On 24 Jun 2005 16:30:32 -0700, "Tony" wrote:
Not to put too fine a point on this, Corky, but you can in fact enter a climb and still maintain 1 G downward relative to the axis of the airplane, but you have to decelerate while starting the climb. I agree that you can't climb at a steady rate and not experience a shift in g forces aft, but as your bring the nose up you have to slow down as well, to add a little negative acceleration to offset the aft shifting gravity vector. Think of it this way. If you hang a plumb bob in the airplane, and start a climb, the bob will shift aft. If you're in level flight and slow down, it'll shift forward. If you combine the two correctly, it'll stay pointing at the same spot on the floor. If you agree with this reasoning, you'll also agree that with a fast enough entry speed you could pull through an entire loop -- it wouldn't be round! -- and keep the plumb bob centered over the same spot. Tony, it doesn't matter where the plumb bob hangs, going up means adding some force in excees of 1G to do it. No matter how gently you do it, a sensitive enough G meter will detect the additional force that is required. It's kind of like trying to fake out a bathroom scale. No matter how gently you step onto it, it will eventually read your weight. Climbing is like pushing against an inverted scale. Corky Scott |
Corky, you're right. Earlier the discussion was about a roll: I think I
can present a model for experiencing 1 g throughout what might be called a roll, but that argument fails for a straight loop. |
Corky Scott wrote: Tony, it doesn't matter where the plumb bob hangs, going up means adding some force in excees of 1G to do it. No matter how gently you do it, a sensitive enough G meter will detect the additional force that is required. It's kind of like trying to fake out a bathroom scale. No matter how gently you step onto it, it will eventually read your weight. Climbing is like pushing against an inverted scale. Corky Scott Corky, "Net force = mass times acceleration" (Isaac Newton, ~1620) "Acceleration = rate of **change** of velocity" "Work done = force times distance" If you're standing on a bathroom scale in a stationary elevator at the ground floor, the scale will read your weight. Gravity (the invisible gravitational field) is pulling down on you with a force mg (your mass times the acceleration of gravity); the scale is pushing back up on you with the same force mg (and that force is what its dial reads). The total force on you (the sum of gravity pulling down on you plus the scale pushing up on you) is thus zero, but it's zero not because you're stationary, that is, remaining at a constant level; it has to be zero because you're at a constant vertical speed, namely zero; you're not *accelerating* (changing speed) -- not at this point anyway The doors close, the elevator starts upward. For a brief initial period, until the elevator reaches its steady-state upward speed, the scales read more than mg. That's because the elevator (or whoever is pulling on the elevator cable) is both pushing you upward with a force equal to your weight (mg), which does work and adds to your potential energy in the gravitational field; but there's also a slight excess force at the start which is needed to accelerate you to the steady-state speed of the elevator (and which therefore gives you a little kinetic energy as well as your steadily increasing potential energy). Once the elevator reaches its steady-state speed (around the 3rd floor, let's say) from there up to the 104th floor you're traveling at a *constant* vertical velocity: you're *not accelerating*. Therefore there can't be any net upward force on you; the scales read mg. [This does leave out the fact that the value of g changes very (very! very!) slightly between the ground and the 104th floors, but this change is so minute in going from the ground floor to the 104th floor that it's just not in the discussion here.] The rest of the way up, from the 3rd to 101st floors, the scales are pushing up on you with a constant force mg; and that force eventually acts through a distance h, the height from the ground floor to the 104th floor. Total work done by the elevator on you is therefore force times distance, or mgh. That work has gone into giving you an added potential energy equal to mgh in the Earth's gravitational field. [As you neared the 104th floor and the elevator slowed to a stop, you also lost the kinetic energy you had gained between the ground and third floors. The scales showed a small reduction below mg between 101 and 104 just as they showed a small increase between first and 3rd floors.] You now own that extra potential energy of mgh; it's yours, as you step off the elevator on the 104th floor. Want to get it back? Step outside on the viewing deck and pop over the railing. Leaving aside questions of air resistance, by the time you get back down to, say, the first floor level you'll have all that potential energy converted into kinetic energy -- a lot of kinetic energy! Unfortunately, one floor later all that energy energy will pretty much have been converted into heat, slightly warming up a small patch of sidewalk and some gunk on it. Same deal in a plane: hang a seat from a butcher's scales hung from the ceiling of a plane, and sit in it. Have someone fly the plane in a constant forward speed, constant upward speed, straight line climb. Except for a slight initial transient period when they begin the climb, the scales will read your weight, mg, no more, no less. --"Another Tony" |
On Mon, 27 Jun 2005 at 12:30:45 in message
, Corky Scott wrote: Tony, it doesn't matter where the plumb bob hangs, going up means adding some force in excees of 1G to do it. No matter how gently you do it, a sensitive enough G meter will detect the additional force that is required. Although it is true that a climb cannot be initiated without exceeding 1g in the transition from level flight to climb, a climb at a steady speed and climb rate does not mean that more than 1g is felt in the aircraft. Why should it? If there is no acceleration there is no g other than the gravitational one. Of course this does ignore the fact that the earth's gravity is reduced as the aircraft moves further from the surface of the earth! -- David CL Francis |
