Cessna 182 or 182RG tips?
Old July 3rd 05, 01:32 AM
Paul Tomblin
Default Cessna 182 or 182RG tips?
Our club is worried that we're not going to be able to get insurance for
our Lance any more. (We had to switch to a named pilot policy this year,
previously anybody in the club could fly it if they met the currency and
checkout requirements.) Plus the Lance is going to need a new engine next
year, and we don't want to put $25K+ into a new engine if we won't be able
to keep the plane for more than a year or two.
So now we're looking at replacements, and one type of plane that people
keep mentioning as a possibility is the C-182 or C-182RG, because it has
similar performance to our Dakota, but better interior room. I've never
flown a high wing before. Is there any tips or hints you could give me to
help the transition?
Paul Tomblin http://xcski.com/blogs/pt/
....I'm not one of those who think Bill Gates is the devil. I simply
suspect that if Microsoft ever met up with the devil, it wouldn't need an
interpreter. -- Nick Petreley
Old July 3rd 05, 02:08 AM
Dan Luke
people
has
never
me to
182s have a tendency to drop hard on the nose gear on landing if you
don't watch 'em. Be sure to add "up" elevator trim on short final and
carry just a little bit of power into the flare. Other than that, a
Skylane is your grandma's Oldsmobile.
Dan
C172RG at BFM
Old July 3rd 05, 02:40 AM
Mortimer Schnerd, RN
Cessnas as a general rule glide better than Pipers. I generally chop the
throttle on final when I'm still a couple of hundred feed shy of the
threshold... something I wait a while longer to do when I fly Cherokees.
Take offs are smoother also. In the Cherokees, you generally skip a couple of
times before you actually lift off unless you wait to rotate until you have
flying speed. In the Cessna, you can rotate once you accelerated to stall speed
and roll along on the two mains until the airplane flies itself off when it's
ready.
That being said, the 182/182RG/206/210 series are all markedly nose heavy. Like
the old Cherokee Six, they have the reputation of flying if you can get the
doors closed. Personally, I think the 210 is the best of the bunch... 165 knots
on about 13.5 gph... and it will carry six... if you put the wimmins in the back
seat.
VE
Old July 3rd 05, 02:56 AM
Dave S
seat.
Insuring 6 seats in a "rental" appears to be the problem. Trading a low
wing 6 seater for a high wing six seater doesnt do much to address that
problem.
Dave
Old July 3rd 05, 03:01 AM
Paul Tomblin
in the back
seat.
problem.
So far it's 6 seats PLUS complex. We know clubs that haven't had problems
with Arrows, and we know clubs that haven't had problems with Cherokee 6s.
But every club with a Lance or a Bo is having insurance problems.
Beware of bugs in the above code; I have only proved it correct, not tried it.
- Donald Knuth
Old July 3rd 05, 03:04 AM
Matt Whiting
I prefer Cessnas to Pipers. I got my private in Cessans and my
instrument in Pipers. I owned a 182 for six years and now fly a club
Arrow. I've never flown a Dakota, however, so I can't make a direct
comparison. The main difference I see between the 182 and the Arrow I
fly now is that the 182 has a much better glide ratio and lighter
ailerons and rudder. Pitch forces are similar. I find the 182 easier
to land. I think you will find that the transition will take one
landing maybe two, neglecting the "systems" transition which may take a
while depending on how different the avionics are between the two.
Matt
Old July 3rd 05, 03:08 AM
Matt Whiting
people
has
never
me to
It's funny as I'd heard this also and found the 182 to not have this
tendency any more than any other airplane I've flown. Then again, as
you know from another thread, I was taught to make full stall landings. :-)
I'm therefore quite used to pulling the nose up on landing until the
stall horn bleeps or until the mains touch. Hopefully, nearly
simultaneously.
If you fly the 182 like a 150, then sure you land on the nose as the 182
probably requires 3-4 times the pull on the yoke to stall before
touchdown. However, I was taught to fly the airplane by using whatever
control input is needed to get the attitude/performance desired, not to
fly by control force. If fly this way, then the 182 is, as you say,
your gramma's Olds.
Matt
Old July 3rd 05, 03:44 AM
problem.
Well, then... get the 182RG. It ought to be fairly quick and I know it'll carry
a load.
VE
Old July 3rd 05, 04:16 AM
Dan Luke
and carry just a little bit of power into the flare. Other than
that, a Skylane is your grandma's Oldsmobile.
landings. :-)
Yes, it takes some mishandling to prang a 182's in this way.
Nevertheless, 182s are somewhat notorious for this - one of the first
things one checks on a used Skylane is the condition of the firewall for
hard landing damage.
simultaneously.
No problem if judged correctly.
182 probably requires 3-4 times the pull on the yoke to stall before
whatever control input is needed to get the attitude/performance
desired, not to fly by control force. If fly this way, then the 182
is, as you say, your gramma's Olds.
Matt
Old July 3rd 05, 04:22 AM
Capt. Geoffry Thorpe
"Dan Luke" wrote in message
tendency any more than any other airplane I've flown. Then again, as you
Yes, it takes some mishandling to prang a 182's in this way. Nevertheless,
182s are somewhat notorious for this - one of the first things one checks
on a used Skylane is the condition of the firewall for hard landing
damage.
All the more reason to get a 180 instead of the 182.
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
Tips on buying a cessna 182 Matteucci Aviation Marketplace 4 September 15th 04 08:42 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Piloting 1 November 4th 03 12:57 AM
