How about posting it somewhere - I'd like to see it as well.
Ron Webb Hello Giles, I have a copy of it here at home. I'll look for it for you. Let me know your address. I got the copy from Wright Patterson AFB library in Dayton Ohio. |
Ron Webb wrote:
How about posting it somewhere - I'd like to see it as well. Ron Webb Sure that's a good idea. What's the usual method? Taking a digital photo of it? -- Saville Replicas of 15th-19th century nautical navigational instruments: http://home.comcast.net/~saville/backstaffhome.html Restoration of my 82 year old Herreshoff S-Boat sailboat: http://home.comcast.net/~saville/SBOATrestore.htm Steambending FAQ with photos: http://home.comcast.net/~saville/Steambend.htm |
gregg a écrit :
Ron Webb wrote: How about posting it somewhere - I'd like to see it as well. Ron Webb Sure that's a good idea. What's the usual method? Taking a digital photo of it? Hi Gregg and all, A 200 dpi scan in JPEG format usually gives fairly correct results, provided the JPEG compression isn't set too high. Each page is then a 1 Mb image. Best regards, Gilles |
On Mon, 20 Jun 2005, GTH wrote:
A 200 dpi scan in JPEG format usually gives fairly correct results, provided the JPEG compression isn't set too high. Each page is then a 1 Mb image. JPG uses "lossy" compression (loses some data for the sake of better compression), which is fine for photos. But with the compression set low (higher number, nearer 100, 75 being considered normal) so you lose less data, the file size gets pretty big. Better to use a format with lossless compression, like GIF or TIF, for anything other than photos. They'll give better reproduction, and usually smaller files. -Dan |
