Who does flight plans?
Old June 16th 05, 04:12 PM
Maule Driver
You're right. It definitely isn't stalled. And it doesn't like that
technique.
T o d d P a t t i s t wrote:
And I suspect the wings would not be stalled even with the
tailwheel touching first as you describe. Usually what
happens is the tail touches before stall, which rotates the
nose down, decreasing wing lift and forcing the touchdown.
If you want to get closer to a true stall at landing, you'd
probably want to come in about a foot or two higher and
really get the nose up before touching the tail. Of course
your Maule probably wouldn't be so happy with that technique
(first handbook issued with the Curtis-Wright flyer)
  #112
Old June 16th 05, 04:20 PM
Maule Driver
Maules are not happy with that technique. When a Maule is in three-point
attitude, it is not stalled. Power-off stall in no-wind conditions
occurs when the mains are about 6" higher than the tailwheel.
Agreed.
The condition that people *call* a full stall landing can be achieved in
the Maule by doing this, "...make a minimum speed approach, flare at the
right moment, and touch the ground just as the wheel is pulled all the
way back. Not a good way to grease it on but it is wonderful thing when
it happens". The key being 'minimum speed approach' in a power-off
condition.
I don't think it's stalled in that configuration because if I add just a
little power, I can continue to bring the nose up and float, and even
touch down tail first. But if you leave the power off, the nose will
not come up any further and begin to fall. Just no more elevator authority.
  #113
Old June 16th 05, 04:51 PM
Neil Gould
Recently, T o d d P a t t i s t posted:
"Neil Gould" wrote:
There is no requirement that
there be a nose-high attitude in a stall,
Ah, but here we're talking about a landing, and that means
that the path of the aircraft has to be nearly parallel to
the ground (otherwise it's called "crashing" :-)
Well, that is what my original response addressed. If Jose & Matt were
truly doing "full-stall" landings, the likelihood that they'd be greasers
would be fairly low. OTOH, the likelihood that they'd be grease marks on
the runway would increase dramatically. ;-)
Neil
  #114
Old June 16th 05, 07:58 PM
Peter Duniho
"Neil Gould" wrote in message
[...] So, in context, how is your theoretically available lift relevant?
It is relevant only to your false claim that a stalled wing provides no
lift. Had you not made that false claim, I would have had no reason to
bring up that element of the discussion.
To be a scalar, it would have to lack motion, ergo no "attack".
Wrong. "To be a scalar" it needs to be a single value. And it is.
Angle-of-attack is just an angle. A single value.
Every angle requires two reference lines in order to define that angle.
That doesn't change the fact that the angle itself is a single value,
without any direction component. Likewise, the fact that two reference
lines (one defined by a direction of travel) are used to define
angle-of-attack DOES NOT MAKE ANGLE-OF-ATTACK ITSELF A VECTOR. It's still
just an angle.
I responded to that. In the context of landing, if one flies slowly
enough to stall, one can stall "flat" relative to the ground because
the decrease in forward "relative wind" increases the AOA. That is
what my remark addresses.
Your claim is incorrect. As long as the airplane is flying just
above the ground, the relative wind is parallel to the ground. No
change in the angle-of-attack will occur from any decrease in speed,
not directly.
My claim is that if the aircraft is flying parallel to the ground just
before touch-down, it isn't stalled.
That's a new claim. Your previous claim (quoted above) was that you COULD
stall while flying parallel to the ground. That is, one could "stall
'flat'".
In any case, other than the issue with the geometry of the airplane, there
is absolutely no justification in claiming that flight parallel to the
ground precludes a stall.
It is simply impossible to do what you suggest one might do. If one
"flies slowly enough to stall", the angle-of-attack is at the stalling
angle-of-attack, period.
And all I'm saying is that this is independent of the pitch angle relative
to the ground.
It is NOT independent of the pitch angle relative to the ground if the
airplane is being flown in a flight path parallel to the ground.
What WILL happen is that as the aircraft slows, the pitch angle of the
aircraft will need to be increased, so as to continually increase the
angle-of-attack of the wing.
We are describing the same phenomena from two perspectives.
I am fairly certain we're not.
In the context
of my usage, if one maintains the pitch angle as the aircraft slows, the
AOA will continually increase (normally, the pitch angle changes as the
aircraft slows).
You cannot "maintain the pitch angle as the aircraft slows" without touching
the runway. If the aircraft slows and the pitch angle is not changed, lift
is reduced and the airplane will descend onto the runway.
