![]() "Chris G." nospam@noemail wrote in message eenews.net... The local FSDO helped me quite a bit in finding the references I need. Look in FAA Order 7110.65 Para. 10-2-5 (2b). I've quoted it for your convenience and the link is provided. It references Jay's specific situation. http://www.faa.gov/ATpubs/ATC/Chp10/atc1002.html#10-2-5 That reference was posted in this thread yesterday. |
![]() "Peter Duniho" wrote in message ... I have never seen any documentation of this claim, for VFR aircraft. My understanding is that the scenario in this thread was motivated solely at the discretion of the controller, that there is no automatic search and rescue for abnormally terminated flight following, and that only a VFR flight plan guarantees a search and rescue attempt for missing VFR flights. Can you provide a reference to something that supports the idea that airplanes getting VFR flight following are given automatic search and rescue if they somehow are "lost" from the controller (either radio or radar contact lost)? http://www.faa.gov/atpubs/ATC/Chp10/atc1002.html#10-2-5 See subparagraph b. He didn't get it quite right. ATC must initiate a search when there is an UNEXPECTED loss of radar contact AND radio communications. If the losses occur in an area where it's normal to lose them ATC isn't required to do anything. |
ink.net... http://www.faa.gov/atpubs/ATC/Chp10/atc1002.html#10-2-5 See subparagraph b. He didn't get it quite right. ATC must initiate a search when there is an UNEXPECTED loss of radar contact AND radio communications. If the losses occur in an area where it's normal to lose them ATC isn't required to do anything. Thanks. Interesting. I assume that somewhere buried in the chain of "inform the/alert the..." there's someone who actually starts the search and rescue proceedings? Given that both radar contact and radio communications must be lost, and given that losing both unexpectedly is sufficient to cause an emergency to be assumed, what is the maximum amount of time between the two events that can happen while still defining an emergency? That is, suppose radio communications are ceased but radar contact is still present. Suppose further that the pilot eventually lands somewhere, at some point descending low enough to no longer be on radar. It seems obvious to me that if the pilot flies out of the controller's sector, or some lengthy period of time goes by (30 minutes? 60 minutes?), that the controller might be able to assume there's no emergency, while near-simultaneous loss of radio and radar would constitute an emergency. Somewhere in between there must be a point where the assumed emergency is no longer an assumed emergency. Is that point well-defined, or does the controller make a judgment call? Finally, what constitutes radar contact? Is a primary return sufficient? What about a 1200 transponder return? If a 1200 transponder return is sufficient, what happens if THAT radar contact is lost within the time limit I asked about above? Can the controller assume that the pilot switching from his assigned code to 1200 has terminated flight following? Does the switch to 1200 make any loss of radio communications and radar contact "expected", or could the controller be obligated to declare an emergency even if the transponder has been set to 1200 unexpectedly and then radar contact is lost altogether? Pete |
![]() Peter Duniho wrote: I have never seen any documentation of this claim, for VFR aircraft. Nope, if you are unexpectedly lost then ATC will start a search immediatley. |
![]() "Chris G." nospam@noemail wrote in message eenews.net... The way the SAR system works is that once the FAA has radar contact with you and are providing radar services, they will continue to do so unless they are unable (due to lack of radar coverage) or you cancel them. If you fall below their radar coverage while utilizing their services, then they begin the SAR process. That's not quite correct. They initiate SAR when there is UNEXPECTED loss of radar contact and radio communications. |
Jay,
You got good service from a controller who got worried about you. Now, quit messing around; with that very capable airplane and all the flying you do, get your instrument rating. It'll also help your VFR travel and dealing with ATC. Besides, the workload IFR is much, much less than VFR when you're dealing with weather such as you had and also having to figure out airspace and so forth. I've had a controller get hold of a small airport when I had a total electrical failure on an IFR flight plan. In and out of the clouds, saw an airport below me, spiraled down and landed. As I parked, the airport manager came out to make sure I was okay and said CVG approach had called and was concerned. I called the controller back, told him what was going on and thanked him for making the call to have someone looking out for me. It was a very nice feeling on an afternoon when the airplane was in the midst of what turned out to be a reaction to a stupid wiring job done by someone years before that was finally coming due as insulation was scraping off of poorly routed wires. (In fact, it was the only good thing that happened that afternoon-figuring out the problem and repairing it wasn't cheap.) Warmest regards, Rick |
![]() "Jay Honeck" wrote in message ps.com... Now that I think about it, I suppose we could have asked Flight Watch to notify Chicago Center when we could no longer hear them, but frankly it never dawned on me that Chicago really cared that much about what happened outside of their Class B airspace. First, Chicago Center doesn't give a crap what happens in the Chicago Class B. Ah, true enough. I have mistakenly been using the terms "Approach" and "Center" interchangeably in this thread. "Chicago Center" is always cooperative and helpful, and will unfailingly provide flight following all the way to Iowa City (if we're high enough, which we rarely are) if requested. "Chicago Approach" is the ATC facility in question here. They are the ones who called the Rantoul airport manager, and they are the ones who usually will not provide VFR flight following. Which is why I was (and am) so surprised that they actually took the time to call Rantoul when we lost radio contact with them. They are usually not so helpful. -- Jay Honeck Iowa City Jay, you've got the plane and you travel in it enough. Break down and get your IFR ticket. GigG |
![]() "Jay Honeck" wrote in message ps.com... Ah, true enough. I have mistakenly been using the terms "Approach" and "Center" interchangeably in this thread. "Chicago Center" is always cooperative and helpful, and will unfailingly provide flight following all the way to Iowa City (if we're high enough, which we rarely are) if requested. "Chicago Approach" is the ATC facility in question here. They are the ones who called the Rantoul airport manager, and they are the ones who usually will not provide VFR flight following. Which is why I was (and am) so surprised that they actually took the time to call Rantoul when we lost radio contact with them. They are usually not so helpful. Ehh? Rantoul is well outside Chicago Approach airspace. Rantoul is in Champaign Approach airspace which is assumed by Chicago Center when Champaign closes for the night. |
![]() "Ron Natalie" wrote in message ... I've had radar facilities chase me down after I've lost comms with them during VFR FF. They want to make sure they didn't lose you and something bad happened to you (like you crashed). Just consider it an extra service. It's not necessarily an extra service. If radio and radar contact is lost in an area where ATC would expect to have both, then ATC is supposed to chase you down. http://www.faa.gov/atpubs/ATC/Chp10/atc1002.html#10-2-5 |
![]() Ron Natalie wrote: I've had radar facilities chase me down after I've lost comms with them during VFR FF. They want to make sure they didn't lose you and something bad happened to you (like you crashed). Just consider it an extra service. It is a required service. If they lose you unexpectedly ATC is required to start a search. In Jay's case he was cruising merrily along, asked to switch to Flight Watch and then disappeared. Meanwhile Center is watching Jay descend and can't get a hold of him. Pretty soon he drops off radar. So call the most likely spot, the airport. If the manager wouldn't have found him then SAR would have been started. |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
