Cessna 172 Oil Temp
Old June 25th 05, 04:44 PM
Darrel Toepfer
Gary Wilcox wrote:
I have a 1964 Cessna 172 (Continental 0300D) and the oil temp seems to be
running higher than I remember from last summer. Its still in the green but
only a needles width below the red-line. What is normal? Conditions during
the latest flight were hot and humid - temp at ground level was 92 and
relative humidity in the 90's.
The engine had all cylinders re-built a couple of months ago and I am
runnning straight mineral oil (Aeroshell 80). All of the baffles are in good
shape and the mechanic sealed all of the seams with sealant during the
cylinder rebuild.
Leaning too much? Perhaps you aren't getting full rich... Makes a big
difference at low altitudes with our C172F... I dunno if I'd still be
running mineral oil, break in wasn't required, rings should be seated by
now, we run Aeroshell 100... Make sure all the baffles aren't folded,
putting the cowling on can sometimes bend them the wrong way...
There are STC's available for adding an oil cooler... And don't
overfill, too much oil might also cause an overheat issue. We run ours
below 7 quarts but above 6.5...
Old June 25th 05, 05:20 PM
RST Engineering
"A couple of months" tells us little about the number of hours. How many
hours on the engine since rebuild? What was done on the "rebuild"? New
rings (I hope), rechrome?
Darryl, I don't have my O-300 book handy, but as I recall when I overhauled
my engine the book recommended mineral oil for the first fifty hours.
When I overhauled the 182 jugs and rechromed them, the oil temperature ran
hot for the first ten to fifteen hours, and then dropped like a rock when
the rings finally seated to the chrome.
but
during
good
cylinder rebuild.
There are STC's available for adding an oil cooler... And don't overfill,
too much oil might also cause an overheat issue. We run ours below 7
Old June 25th 05, 06:04 PM
Darrel Toepfer
About there or oil consumption geaux's down, which was what I was
eluding to. Some like to run a mixture of mineral and multiweight...
Another thing is to make sure the blast tubes from the back baffle are
pointed at the oil screen and not bent and blowing elsewheres...
Whats your take on this "new" CO (Carbon monOxide) measurement
requirements at annual. Was our IA just extorting extra time/money?
http://www.faa.gov/avr/arm/arac/arac...nical3_all.doc
11. AC 20-32B, Carbon Monoxide (CO) Contamination in Aircraft -
Detection and Prevention.
Sec. 121.219 references ventalation requirements:
http://www.faa.gov/asd/international...%20Notepad.pdf
"carbon monoxide concentration may not be more than one part in 20,000
parts of air"
Page 15-6 just references what it can do to you in the Pilots Handbook:
http://av-info.faa.gov/data/training...83-25-4of4.pdf
Old June 25th 05, 06:34 PM
RST Engineering
11. AC 20-32B, Carbon Monoxide (CO) Contamination in Aircraft - Detection
and Prevention.
Which references standards for transport category aircraft.
parts of air"
Part 121 is the section for air carrier aircraft.
And they are correct, but hardly regulatory.
What is this CO measurement thing that you are talking about? Are you
saying that somebody has determined that a CO measurement is part of an
annual inspection on a part 91 aircraft? Not anything I've heard about, but
that doesn't say it didn't slip by me. Then again, you may have been part
of the mechanic's Hawaii fund.
Old June 25th 05, 07:07 PM
Darrel Toepfer
Yes. Which is what we figured too...
Old June 25th 05, 10:04 PM
RST Engineering
And I read in another thread where he wanted to "sniff for CO" with the
airplane at various angles to the wind?
Repeat after me very carefully ... Carbon monoxide is a colorless gas with
no perceptible odor.
Now it is true that CO is generally mixed with other exhaust gases which DO
have an odor, but that's not always true.
If the visual inspection of the stacks, the muffler and the shroud show
absolutely no evidence of exhaust gas leakage, tell me how in hell he
expected any gas leakage into the cabin?
"Darrel Toepfer" wrote in message
but that doesn't say it didn't slip by me. Then again, you may have been
part of the mechanic's Hawaii fund.
Old June 26th 05, 12:37 AM
Darrel Toepfer
Kneaux news there...
Commercial CO Monitor with a wand (rigid tubing) attached...
Old June 26th 05, 12:54 PM
Mike Spera
He's sniffing for money... yours.
Sorry, I just had to get one in.
Mike
Old June 26th 05, 03:13 PM
Gary Wilcox
The engine has around 400 hours since major (1995) new Superior cylinders
installed at that time. Found aluminum in the oil last winter, oil analysis
said it was piston pin cap material. Pulled all cylinders and had re-built,
new rings, new piston pins, new exhaust valves and guides. Temp has seemed
higher since the cylinder work. Would expect temp to be higher during
break-in but its been 26 hours since the cylinder work.
The 172 users manual says temp should be in the green with max allowable
temp at the red-line. Anyone know what the actual temp is for this 172 at
red-line, any way to calibrate the gauge?
Thanks for your help
Gary
"RST Engineering" wrote in message
overhauled
be
but
during
good
cylinder rebuild.
overfill,
Old June 26th 05, 04:04 PM
RST Engineering
According to the type certificate data sheet for the O-300D the max
allowable inlet temperature for the oil is 225F. I've always done an
"eyeball" test with a hot plate and boiling water. If the needle is about a
needleandahalf below redline, that is about right.
I looked at the tc for the Cessna and strangely enough, it doesn't specify
the redline temperature. My 172 manual got burned in a hangar fire about
ten years ago and I haven't gotten around to replacing it.
Gary
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Piloting 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Products 1 November 4th 03 12:57 AM