David, the issue for me was 1 g down, into the seat. In a steady state
climb one experiences one G, but if the nose is 5 degrees up that force is 5 degrees aft of down. My understanding of the question (and it could not be an accurate understanding) was, can one somehow roll an airplane without having it experience anything other than 1 g "down". I think it's been shown the airplane can be rotated 360 degrees on its axis with the pilot always experiencing 1 g down into the seat. At that point though the airplane is going downward pretty fast, and the weight vector would shift forward of straight down. |
On Thu, 30 Jun 2005 at 18:35:25 in message
.com, Tony wrote: David, the issue for me was 1 g down, into the seat. In a steady state climb one experiences one G, but if the nose is 5 degrees up that force is 5 degrees aft of down. My understanding of the question (and it could not be an accurate understanding) was, can one somehow roll an airplane without having it experience anything other than 1 g "down". I think it's been shown the airplane can be rotated 360 degrees on its axis with the pilot always experiencing 1 g down into the seat. At that point though the airplane is going downward pretty fast, and the weight vector would shift forward of straight down. Tony, I see where you are. I would say that if that is what you using as a datum then the 'g' down axis will vary from a few degrees at high speed in level flight to up to around 12 degrees or more at touchdown in level flight without any aerobatics at all.. But in your definition it would be impossible to have a flight that included take off and landing and a modest climb and descent at a strict '1g' down. I was assuming a steady one 'g' at right angles to the free stream airflow! -- David CL Francis |
David CL Francis wrote: David, the issue for me was 1 g down, into the seat. In a steady state Tony, I see where you are. But in your definition it would be impossible to have a flight that included take off and landing and a modest climb and descent at a strict '1g' down. I'm still struggling to think this whole problem through from the viewpoint of someone who likes to solve "simple" physics problems, but is absolutely not a pilot. Let's just take the part of the flight that involves climbing at a constant upward rate and then leveling off. Seems as if you will never be able to convert to level flight without reducing the upward velocity vector, ergo some (negative) vertical acceleration has to occur. But what if you roll the plane, slowly and gently, about a longitudinal axis that passes through the bathroom scales, simultaneously applying control forces so that the plane begins turning right. If you can roll slowly enough so you neglect the rotational inertia of the pilot about this axis and simultaneously turn right at the correct rate, during this time the seat will push the pilot (who's a point mass, of course) up with *less* vertical force than previously, while pushing (and accelerating) the pilot to the right with a small horizontal component of force. If you do this just right, you ought to be able to keep the total force pushing from the seat into the pilot equal to the pilot's weight. Do this carefully enough, keep it up for a while, then roll back to level, and you ought to be able to bleed the vertical velocity down to zero and thus be leveled off -- though with a different compass heading -- while keeping the bathroom scales reading a constant value equal to the pilot's weight. Does this make sense? --"The other Tony" P.S. -- Takeoff and landing is more easily solvable. You just need a long enough taxiway that can be curved but eventually feeds straight into a (potentially very short) runway, with both of these at the point where they join having exactly the same upward slope as the slope that you want to climb at after takeoff, and with the runway ending at the edge of a cliff. So, all you have to do is accelerate up to full flying speed while you're still on the taxiway -- which of course doesn't count since you're still only taxiing -- until you get on the runway part and just keep going. Landing is obviously the same thing reversed. |
About taking off and landing: If you take as the goal 1 g downward --
that's an integer, not 1.0000 plus or minus a little bit, you can't do it. There is acceleration. The same thing is true for a loop, there just are not enough degrees of freedom to allow the pilot to see the horizon drop down as he climbs, then reappear inverted at the top of the loop, without experiencing some incremental (even if small) g forces. I think a roll adds the additional variables one might need. Consider, for example, a plane about 45 degrees into a roll. At that moment, in coordinated (pilot talk for keeping the pilot's weight centered on the seat) level flight there's a g toward the center of the earth, and another along the radius of the turn. The pilot experiences 1.414 gs into his seat. If, however, the airplane is also pitched down 45 degrees accelerating, and coordinated, you could choose numbers that'll resolve to 1 g into the seat. Take now a bank of 90 degrees. If the airplane is pointed straight down and accelerating at 1 G, that is, in free fall vertically, there'd be no fore and aft weight component. The pilot would, however, have to be pulling back on the yoke hard enough to accelerate in the nose up direction at 1 G. At inverted if level he'd be experiencing 1 g "up", so he'd have to have the yoke back far enough to accelerate in the nose up direction 2 gs worth. You can, at each point point in the "roll", calculate how the