More info on GNS 430/530 WAAS upgrade
Old June 22nd 05, 07:15 PM
Ron Natalie
Brad Salai wrote:
I've been trying to convince my club to consider the 480 over the 530, any
thoughts on that?
If you're going to fly IFR, the 480 is the way to go. While it's (by
history) different than EVERY other Garmin GPS out there, it is more
straight forward for IFR ops.
Old June 23rd 05, 02:50 AM
Matt Barrow
any
thoughts on that?
I'd like to dump my KLN94 and go to a GPS480 with an AviDyne MX-500. One
problem is the GPS480 does not support curved flight paths (GAMA) that a GPS
430 does.
I wonder if I should go with a dual GPS in the form of a GPS 430/ 480 combo?
Would it work?
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old June 23rd 05, 01:41 PM
Ron Natalie
430 does.
It will fly them (at least it does holds, procedure turns, and DME
arcs). Maybe it doesn't reflect htem properly on the GAMA graphcis
to the AVIDYNE (I have an MX20)
Would it work?
Perhaps but confusing as hell I would think.
Old June 23rd 05, 03:42 PM
430 does.
ARINC 424 specifications provide for two different type of curved legs AF (arc to
fix) and RF (radius to fix). AF legs are for DME ARCs. RF legs are for the new,
advanced instrument approach procedures, which thus far are limited to
RNP-qualified aircraft and flight crews.
Garmin claims their panel mounts will be able to do RF legs, but I remain
skeptical. I can see it working but only in a robust installation with an
electronic HSI (where the course setting auto-slews to keep up with the RF leg's
constant course change) and with a good steering computer for either a flight
director or nav mode of the autopilot.
With an AF leg you have 4 miles of protected airspace (plus a 2 mile secondary)
each side of the ARC, so some plus-or-minus 0.5 mile zig-zagging is
insignificant. Not so with RF legs where not only is the radius of turn typically
much tighter than a DME ARC, the protected airspace may only be 0.6 of a mile each
side of centerline. And, an RF leg of one radius and direction can be immediately
followed by a different RF leg of a different radius and/or direction. This is a
much more complex flight path to manage than a DME ARC or a holding pattern
(Garmin's holding patterns are not real-world patterns in any case; rather just
symbols for holding course and turn direction.)
Old June 24th 05, 01:32 PM
Ron Natalie
With GPSS steering engaged the HSI OBS is ignored and the only reason
you need touch it is to keep the needle oriented right. It reads
left-right of course just fine even on my old steam-gage King HSI.
It seems it depends on how the autopilot gets its steering information. The most
common for light aircraft, as I understand it, is to use the value in the OBS window.
Having said that I have no doubt there are other methods of doing it with all the
technology out there.
I was talking about GPSS. It doesn't even require the aircraft to have
an HSI. The GPS talks directly to the autopilot in digital form.
They're real enough that the autopilot flies them as depicted.
That doesn't make them bear any relationship to the holding pattern containment area
provided by the procedures designer.
The procedure designer doesn't "provide the containment area." He
provides the hold based on the protected area available. The 480
flies the hold either literally as published or when not published
in a manner consistant with the TERPS guideline. Is there some
specific instance you're referring to?
Old June 23rd 05, 04:34 PM
Matt Barrow
GPS
430 does.
That's right...I should have specified that the Avidyne requires a GAMA
conection.
combo?
Would it work?
Yeah, but neither has what I want. Darn!
Old June 23rd 05, 07:22 PM
Scott Moore
430 does.
WAAS, in the long run, probally has its best advantage if it can do curved
approaches to final. This would eliminate a LOT of the clearance restrictions
on existing approaches.
Old June 23rd 05, 07:40 PM
WAAS has nothing to do with RF legs (curved approach paths). RF legs are a leg
computation done by an RNAV/LNAV platform. WAAS is an augmentation scheme for
GPS. RF legs are independent of the nav sensor, although GPS is presently the
preferred sensor for RNAV/LNAV. So, there is no reason that a TSO-C146 (WAAS/LPV)
couldn't do RF legs with, or without, WAAS and or LPV.
Having said that, I haven't heard of any proposed implementation along those lines
for WAAS and LPV.
Any inside story re 430/530 WAAS cert.? [email protected] Instrument Flight Rules 0 May 20th 05 06:13 PM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
Big News -- WAAS GPS is Operational for IFR Lockheed employee Instrument Flight Rules 87 July 30th 03 02:08 AM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
