Matt Barrow wrote:
I'd like to dump my KLN94 and go to a GPS480 with an AviDyne MX-500. One problem is the GPS480 does not support curved flight paths (GAMA) that a GPS 430 does. It will fly them (at least it does holds, procedure turns, and DME arcs). Maybe it doesn't reflect htem properly on the GAMA graphcis to the AVIDYNE (I have an MX20) I wonder if I should go with a dual GPS in the form of a GPS 430/ 480 combo? Would it work? Perhaps but confusing as hell I would think. |
![]() Ron Natalie wrote: Matt Barrow wrote: I'd like to dump my KLN94 and go to a GPS480 with an AviDyne MX-500. One problem is the GPS480 does not support curved flight paths (GAMA) that a GPS 430 does. It will fly them (at least it does holds, procedure turns, and DME arcs). Maybe it doesn't reflect htem properly on the GAMA graphcis to the AVIDYNE (I have an MX20) ARINC 424 specifications provide for two different type of curved legs AF (arc to fix) and RF (radius to fix). AF legs are for DME ARCs. RF legs are for the new, advanced instrument approach procedures, which thus far are limited to RNP-qualified aircraft and flight crews. Garmin claims their panel mounts will be able to do RF legs, but I remain skeptical. I can see it working but only in a robust installation with an electronic HSI (where the course setting auto-slews to keep up with the RF leg's constant course change) and with a good steering computer for either a flight director or nav mode of the autopilot. With an AF leg you have 4 miles of protected airspace (plus a 2 mile secondary) each side of the ARC, so some plus-or-minus 0.5 mile zig-zagging is insignificant. Not so with RF legs where not only is the radius of turn typically much tighter than a DME ARC, the protected airspace may only be 0.6 of a mile each side of centerline. And, an RF leg of one radius and direction can be immediately followed by a different RF leg of a different radius and/or direction. This is a much more complex flight path to manage than a DME ARC or a holding pattern (Garmin's holding patterns are not real-world patterns in any case; rather just symbols for holding course and turn direction.) |
![]() Ron Natalie wrote: wrote: Garmin claims their panel mounts will be able to do RF legs, but I remain skeptical. I can see it working but only in a robust installation with an electronic HSI (where the course setting auto-slews to keep up with the RF leg's constant course change) and with a good steering computer for either a flight director or nav mode of the autopilot. With GPSS steering engaged the HSI OBS is ignored and the only reason you need touch it is to keep the needle oriented right. It reads left-right of course just fine even on my old steam-gage King HSI. It seems it depends on how the autopilot gets its steering information. The most common for light aircraft, as I understand it, is to use the value in the OBS window. Having said that I have no doubt there are other methods of doing it with all the technology out there. My concern is that a pilot cannot, should not be able to hand fly an RF leg without at least a flight director providing valid steering commands. (Garmin's holding patterns are not real-world patterns in any case; rather just symbols for holding course and turn direction.) They're real enough that the autopilot flies them as depicted. That doesn't make them bear any relationship to the holding pattern containment area provided by the procedures designer. |
![]() Ron Natalie wrote: That doesn't make them bear any relationship to the holding pattern containment area provided by the procedures designer. The procedure designer doesn't "provide the containment area." He provides the hold based on the protected area available. The 480 flies the hold either literally as published or when not published in a manner consistant with the TERPS guideline. Is there some specific instance you're referring to? The procedures designer indeed provides the containment area for holding. The criteria are contained in FAA Order 7130.3A, "Holding Pattern Criteria." The forward to that handbook states, "This order primarily serves as a planning document for airspace planners by setting forth criteria for determining holding pattern airspace area dimensions and instructions for their use. In addition, it provides application criteria for use by procedures specialists in developing holding airspace for instrument procedures. Sufficient holding airspace areas shall be planned and established to meet IFR traffic requirements within a facility's area of jurisdiction. Holding airspace areas shall be determined by applying the criteria contained within this document." There are 31 different templates used for over 125 combinations of altitude, distance from facility, type of aircraft, etc. Generally, pattern sizes 4 to 13 for low altitude holding and holding pattern course reversals on IAPs. So far as I know there is no RNAV platform today that contains database information or software routines consistent with the holding patterns developed and documented by the FAA on airspace record 8260-2 (the form that documents all the details about facilities, fixes, and waypoints). As to whether a light aircraft autopilot can track an RF leg (a much, much tigher requirement than holding pattern or DME ARCs) I passed it by an avionics engineer. The autopilot has to be roll-steering based. He added that most light aircraft autopilots are not roll-steering based. |
![]() "Ron Natalie" wrote in message ... Matt Barrow wrote: I'd like to dump my KLN94 and go to a GPS480 with an AviDyne MX-500. One problem is the GPS480 does not support curved flight paths (GAMA) that a GPS 430 does. It will fly them (at least it does holds, procedure turns, and DME arcs). Maybe it doesn't reflect htem properly on the GAMA graphcis to the AVIDYNE (I have an MX20) That's right...I should have specified that the Avidyne requires a GAMA conection. I wonder if I should go with a dual GPS in the form of a GPS 430/ 480 combo? Would it work? Perhaps but confusing as hell I would think. Yeah, but neither has what I want. Darn! |
Ron Natalie wrote:
Matt Barrow wrote: I'd like to dump my KLN94 and go to a GPS480 with an AviDyne MX-500. One problem is the GPS480 does not support curved flight paths (GAMA) that a GPS 430 does. It will fly them (at least it does holds, procedure turns, and DME arcs). Maybe it doesn't reflect htem properly on the GAMA graphcis to the AVIDYNE (I have an MX20) WAAS, in the long run, probally has its best advantage if it can do curved approaches to final. This would eliminate a LOT of the clearance restrictions on existing approaches. |
![]() Scott Moore wrote: Ron Natalie wrote: WAAS, in the long run, probally has its best advantage if it can do curved approaches to final. This would eliminate a LOT of the clearance restrictions on existing approaches. WAAS has nothing to do with RF legs (curved approach paths). RF legs are a leg computation done by an RNAV/LNAV platform. WAAS is an augmentation scheme for GPS. RF legs are independent of the nav sensor, although GPS is presently the preferred sensor for RNAV/LNAV. So, there is no reason that a TSO-C146 (WAAS/LPV) couldn't do RF legs with, or without, WAAS and or LPV. Having said that, I haven't heard of any proposed implementation along those lines for WAAS and LPV. |
Any inside story re 430/530 WAAS cert.? | [email protected] | Instrument Flight Rules | 0 | May 20th 05 06:13 PM |
WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 04:06 AM |
Terminology of New WAAS, VNAV, LPV approach types | Tarver Engineering | Instrument Flight Rules | 2 | August 5th 03 03:50 AM |
Big News -- WAAS GPS is Operational for IFR | Lockheed employee | Instrument Flight Rules | 87 | July 30th 03 02:08 AM |
Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 01:43 PM |