airplane must be accelerating in the nose up direction and what direction the nose must be pointing for the pilot to experience 1 g down. I don't know if it's a realizable manouver -- it'll take some serious elevator "authority" to provide the nose up accelerations that are needed. Some insightful person in this thread made the observation that if the airplane was during the roll just accelerating downward at 1 G -- in free fall, if you will, one need not worry about the gravity effects and the pilot would just have to pull back on the yoke hard enough to keep the nose accelerating up at 1 g. It's an interesting problem. I think the airplane, as seen from outside, would look like it was in a death sprial. The pilot, however, would see the horizon rotate through 360 degrees, so he'd say he rolled the airplane. At the end of the roll the airplane would be in a serious nose down attitude, and going pretty fast. I don't think you can get from there to straight and level while keeping a local 1 g down weight component. |
"Tony" wrote:
At the end of the roll the airplane would be in a serious nose down attitude, and going pretty fast. I don't think you can get from there to straight and level while keeping a local 1 g down weight component. Of course not. I think the only reasonable interpretation of the "aileron roll is a 1-g maneuver" claim is that the maneuver itself will be at one g, while setup and recovery can be at g-loads normally experienced in non-aerobatic flight. E.g, enter a 15-degree nose-up climb (requiring more than 1-g), do the roll at 1-g, then recover from the resulting 15-degree nose-down dive (requiring more than one g). -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
On Fri, 1 Jul 2005 at 18:35:50 in message
, AES wrote: In article , David CL Francis wrote: David, the issue for me was 1 g down, into the seat. In a steady state Tony, I see where you are. But in your definition it would be impossible to have a flight that included take off and landing and a modest climb and descent at a strict '1g' down. I'm still struggling to think this whole problem through from the viewpoint of someone who likes to solve "simple" physics problems, but is absolutely not a pilot. It would help if you give a picture of what you mean by simple physics: e.g. are you comfortable with Newton's basic mass and force equations? Do you have any knowledge of vectors as applied to forces? Are you able to calculate the forces required for a level banked turn of a given angle? Do you have any knowledge of the simple calculations of drag and lift? There could be others but it is difficult to answer without knowing something more about your starting point. You may not believe this, but I have been caught up in discussions with people, trying to help them when their sole object was to stir things up. I am not a pilot either although I have, many years ago, flown solo. Now I am an elderly ex-aerospace engineer whose powers have faded somewhat! Let's just take the part of the flight that involves climbing at a constant upward rate and then leveling off. Seems as if you will never be able to convert to level flight without reducing the upward velocity vector, ergo some (negative) vertical acceleration has to occur. Correct, but in some cases it may be quite a small effect. But what if you roll the plane, slowly and gently, about a longitudinal axis that passes through the bathroom scales, simultaneously applying control forces so that the plane begins turning right. You lost me there! If you can roll slowly enough so you neglect the rotational inertia of the pilot about this axis and simultaneously turn right at the correct rate, during this time the seat will push the pilot (who's a point mass, of course) up with *less* vertical force than previously, while pushing (and accelerating) the pilot to the right with a small horizontal component of force. If you do this just right, you ought to be able to keep the total force pushing from the seat into the pilot equal to the pilot's weight. If by 'correct rate', you mean a properly balanced turn then you are wrong. In a balanced turn the pilot will always detect slightly more 'g'. Remember what the pilot feels is the vector sum of any accelerations. Do this carefully enough, keep it up for a while, then roll back to level, and you ought to be able to bleed the vertical velocity down to zero and thus be leveled off -- though with a different compass heading -- while keeping the bathroom scales reading a constant value equal to the pilot's weight. Does this make sense? Not to me. Are your bathroom scales fixed to the aircraft and under the pilot's seat? --"The other Tony" P.S. -- Takeoff and landing is more easily solvable. You just need a long enough taxiway that can be curved but eventually feeds straight into a (potentially very short) runway, with both of these at the point where they join having exactly the same upward slope as the slope that you want to climb at after takeoff, and with the runway ending at the edge of a cliff. You have lost me again. So, all you have to do is accelerate up to full flying speed while you're still on the taxiway -- which of course doesn't count since you're still only taxiing -- until you get on the runway part and just keep going. Only a vague idea what you might be trying to get at here. If you are referring obliquely to a 'ski jump' then the only difference is that the slight acceleration required is provided a forced rotation on a curved slope than the result is the same except the force is in the original case is provided by lift (and thrust) and in the second by the change of momentum caused by being forced around a curve. You feel it just the same. Keep up the search for enlightenment! -- David CL Francis |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Rolling a 172 - or not | Scott Lowrey | Piloting | 55 | November 16th 03 12:15 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
