None of the a/c flown by most of us can be 'flown' while stalled no matter how much engine power is applied.
Then what am I doing when I practice stalls at altitude, holding the aircraft at the stall buffet? I suppose that's not fully stalled yet, and when it does fully stall I would lose altitude, but ok, fly it juat above this speed (unstalled) six inches above the runway, and reduce power. I don't reccomend this, but put it out since it would not be impossible to do, and would result in a full stall greaser if all conditions were right. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Recently, Jose posted:
None of the a/c flown by most of us can be 'flown' while stalled no matter how much engine power is applied. Then what am I doing when I practice stalls at altitude, holding the aircraft at the stall buffet? You're holding the aircraft at just above the stall speed. When you're stalled, you're falling, not flying. What I thought you were describing in your earlier post was there is adequate power to remain in flight strictly on the engine alone. Think F-18, not C-172. ;-) I don't reccomend this, but put it out since it would not be impossible to do, and would result in a full stall greaser if all conditions were right. What you seem to describing now is one where you reach stall speed at exactly the point where your wheels touch down. What's the point in that, when you can grease it on at 2-3 kts above stall without the risk of being wrong and dropping, or hitting a gust and being lifted a few feet and *then* dropping because you don't have the airspeed to fly? Neil |
exactly the point where your wheels touch down. What's the point in that, when you can grease it on at 2-3 kts above stall without the risk of being wrong and dropping, or hitting a gust and being lifted a few feet and *then* dropping because you don't have the airspeed to fly? I was taking issue with the idea that a greaser full stall landing is self-contradictory. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose wrote:
I was taking issue with the idea that a greaser full stall landing is self-contradictory. Well, lot's of semantic problems in this whole discussion. I would say that what people commonly *call* a full stall is not a good way to grease it on. I would also say that what is called a full stall landing is actually a landing where power is off, and the plane is at an attitude and speed where you run out of elevator authority just as you touch the ground - perhaps the wing is stalled but what I think is that the nose is simply dropping to continue flying as you run out of elevator. The only way out of this is to add power or let the nose drop until more airspeed is gained. I can do this in the Maule when I make a minimum speed approach, flare at the right moment, and touch the ground just as the wheel is pulled all the way back. Not a good way to grease it on but it is wonderful thing when it happens. Normally, I come in at a normal approach speed, flare to the 3 point attitude and touch down. If I pull back too far or too fast, I can and will touch the tailwheel first. So I agree that what we think of as a full stall landing, can be greased on. It's just not the best way. I also suggest that the idea of holding it off with power at a high angle of attack (dragging it in) is neither a 'full stall landing' nor a good way to grease it. Perhaps just a different perspective. |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 03:01 PM |
Flight instructors as Charter Pilots | C J Campbell | Piloting | 6 | January 24th 04 07:51 AM |