I'll say it again: the scenario you propose is an impossibility.
Pete
  #115
Old June 16th 05, 09:23 PM
Neil Gould
Recently, Peter Duniho posted:
relevant?
no lift. Had you not made that false claim, I would have had no
reason to bring up that element of the discussion.
The only falsity here is your claim that I made such a statement. So,
apparently you have no reason to bring up that element in the discussion.
What I *did* claim is:
"You're holding the aircraft at just above the stall speed. When you're
stalled, you're falling, not flying."
This makes *no* reference to the amount of lift that a stalled wing
provides beyond it being inadequate to support flight, which should be
obvious to one who pays so much attention to details as you.
Wrong. A scalar can not contain elements of direction by definition. Ergo,
AOA has no meaning as a scalar.
angle. That doesn't change the fact that the angle itself is a single
value, without any direction component. Likewise, the fact that two
reference lines (one defined by a direction of travel) are used to
define angle-of-attack DOES NOT MAKE ANGLE-OF-ATTACK ITSELF A VECTOR.
It's still just an angle.
Wrong, it's AOA only has meaning when referenced by a direction and
motion. Without that direction and motion, THERE IS NO ANGLE OF ATTACK. If
you still don't understand this, what is the AOA when the aircraft is
parked in the hangar (with the doors closed and no fans running, if you
insist on picking nits)? ;-)
Finally, when you apply a direction to a scalar, what does it become?
because the decrease in forward "relative wind" increases the AOA.
That is what my remark addresses.
not directly.
just before touch-down, it isn't stalled.
That's a new claim.
Wrong, that's my original claim:
Jose: " Then what am I doing when I practice stalls at altitude, holding
the aircraft at the stall buffet?"
I wrote: "You're holding the aircraft at just above the stall speed."
COULD stall while flying parallel to the ground. That is, one could
"stall 'flat'".
Again, I made no such statement. My above claim is actually a
clarification of my original statement for your benefit.
My "stall flat" comment refers to pitch angle relative to the ground (as
was stated in the same paragraph). I made no claim about travelling
parallel to the runway. Indeed, one would *not* be going parallel to the
ground in a flat stall.
there is absolutely no justification in claiming that flight parallel
to the ground precludes a stall.
I made no such claim as this, either.
stalling angle-of-attack, period.
relative to the ground.
Again, "a flight path parallel to the ground" is *your* assumption, and
not a claim of mine. A flight path parallel to the ground, but with a high
AOA is Todd's assumption, and again not a claim of mine. I have no problem
with these scenarios, they just have nothing to do with what I've written.
the aircraft will need to be increased, so as to continually
increase the angle-of-attack of the wing.
I am fairly certain that you are confused about this.
In the context
the AOA will continually increase (normally, the pitch angle changes
as the aircraft slows).
touching the runway. If the aircraft slows and the pitch angle is
not changed, lift is reduced and the airplane will descend onto the
runway.
That is NOT incongrous with what I've written. The aircraft "descends"
because the AOA increases as the aircraft slows and the pitch angle is
maintained. Do you *really* disagree with this?
And, I'll say it again, you are confused about what I've written. You've
repeatedly attributed claims to me that I never made, and set up straw men
that have nothing to do with the issue at hand.
Neil
  #116
Old June 16th 05, 10:15 PM
Gary Drescher
Interestingly enough, a stall occurs at the critical angle of attack, which
is the AOA at which the coefficient of lift is the *maximum possible*. Just
past the critical angle of attack (that is, further into the stall), the
lift coefficient is no longer maximal, but is still well above what it is in
ordinary cruise flight.
What *does* happen just past the critical AOA--that is, just into the
stall--is *not* that there's insufficient lift to support the plane's
weight, but rather that there's a loss of *vertical damping*. John Denker (a
physicist and a pilot) has a nice explanation he
http://www.av8n.com/how/htm/vdamp.ht...rtical-damping.
No, an angle is unquestionably a scalar, not a vector. Check any
introductory math text. If an angle were a vector, then a symbol
representing an angle would be set in boldface; but it is not.
You're right that an angle is defined by reference to vectors, but so is
(for example) the *dot product* of two vectors (yet the dot product is a
scalar); or so is the *magnitude* of a vector (but the magnitude is a
scalar). So being defined by reference to vectors does not preclude a
quantity from being scalar.
--Gary
  #117
Old June 17th 05, 08:30 AM
Roger
On Wed, 15 Jun 2005 13:52:58 GMT, Maule Driver
You are kidding, right?
