Off topic, but related: Can a radar center offer flight following to a
plane not equipped with a transponder? I would guess no, but I'm curious. tom pettit "Bob Gardner" wrote in message ... Sorry to hear that you have had bad experiences with FF in your area...it is a valuable tool that should be used by everyone. Bob Gardner |
plane not equipped with a transponder? I would guess no, but I'm curious. I think that you can have an IFR clearance and at points along the route not be in radar coverage. In those cases you get a much larger zone of protected airspace around you, and you have to radio in your position at compulsory reporting points. As for flight following, I would think the value would be pretty much useless. The whole point is to gain a second pair of eyes for you on the ground with the assumption that you are still responsible for separation from other aircraft. If the folks on the ground can't see you on their scopes, then there's really no point to flight following. -- Guy |
Guy Elden Jr wrote:
As for flight following, I would think the value would be pretty much useless. The whole point is to gain a second pair of eyes for you on the ground with the assumption that you are still responsible for separation from other aircraft. If the folks on the ground can't see you on their scopes, then there's really no point to flight following. You will appear on the scopes (provided the primary radar is functional) but it's probably more trouble than it is worth to the controller to track you. |
That's what I figured. The lack of a squawk code on their screen would mean
they would have to keep on top of my blip, or they wouldn't know it was me. I also suspect that in mountainous terrain, the return on primary would not be as strong as from a transponder. tom "Ron Natalie" wrote in message ... Guy Elden Jr wrote: As for flight following, I would think the value would be pretty much useless. The whole point is to gain a second pair of eyes for you on the ground with the assumption that you are still responsible for separation from other aircraft. If the folks on the ground can't see you on their scopes, then there's really no point to flight following. You will appear on the scopes (provided the primary radar is functional) but it's probably more trouble than it is worth to the controller to track you. |
I have gotten Flight Following without a transponder, but it was one of
those corner cases. Basically, the transponder was inoperative, but it would have required a very long flight to go around the airspace that required a transponder (a Class C up against a Mode C veil). So, we contacted ATC, advised them of our transponder issue, and asked to transition over the top of the Class C (transponder is required except by prior arrangement... which was the purpose of asking). They RADAR identified us, and followed our primary return. Indeed, they continued the service until they lost RADAR contact quite a peice out from over the Class C. -Rob Guy Elden Jr wrote: Off topic, but related: Can a radar center offer flight following to a plane not equipped with a transponder? I would guess no, but I'm curious. I think that you can have an IFR clearance and at points along the route not be in radar coverage. In those cases you get a much larger zone of protected airspace around you, and you have to radio in your position at compulsory reporting points. As for flight following, I would think the value would be pretty much useless. The whole point is to gain a second pair of eyes for you on the ground with the assumption that you are still responsible for separation from other aircraft. If the folks on the ground can't see you on their scopes, then there's really no point to flight following. -- Guy |
![]() "tom pettit peak.org" tompetat wrote in message ... Off topic, but related: Can a radar center offer flight following to a plane not equipped with a transponder? I would guess no, but I'm curious. Possible, but not practical. Some ARSR sites have only beacon interrogators. |
![]() tom pettit tompet wrote: Off topic, but related: Can a radar center offer flight following to a plane not equipped with a transponder? I would guess no, but I'm curious. Sure they can. |
How? If they have to rely on primary radar alone, then how could they
reasonably be sure they were watching the plane they thought they were? |
Ben Hallert wrote:
How? If they have to rely on primary radar alone, then how could they reasonably be sure they were watching the plane they thought they were? If it's a slow day they'll give you vectors and watch to see whether their target turns. |
Ben Hallert wrote:
How? If they have to rely on primary radar alone, then how could they reasonably be sure they were watching the plane they thought they were? By watching the blip. I've flown into Dulles with only a receiver and primary radar return (turns for identification and to indicate our intents). I've also departed Dulles with comms but with no transponder while the primary radar is out. ATC can be resourceful when they have to be. |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
