10 AM |
