Tiedown "winch" device
Old June 22nd 05, 02:51 AM
City Dweller
Helen, thanks for the tip. I think I found the right term for those
tiedowns: "ratchet".
-- CD
"Helen Woods" wrote in message
Sporty's sells tie down kits as you describe. You can also get similar
ones in your hardware store in the section with tie down straps for
trailers although the Sporty's ones are a bit nicer.
One problem I've seen people have with them is that they don't take well
to being run over by a fuel truck if you leave them on the ground while
you are out flying. The buckles tend to squish out of shape.
Your local hardware store will also have other things you can use to make
some nice tie downs that are the proper length. My portable kit is made
out of good thick braided ropes of a distinctive color (so they won't walk
off) from Lowes with carabeners from the local kayak shop on one end. I
can use these to clip into the metal hooks in on the ramp at many
airports. Also, when I park at an airport that has too short of ropes or
ropes in ratty condition, I'll tie a loop in the existing rope and hook
one of my carbeners into the loop to use my rope as an extension.
Helen
Old June 22nd 05, 03:16 AM
George Patterson
That's one type.
I just bought tiedowns for other purposes at Home Depot. I would recommend that
you AVOID the "Workforce" brand. In fact, this is one time you might want to buy
only from an aviation supplier (or perhaps a motorcycle dealer) -- there's a lot
of trash out there.
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
Old June 22nd 05, 01:59 PM
Mike in GR
"George Patterson" wrote in message
news:AR3ue.550$2s.540@trndny02...
That's one type.
recommend that you AVOID the "Workforce" brand. In fact, this is one
time you might want to buy only from an aviation supplier (or perhaps a
motorcycle dealer) -- there's a lot of trash out there.
George Patterson
Good point,
One thing you want to watch out for is cheap webbing. Make sure you get
Nylon or Rayon. Most anything else, polypropylene in particular, will get
sunrot in short order and it isn't always easy to tell until it breaks.
Mike Z
Aerotow with Diesel engine? Olfert Cleveringa Soaring 44 November 2nd 04 10:22 AM
Winch Physics Bob Johnson Soaring 15 March 27th 04 07:33 PM
Winch design c1rrus Soaring 10 January 19th 04 12:18 PM
Coalition casualties for October Michael Petukhov Military Aviation 16 November 4th 03 11:14 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
