Bob Gardner wrote:
Conventional wisdom, according to every controller I have ever discussed this with, is to forget about the regs, fly to the destination as planned and shoot an approach. Their reasoning is that once you are identified as NORDO, either by transponder or by failing to communicate, they will sterilize the airspace around the destination until you are on the ground. They do not want to keep other planes hanging while you comply with the regs You will not find this in writing in any official pub. Interesting. I just took my IA checkride and of course they asked about NRODO rules. The DE said "what would *you* do?" I told him. "The regs say .... but after reading a heck of a lot, apparently controllers expect you to shoot you choice of IAP as soon as possible as not to tie up air space." He said "perfect." I specifically ask him about holding until your planned arrival time and his reponse was that it was nonsense and the FAR's have not been updated to follow the controller's bible. Can a controller confirm this? Gerald |
![]() "G. Sylvester" wrote: Bob Gardner wrote: Conventional wisdom, according to every controller I have ever discussed this with, is to forget about the regs, fly to the destination as planned and shoot an approach. Their reasoning is that once you are identified as NORDO, either by transponder or by failing to communicate, they will sterilize the airspace around the destination until you are on the ground. They do not want to keep other planes hanging while you comply with the regs You will not find this in writing in any official pub. Interesting. I just took my IA checkride and of course they asked about NRODO rules. The DE said "what would *you* do?" I told him. "The regs say .... but after reading a heck of a lot, apparently controllers expect you to shoot you choice of IAP as soon as possible as not to tie up air space." He said "perfect." I specifically ask him about holding until your planned arrival time and his reponse was that it was nonsense and the FAR's have not been updated to follow the controller's bible. Can a controller confirm this? Gerald The regulation is painfully obsolete. Nonetheless, it is the regulation. ATC does not write or interpret regulations, at least not for pilots. If you are in a low-traffic, especially non-radar area, you should follow 91.185 exactly, if you can. If you are in a robust, busy radar terminal area, best to use emergency authority and keep on trucking similar to what controllers suggest for those locations. After the fact, you don't cite ad hoc controller advice as your reason for deviating from 91.185, rather you cite the inconsistency of that regulation with NORDO operations in busy terminal airspace, and thus a reasonable excerise of pilot emergency authority. Having said that, how often is a light aircraft going to still have nav radios and no comm capability? |
![]() David Rind wrote: wrote: Having said that, how often is a light aircraft going to still have nav radios and no comm capability? Assuming by "nav radios" you're willing to count anything I can navigate with, this can easily happen since I always have a handheld GPS with me. I do also carry a handheld comm, but do not have a link to an external antenna so I'm not convinced I could always reach someone with it. That could work. But, someone flying a jet probably can't do that. |
