![]() wrote in message ups.com... I'm hoping the home built community can assist me with a small problem. I own a glider that does not fly straight without applying a little constant cross control (L stick and R rudder). If hands are removed from the controls, it slips (or yaws?) to the left, and then the nose gently swings around to the right. If allowed to continue, the aircraft begins to dive to the right and rapidly builds up airspeed. The aircraft was never damaged but may have had control rods for the ailerons replaced putting the control surfaces out of alignment. The maintance manual gives the proper aileron and flap deflection angles. The angle is measured from a reference point on the bottom surface of the wing 100mm forward of the aileron-wing junction to the trailing edge of the aileron. My question is how do you measure the angles of the control surfaces to see if they are within tolerance of their deflection angles? Sounds like more a matter of where the neutral points are rigged, not what the deflection is at the stops. Maybe a warp in the left wing; less washout? Does the rudder have centering springs? If so an imbalance there... |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
PIK20D Control surface hinge moments | PIK20D | Soaring | 3 | November 19th 04 03:06 PM |
Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 02:20 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