None of the a/c flown by most of us can be 'flown' while stalled no
matter how much engine power is applied. They may be flown below normal
stall speed in such a config but they are not stalled. They can be
'dragged in' below stall speed and even smoothly landed, but not
stalled. And with power-on, the stall will probably be more exciting.
Most of my landings are "full stall". The horn goes off whitht he
nose way "up there", then the stall breaks. Being that close to the
runway it just drops onto the mains, nose high.
But I agree. Once that wind stalls you are not going to stay up there.
If you don't come down the wing isn't stalled.
www.rogerhalstead.com
Stall speed and a stalled wing are 2 different things. Right?
Jose wrote:
If you have enough speed to grease it on, you're not even close to a
stall.
While this may be generally the case, it is not of necessity true. One
can stall and maintain altitude (with power). Maintain one foot of
altitude, and gradually reduce power on a calm day. Greaser.
Jose
  #118
Old June 17th 05, 08:37 AM
Roger
On Thu, 2 Jun 2005 22:24:29 -0600, "Michael 182"
I'm kind of curious - does anyone with more than 100 hours do a flight plan,
with winds and all, before they fly cross country? Most of my planning is of
the fuel stop, or occasionally detour for weather variety - but it is rare
for me to include more than one or two waypoints in my "plan", and I almost
never file an airway, even when I file ifr. Maybe it's because I live in the
west. A typical flight plan will be Longmont - Amarillo - Austin, or if the
winds are good, Longmont - Austin. What do others do?
If you mean a complete, on paper flight plan then no I don't.
OTOH, I get a DUATs briefing and then talk to FSS prior to departure.
I file IFR. VRF I rarely talk to any one, but that depends on the
area(s) through which I'm going to fly.
I either print the charts, or have the standard Sectionals and Low
Altitude charts along with the approach charts whether going IFR or
VFR. Even printing out a detailed route chart is only a guide, so
it's about as easy for me to just use a chart as except for direct I
usually get rerouted any way.
So, I have an unofficial flight plan and I do print out the IFR
routes, but 9 times out of 10 I go direct and I can figure the times
and headings in my head.
Michael
  #119
Old June 17th 05, 12:10 PM
Neil Gould
Recently, Gary Drescher posted:
which is the AOA at which the coefficient of lift is the *maximum
possible*. Just past the critical angle of attack (that is, further
into the stall), the lift coefficient is no longer maximal, but is
still well above what it is in ordinary cruise flight.
Denker (a physicist and a pilot) has a nice explanation he
Thanks for that! I'm not sure that resolves the issue of trying to land
with these parameters.
Ergo, AOA has no meaning as a scalar.
Mathematically, an "angle" by itself *is* a scalar, and I'm not arguing
otherwise. I'm saying that "Angle Of Attack" requires direction to have
meaning. Without direction, there is no AOA.
is (for example) the *dot product* of two vectors (yet the dot
product is a scalar); or so is the *magnitude* of a vector (but the
magnitude is a scalar). So being defined by reference to vectors does
not preclude a quantity from being scalar.
Well, OK. Then, how do you determine the AOA when the aircraft is parked?
If the component of direction is inseparable from the definition of AOA,
how can it be a scalar?
Neil
  #120
Old June 17th 05, 02:21 PM
Jose
How long is it between 11 AM and 1:30 PM? The answer is 150 minutes.
Now, is that 150 minutes AM or 150 minutes PM?
In order to form the difference, you NEED to know whether the original
times are AM or PM, but the result is a pure number of minutes. 11 AM
is a =time of day=, 1:30 pm is a =time of day= but the difference is
=not= a time of day, it is just a number (of minutes).
In a similar vein, in order to form an angle (a pure number), you need
to have not just one direction, but two. You need TWO quantites that
have direction (they don't even have to have magnitude!). However, the
result (the angle between them) has no direction (beyond the algebraic
sign).
When you say:
meaning.
all you're really saying is that you don't have an angle of attack if
you don't have the requisite components (a relative wind, and a chord).
But don't confuse the components with the result. Area is made up of
length and width, but area is not in itself one dimesional. Cakes are
made with raw eggs and flour, but I'm not likely to confuse the two any
time soon.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain."
(chapter 10 of book 3 - Harry Potter).
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
WINGS: When do the clocks start ticking? Andrew Gideon Piloting 6 February 3rd 04 03:01 PM
Flight instructors as Charter Pilots C J Campbell Piloting 6 January 24th 04 07:51 AM
