Handhelds?
Old June 15th 05, 08:35 PM
Ben Hallert
I know a pilot who described handheld radios as a container for storing
dead batteries. I'd personally invest in a nice aviation GPS before a
handheld, especially if I have dual comms in my plane, but that's just
me.
Regards, and good luck!
Ben Hallert
PP-ASEL
Old June 16th 05, 09:38 AM
Greg Farris
In article .com,
says...
me.
Maybe - maybe not.
I've carried a handheld for years now, and it's never seen any "serious"
use. I use it to listen to ATIS and traffic when doing a preflight,
before switching on the aircraft's battery and avionics master - but
that's just "because it's there" kind of use, and also serves a s a
check to make sure the thing itself is working.
I have however, on two recent occasions taken the thing out of my flight
bag during flight. The first was an issue with a bad PTT switch. I ended
up plugging my headset into the co-pilot's position, and using the other
PTT switch, but I probably would have been just as well off using my
ICOM headset adapter, and not had the wire pulling on my head!
The other was a rental 172 with dodgy VOR's. With Com1 completely dead,
and Com2 "apparently" OK, I was able to use the VOR function of the
handheld to emulate the KX155A's "to" and "from" modes that I've gotten
used to, as well as a cross-check for the aircraft's VOR indicator I had
little confidence in. Turned out OK, and the flight would have been the
same without the handheld, but I realized the VOR indicator I had always
thought to be a useless gimmick actually does work.
So now, even though it's one of the least used items, I have upgraded it
to "essential" status in my personal rating, and wouldn't want to go
further than a local flight without it.
I concur you will not usually pick up much of anything on the ground, as
soon as you get a few miles from the airport. I can't even tell if mine
is working correctly until I get to the airport.
Old June 17th 05, 05:54 AM
Bryan Mason
me.
As a student, I found a handheld very useful for hanging around the
airport, listening to the radio traffic, and then correlating it to the
positions of the actual traffic.
It's also very handy for calling for fuel. :^)
-- Bryan
Vertex Handhelds Jeff Franks Piloting 20 November 28th 04 02:10 PM
What's next for Garmin handhelds? NEW 296 MichaelR Piloting 3 March 19th 04 12:50 PM
What's next for Garmin handhelds? Mike Rapoport Piloting 13 March 6th 04 03:58 PM
Handhelds and alkaline batteries Ross Richardson Piloting 44 August 10th 03 12:17 AM
