Test Q's
Old June 14th 05, 08:16 PM
George Patterson
jsmith wrote:
There is a movie documenting Richard Bach's late-70's barnstorming trip
around the country with a pair of Fleet biplanes (same name as the book,
but I cannot remember what the title is). In one segment, he attaches
flares to the wingtips and goes flying, ignites the flares and in the
course of the flight, stalls and spins the aircraft. It is at this point
the a picture makes clear what is happening with the wings.
The smoke from the flare on the outside (flying) wing streams behind the
wingtip, while the smoke from the flare on the inside (stalled) wing
wafts slowly upward. This was filmed from the air from the accompanying
aircraft.
It would be more helpful if someone placed the smoke generators about mid-span
so that the smoke passed over the wing. That would be a much more accurate
indication of how well the outside wing was actually flying.
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
Old June 15th 05, 11:58 PM
NoGoals
aircraft.
Correct me if I'm wrong (it happened once b-4) but a stalled wing is
one which is not producing enuf lift to hold up the associated weight.
A stalled wing can still be moving forward, even as it falls toward
Momma Earth. Also, in a spin don't you always have one wing rotaring
around a point defined by the lower wingtip? The smoke in the above
example acts exactly as I would expect it to.
I'd answer A.
BTW, does anyone know what answer the FAA considers correct???
---Hilarious!!!!
Old June 16th 05, 02:42 AM
George Patterson
A stalled wing is one in which the airflow has separated from the upper surface
of the wing. It may indeed still be moving forward. Blow smoke across a stalled
wing and you can clearly see the burble in the airflow over the surface. Smoke
generators at the wingtips will not show whether a wing has stalled or not.
George Patterson
Post Test Web to Usenet Guest Naval Aviation 0 April 22nd 05 03:43 AM
Air Force conducts live test of MOAB Otis Willie Military Aviation 0 November 21st 03 10:45 PM
FAA Knowledge Test Results Richard Moore Instrument Flight Rules 4 October 12th 03 07:10 AM
FAA Knowledge Test Results Richard Moore Simulators 3 October 12th 03 04:48 AM
