Ray Andraka wrote: The reason for the change is to comply with an initiative to prepare the ILS approaches for RNAV. Part of that initiative requires the location of the glideslope to be at an a 100' interval. Most OM's are not, and it is too expensive to move them, so Ohhhh, this must explain why HIO ILS 12 no longer uses ABATE LOM. I had assumed that the few hundred feet they tacked onto 12/30 had made it too close to the threshold (though that was obviously a stretch!). -- Ben Jackson http://www.ben.com/ |
How are the intersections it now uses identified? DME or a crossing radial?
Ben Jackson wrote: In article , Ray Andraka wrote: The reason for the change is to comply with an initiative to prepare the ILS approaches for RNAV. Part of that initiative requires the location of the glideslope to be at an a 100' interval. Most OM's are not, and it is too expensive to move them, so Ohhhh, this must explain why HIO ILS 12 no longer uses ABATE LOM. I had assumed that the few hundred feet they tacked onto 12/30 had made it too close to the threshold (though that was obviously a stretch!). -- Ben Jackson http://www.ben.com/ -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Ray Andraka wrote: Ben Jackson wrote: Ohhhh, this must explain why HIO ILS 12 no longer uses ABATE LOM. How are the intersections it now uses identified? DME or a crossing radial? If you google it you can see a thread I started about that very thing a few weeks ago. I think the new intersection is COUVE (coo-vee) and it's on the localizer and it's identified by radials off of UBG and BTG, both more than 30 degrees away from perpendicular. There's also a DME distance from UBG. -- Ben Jackson http://www.ben.com/ |
THe guy who designed the new charts for Providence, Bob Llewellyn, told me
that crossing radials are used if they meet the criteria. I thought he said 30 degrees, but it might have been an angle greater than 30 degrees to the course. The only navaids here that might work are Norwich (ORW), and Putnam (PUT). I think there may be a distance limitation as well, which probably rules out PUT and possibly ORW as well. Ben Jackson wrote: In article , Ray Andraka wrote: Ben Jackson wrote: Ohhhh, this must explain why HIO ILS 12 no longer uses ABATE LOM. How are the intersections it now uses identified? DME or a crossing radial? If you google it you can see a thread I started about that very thing a few weeks ago. I think the new intersection is COUVE (coo-vee) and it's on the localizer and it's identified by radials off of UBG and BTG, both more than 30 degrees away from perpendicular. There's also a DME distance from UBG. -- Ben Jackson http://www.ben.com/ -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 05:22 PM |
