FINALLY saw a P-38 fly
Old June 27th 05, 06:03 PM
George Patterson
Montblack wrote:
In your P-38 aviation video (Start-Up) the two props are spinning in the
same direction.
I've watched that quite a few times now, and I think this must be some kind of
optical illusion. If you freeze the display when one of the right prop blades is
vertical and above the wing, it appears to be in line with the camera. That is
consistent with the prop rotating clockwise as viewed from behind. If you freeze
the display when one of the left prop blades is vertical and *below* the wing,
it appears to be in line with the camera. That is consistent with the prop
rotating counter-clockwise.
The 2004 publicity shot I posted earlier also seems to have counter-rotating props.
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
Old June 27th 05, 07:41 PM
Dale
From memory only, all P-38s had counter-rotating props. The early
version the props turned "in" as in most designs today with
counter-rotating props. Most production models had the props turning
"out"...the direction that most adversely effects handling/performance
during single engine flight.
Dale L. Falk
Old June 27th 05, 08:10 PM
Paul Tomblin
No, the British ones turned the same way. They also didn't have
superchargers, which probably explains why P-38s are thought of as a
Pacific theatre plane.
Paul Tomblin http://xcski.com/blogs/pt/
Usenet is a co-operative venture, backed by nasty people -
follow the standards.
-- Chris Rovers
Old June 27th 05, 08:56 PM
Newps
Yep, Chuck Yeager said in his book that the P38 was the worst plane that
you could possibly make for the mission it was given over there in Europe.
Old June 28th 05, 06:16 PM
John T
Yep, read a book that said the P-38 was a success in the pacific and
africa/med theatres because the the combat was low alt, while the
european theater was high alt where the P-38 wasn't a good performer.
John
Old June 28th 05, 12:14 AM
CryptWolf
"Paul Tomblin" wrote in message
The British rejected the special run of P-38s and they were used for
training in the US. Give me some time and I can even dig up the exact
designation and probably the serial numbers. The British version wasn't
actually designated a P-38 and something of an oddball. Wish I could
remember the title of the book. You really can have to many books
sometimes, but that is another story and part of how I got started in
flying.
The P-38 was used quite a bit in Europe and the Pacific by the US until it
was replaced by the P-51. I don't think the British ever flew a P-38 in
combat.
The F-4/F-5 (P-38 photo versions with no guns) recce birds remained for a
time after the regular P-38s were retired.
Which reminds me of a joke about the pilot who screams over the radio
in a panic "My engine quit. What do I do?"
To which the old P-38 pilot replies "Feather the prop, bank into the good
engine and fly it home."
The other pilot replies "But I only have one engine it's a P-51".
The old P-38 pilot replies back. "Then I guess you are going swimming."
Or something like that. So I was told or maybe read somewhere.
Old June 29th 05, 04:13 AM
Jay Honeck
flying.
That would probably be "Fork-Tailed Devil" by Martin Caidin.
An absolutely outstanding book, by the way. It started my love affair with
the P-38 when I first read it, some 35 years ago...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old June 28th 05, 04:25 AM
George Patterson
They're considered a Pacific theatre plane because Ira Eaker wanted to set the
8th Air Force up with only one type of fighter escort (to reduce spare parts
counts and other maintenance issues). Lockheed could not provide enough P-38s to
supply the entire 8th. North American could provide enough P-51s. Eaker had the
Lightnings transferred out.
George Patterson
Old June 28th 05, 05:11 PM
Corky Scott
On Mon, 27 Jun 2005 19:10:52 +0000 (UTC),
The P-38 sometimes gets a bum rap for it's appearance in the European
theatre. The initial versions had excessively complicated controls
and had the turbocharger tubing running up and down the D section of
the wing. Naturally there were a lot of leaks in this system.
The oil being used apparently congealed at very low temperatures, the
type encounted at the typical high altitudes at which combat occured.
The fuel seemed to be a problem too, with seperation of components
occuring, which reduced it's octane rating leading to severe
detonation and engine failure. Frequently.
The cockpit heater was not adaquate leading to frosting of the
windshield and canopy, which of course made it difficult to see out
of. Seeing out is considered reasonably important in a combat zone.
In addition, the lack of heat severely incapacitated the pilots.
In addition, there was the problem of not being able to exceed a
certain speed in a dive, which allowed the Messerschmitt's and Focke
Wulf's to dive away vertically with impunity.
The DC-4 bringing dive flaps that would have alleviated this situation
was mistaken by an intercepting Spitfire for a Focke Wulf Condor, and
shot down off the coast of Scotland.
The P-38's shape is and was of course unique, a disadvantage in a
combat zone as the enemy knows for sure that you are foe, no mistake.
Plus the P-38 was a big airplane which meant that it could be seen
from a greater distance.
As if this weren't all enough to make the fighter unpopular, it's
controls stiffened up at high speeds, a characteristic shared by most
fighters designed early in the war.
Finally, at least one expert remarked that to transition from cruise
power settings to combat power required so many control manipulations,
coolant flap settings, and myriad other adjustments that pilots had
their heads down in the cockpit making them all while being bounced,
all the while flying in a straight line.
That last may be a slight exaggeration.
In any event, the last model of P-38 deployed to Europe had boosted
controls and automated cooling controls. The boosted controls made it
instantly more maneuverable than most of it's opponents. It was a
formidable fighter and few German or Allied airplanes were it's match.
But by then the orders were cut and the P-38 was replaced by the P-51.
It cost a lot less to manufacture P-51's than P-38's, more could be
built in a month than P-38's and the performance was essentially
equal, especially in regards range.
So the P-38 was sent to the Pacific where it excelled.
Corky Scott
Old June 29th 05, 04:22 AM
Jay Honeck
Considering that our leading ace of the war, Richard I. Bong, flew only the
P-38 in the Pacific Theater, as did Tommy McGuire -- our Number 2 Ace in the
war -- this last is, indeed, an exaggeration. As with all things, with
practice all movements were done without thought, nearly instantly.
Indeed.
The P-38 failed in Europe because the climate was too damned cold, and
because the airplane had a few design flaws that were heightened by the
cold. As you state, by the time the J and L models came along -- which
fixed all of the early shortcomings -- the orders had already been cut to
transition to the Mustang and Thunderbolt.
Jay Honeck
Iowa City, IA
Pathfinder N56993
It's finally running! Corky Scott Home Built 19 April 29th 05 04:53 PM
Finally got my X-country in.. PJ Hunt Rotorcraft 0 December 18th 04 10:50 AM
Cobra Tongue Strut Removed Finally Brian Iten Soaring 0 December 4th 04 07:54 PM
Finally flying new Skyhawks! Scott Schluer Piloting 11 February 24th 04 10:02 PM
It’s finally ready! Joern Lillehagen Home Built 0 September 4th 03 02:11 AM
